Which METEO data source for a home automation system ?
siutek84 2367 13
Where can I get weather data for a home automation system, especially cloud and fog information for a small town?
Use Yahoo Weather for town-level weather data, and estimate fog/cloudiness locally from sensors if needed [#15491749] [#15490090] Yahoo’s weather page and RSS feed can return forecasts for a specific small location, even when it is not covered by the common meteo services [#15491749] For fog, one reply suggests deriving it from wind, temperature, and humidity rather than looking for a direct source [#15490090] For cloudiness, you can place several light sensors in different spots and average their readings [#15490090]
  • #1 15490045
    siutek84
    Rate: 21
    Hello, as I have started working on home automation, I have also started looking for information to use in the system. As with any system of this type, there needs to be a meteo module. While I am able to get air temperature/pressure/humidity information from my own devices, likewise information on possible rainfall, the conundrum for me is the cloud/fog information.
    Where do I get it from to display it on the system? I should add that I live in a town of 15k, so it's hard to find it in the popular meteo systems.
  • #2 15490090
    LightOfWinter
    Help: 369
    Rate: 935
    Arguably, fog can be predicted from wind, temperature and humidity.
    For cloudiness, for example, you could add several light sensors away from each other and average from more measurements.
  • #4 15491841
    siutek84
    Rate: 21
    Erbit - you are a master!!!!! brilliant!
  • #5 15491870
  • #6 15491932
    siutek84
    Rate: 21
    Erbit wrote:
    siutek84 wrote:
    Erbit - you are master!!!!! brilliant!
    Yes, I know :D :D
    Modesty also comes through you :P
  • #7 15491994
  • #8 15492093
    siutek84
    Rate: 21
    at the moment I have too little to brag about.
    in any case, the components are:
    - arduino
    - router with OpenWRT
    - dS1820 temperature sensors
    and a few others. i am in the process of designing the web interface. I am also trying to plug the ds1820 into the router to monitor the temperature in each room. Tomorrow I am ordering an arduino nano to handle the 1-wire.
    In April my co-op is changing all the flats' water meters to ones with remote reading - I'd like to tap into that somehow.
    I'm also considering whether to ask the energy company to change the electricity meter to a remote reading version as well.
    Both water and electricity would be read by me for statistical purposes (collected and converted into appropriate graphs from the web panel)
    So the first stage is to monitor the temperature in the flat and outside (as well as the weather in general)
    The next stage is to successively connect light sources to the remote control (with this will be more fun)
    I recently bought programmable thermostats for radiators in Lidl for ridiculous money. But that's unlikely to be of much use to me, as I'd have to do the electronics from scratch to be able to remote control with that. Maybe one day I'll buy one that has remote control built in.
    What comes out is what comes out.... ;)
  • #9 15492150
  • #10 15492162
    siutek84
    Rate: 21
    As always it is certainly a question of reading what is being transmitted, perhaps someone has already figured out the signal. If not, I will actually figure something out myself and put it in front of the counter.
  • #11 15492170
  • #12 15492255
    siutek84
    Rate: 21
    send me your contact details, maybe I'll find something else interesting from him
  • #14 15492289
    siutek84
    Rate: 21
    thanks, I'm going shopping tomorrow ;)
