Windows 10 Language Switch: English to Polish Pack Download & Installation Issues
Rafal328 32259 11
How can I fix Windows 10 language pack installation when the Polish pack downloads but never finishes installing and keeps prompting me to download it again?
Update Windows 10 to the latest available version; after that, the Polish language pack installed without problems [#17246543]
  • #1 15499181
    Rafal328
    Rate: 31
    I have a problem with changing the language in Windows 10. I want to change the language from English to Polish. The language pack is downloaded, then installed, but the progress bar does not go to completion. A button to download the package from scratch appears, i.e. the package does not install. Can anyone help locate the cause of this behavior? Thanks in advance.
    best regards
  • #2 15499216
    moryson
    Try to run the installation in safe mode, provide the computer specifications
  • #3 15499238
    Rafal328
    Rate: 31
    It is a laptop, Acer Aspire F5-571-50S0
  • #4 15499249
    moryson
    Try to install in safe mode, or download the package again.
  • #5 15499326
    Rafal328
    Rate: 31
    In safe mode, the wi-fi drivers do not load despite running it with network support. I do not have an ethernet cable unfortunately. I downloaded the package several times, it can be done endlessly and it won't install anyway. Unable to download the package any other way?
  • #7 15499368
    Rafal328
    Rate: 31
    It is not possible to download packages from MS site, by the way I don't see any download link anywhere
  • #9 15499454
    Rafal328
    Rate: 31
    Thanks, and how to install it? This is a cabinet file, it contains a lot of different files and folders, where should I copy them?
    during installation from the control panel there is a description of the error in the event log
    "Installation Failure: Windows failed to install the following update with error 0x80246007: Polish Language Pack - Windows Technical Preview for x64-based Systems - (KB3146014) [en-PL_LP]."
  • #11 15499654
    Rafal328
    Rate: 31
    I'm sorry I didn't notice. When selecting a package file in the program, an error message appears stating that it cannot be installed on this system. Regarding the error with windows update, I have these 2 services enabled
  • #12 17246543
    pablo.m
    maybe the topic is old ...
    but I was helped by updating Win10 to the latest available version and the Polish language is installed without any problems
The discussion revolves around issues encountered while attempting to change the Windows 10 language from English to Polish. The user reports that the language pack downloads and initiates installation, but fails to complete, displaying an error and prompting for a re-download. Suggestions include running the installation in safe mode, but the user faces connectivity issues as Wi-Fi drivers do not load in safe mode. Alternative download sources are provided, but the user struggles with installation errors related to the Windows update service. A later response indicates that updating Windows 10 to the latest version resolved the installation issue, allowing the Polish language pack to install successfully.
