Left Shift + Right Alt + S Key Combination Not Working on Any Program
Boruxas 102909 19
Why does pressing Left Shift + Right Alt + S produce lowercase s instead of the Polish capital Ś, while Right Shift + Right Alt + S works?
The combination fails because the keyboard has key-rollover/ghosting limitations: this keyboard cannot correctly report Left Shift, Right Alt, and S pressed together, even though other combinations work. Test the keyboard with the MultiKeyDisplay ghosting tester to confirm the limitation [#19281343] Also verify that the active layout is Polish Programmer rather than Polish 214 or another Polish layout [#15525867] If the layout is correct and no background hotkey is intercepting the combination, replace the inexpensive keyboard; remapping is the alternative if replacement is not desired [#19281343]
  • #1 15525527
    Boruxas
    Hello!
    Well, my problem is flimsy, but troublesome for me - the point is that when I press the key combination: left Shift + right alt + s in ANY program "S" appears. However, strange as I take the key combination Right shift + right alt + s, "Ś" works without any problems. I'm just used to typing capital letters with the left shift and it's hard for me to switch. I even made a format to see if it worked (I know it's a "brilliant solution"). However, the problem persists.
  • #2 15525803
    pdurka
    Rate: 16
    and the rest of the Polish letters, e.g. ą, ę? it works? If it does not work, try the remapkey program, I will give the link http://www.remapkey.com/download.html, but first check if you have not assigned a keyboard shortcut to some program running in the background.
  • #3 15525806
  • #4 15525867
    sylweksylwina
    Help: 1882
    Rate: 2355
    It is also possible that this keyboard does. Maybe some Chinese genius did not predict that someone would type "Polish capital s with a line" on the keyboard. Of course you have to make sure that the keyboard layout is "Polish programmer" and not "Polish 214", or "Polish" only.
  • #5 15525888
  • #6 15525889
    pdurka
    Rate: 16
    I do not recommend buying keyboards from little-known companies. It is enough to buy a cheaper but good one. Besides, maybe his chip is broken.
  • #7 15525965
    Damnian
    Help: 193
    Rate: 89
    Check if any program has HotKey in this combination. Most often it is in the drivers of the graphics card.
  • #8 15531010
    Boruxas
    -I have this Polish programmer set up and tried with everyone else Polish
    -yes, other Polish characters like ą, ę etc. work big and small
    -no program in the background does not cause this, closed what I could and only with the right Shift entered
    -with this problem in the keyboard itself: I will let you know soon because I do not have something else at hand
    -with HoKey in graphics: I'm more of a physical work than an IT specialist, so I don't know how to check it
    - remapkey: the screenshot attachment best describes my situation.
    Overall, thanks a lot for all these helpful answers and sorry that I couldn't write back during the day with the hook.
    • Left Shift + Right Alt + S Key Combination Not Working on Any Program tototototot.PNG (71.34 KB) You must be logged in to download this attachment.
  • #9 15531552
    Damnian
    Help: 193
    Rate: 89
    I don't know what graphics card you have, so I can only guess .. you right-click on the desktop and enter the graphics properties or there should be a direct link to the Nvidia or Radeon driver. There, find the hotkey options or whatever sounds similar and deactivate it.
  • #10 15531954
    Boruxas
    The graphics card is an nvidia GTX960 and after right-clicking I have the "NVIDIA Control Panel" option. I haven't found anything there about these hotkey options unless it's just under a different name or I'm blind and I can't see it.
    • Left Shift + Right Alt + S Key Combination Not Working on Any Program tototototot.PNG (128.12 KB) You must be logged in to download this attachment.
    • Left Shift + Right Alt + S Key Combination Not Working on Any Program fggggggggggh.png (22.24 KB) You must be logged in to download this attachment.
  • #11 15546965
    Boruxas
    I checked my brother's keyboard, or rather "checked". He has a 6-pin keyboard and he works without a problem in my computer, and I don't read it like that and I don't have how to check the damn Left shift + right alt + s. Now the question: what is k # @% not like this with my computer?!?
  • #12 15551025
    chmieluzg
    If you connect a different keyboard to your computer and it will be 100% fault with the keyboard. If it still won't, it will either be language / keyboard settings or hotkeys.
  • #13 15551793
  • #14 15565714
    pdurka
    Rate: 16
    @ Aseri15 but he has a ps / 2 port, how to connect? unless you need to buy a USB adapter.
  • #15 15566013
  • #16 15566766
    bartix1990
    Rate: 21
    This is how you buy cheap keyboards ;-)
  • #17 15567655
    pdurka
    Rate: 16
    @ Aseri15 and not a PS / 2 port better? because as via USB it takes up space.
  • #18 15567790
    sylweksylwina
    Help: 1882
    Rate: 2355
    I understand that you mean to seize the usb port? Maybe it was a problem in the past when there were 2 usb ports on the rear panel, but not when we have 6-8 usb ports.
  • #19 15568189
  • Keyboard ghosting on cheap keyboard blocks Alt+Shift+S
    #20 19281343
    Johnny_Cage
    I will give the answer because maybe someone else will have this problem.
    Your keyboard has a problem with ghosting (due to the way the keyboard is constructed, after pressing several buttons at once, the keyboard stops sending subsequent buttons. Some combinations allow you to press 5-6 at the same time, but e.g. l-alt, shift do not allow you to read the s character) the problem is directly the cheap keyboard.
    https://drakeirving.github.io/MultiKeyDisplay/
    Here you can test how ghosting works.
    The only solution that would not require some strange binding itself to e.g. numpad is to buy a new keyboard
The user is experiencing an issue where the key combination of left Shift + right Alt + S does not produce the expected output of "Ś" in any program, while the combination of right Shift + right Alt + S works correctly. Various responses suggest checking keyboard language settings, specifically ensuring it is set to "Polish - Programmers," and verifying if any background programs are using hotkeys that might interfere. Some responses indicate that the problem could be due to keyboard ghosting, a limitation in cheaper keyboards that prevents multiple key presses from being registered simultaneously. Recommendations include testing with a different keyboard and considering the purchase of a higher-quality USB keyboard to resolve the issue.
