[Solved] Win 10: Missing Polish Developer Keyboard, QWERTZ/QWERTY Layout Issues, and Solution Steps
aro_40 16050 9
How can I restore the Polish programmer's keyboard layout in Windows 10 when only the Polish 214 keyboard is available?
Open Windows 10's Region & language settings and use Advanced keyboard settings / language options to add the Polish programmer's keyboard; it should appear as “Polish - Polish (programmer's)” [#17494720][#17494745][#17494785] If adding a language fails because Polish is already installed, add a keyboard instead of a language, since that is where the programmer's layout is available [#17494785] This solved the problem for the original poster [#17494776]
  • #1 17493778
    aro_40
    Rate: 17
    Today my daughter came with the computer, complaining about the lack of Polish letters. At first it turned out that it has a QWERTZ layout. Attempts to use CTRL + SHIFT did not help.
    After many searches, we managed to replace the keyboard with QWERTY, but the problem is that there are no Polish letters.
    I tried to use the WIN + spacebar combination, but both keyboards appeared, only there was no way to change it. After restarting the computer there is no such possibility.
    In the settings there is only the Polish keyboard (214) and there is no programmer's keyboard. Can you tell me how to get it back ????
  • #2 17493890
    krzychupar
    Help: 1490
    Rate: 633
    In the control panel, Region and Language are well positioned.
  • #3 17494426
    aro_40
    Rate: 17
    Poland and the Polish language are set.
  • #4 17494525
    krzychupar
    Help: 1490
    Rate: 633
    In the Keyboards and languages tab and change the keyboards in general, you can add a Keyboard.
  • #5 17494697
    aro_40
    Rate: 17
    Well, the problem is that there is ONLY a 214 keyboard, so there is nothing to change :(
    There is no general or keyboard in the 10 wines. Instead, there are regions and languages :(
  • #6 17494720
    ta_tar
    Help: 699
    Rate: 2052
    Did you go to "Advanced keyboard settings" in "Regions and language"? I have something like "Use the list of languages" and there is a drop-down list where "Polish - Polish (programmer's)" is
  • #7 17494724
    aro_40
    Rate: 17
    Yes, I did. But only Polish language is available
  • #8 17494745
    CodeBoy
    Help: 138
    Rate: 690
    Win 10: Missing Polish Developer Keyboard, QWERTZ/QWERTY Layout Issues, and Solution Steps Win 10: Missing Polish Developer Keyboard, QWERTZ/QWERTY Layout Issues, and Solution Steps
    advanced options to the language and you can add whatever you want.
    If it does not work, this playback from the backap because something might have fallen apart.
  • #9 17494776
    aro_40
    Rate: 17
    OK, it worked :) THX :)
  • #10 17494785
    aro_40
    Rate: 17
    Added after 4 [minutes]:
    I wanted to add a language, but it failed because there was no other version of Polish. But it turned out that you can add a keyboard (a programmer's keyboard will appear). After adding
The discussion revolves around a user experiencing issues with a missing Polish Developer Keyboard layout on Windows 10, specifically regarding the QWERTZ and QWERTY layouts. The user initially faced difficulties in accessing Polish letters despite changing the keyboard layout. Various suggestions were made, including checking the Region and Language settings, adding a keyboard in the Keyboards and languages tab, and exploring advanced keyboard settings. Ultimately, the user successfully added the Polish (programmer's) keyboard layout, resolving the issue.
