HP 2920-24G Switch (J9726A) & POE Camera: Achieving 160-170m Distance with FTP Twisted Pair
tomrom1985 22281 22
Can I connect a PoE camera 160–170 m from an HP 2920-24G switch over FTP twisted pair, and if not, what is the best way to extend the link?
A single 160–170 m PoE/Ethernet run is beyond the normal 100 m limit, so it is not a guaranteed solution; some people reported longer runs working in practice, but others warned that power may still work while data becomes unreliable [#15551153] [#15550173] [#15548354] The safest approach is to split the link into two Ethernet segments of up to 100 m and place a PoE extender/repeater or PoE-powered switch in the middle, such as the BCS-xPoE4/EXT module [#15541357] If you want to try a passive cable-only setup, use a good-quality cable and expect that it may still need an expander if the camera does not sync or loses packets [#15541311] [#15549558] Shielded/gelled cable can help with interference in harsh outdoor conditions, but it does not increase the allowed Ethernet distance [#15551153] [#15549659]
  • #1 15541087
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    Hello. A question for specialists - I want to add a camera to my monitoring, which will observe the entrance gate. The distance from the HP 2920-24G SWITCH (J9726A) is approx. 160-170m. I wonder if in this case the 100m / switch / 100m / switch principle should be used as well as in computer networks. Of course, these are only standards and it all depends on the conditions. I could use an ftp twisted pair. Possibly how else to fix this problem. I haven't chosen the camera yet.
  • #3 15541311
    zuczek1987
    Help: 63
    Rate: 80
    It all depends on the hardware. The standard says 100 meters because POE comes from structured cabling. However, life already speaks differently. In the department, installations where there were 130 meters and worked, but also those with a problem at 70 meters, I also saw a problem. However, 160-170 is definitely an exaggeration. Well, probably you will use a repeater and choose the power accordingly.
  • #5 15541357
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    Above 100m, you can use the BCS-xPoE4 / EXT - 4-port PoE switch, 4x FE ;)
    The xPoE4 / EXT module, which is a 4-port PoE-powered network switch. To ensure the operation of the camera - 200m of UTP cable is divided into two sections of 100m and we use xPoE4 / EXT to connect them. We do not need a local power supply in the place where the module is installed. The xPoE4 / EXT module works with 802.3at, 802.3af and passive PoE switches
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #6 15542136
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    NV-208S / P + a bit expensive solution. The BCS-xPoE4 / EXT proposition is cheaper - as far as I know, Cisco also has such a solution. Let me know what I have decided and how it works. Additional question, if I can do tasks in this thread, what external camera should I use to monitor the gate. Requirements - the ability to read the registration number. If the driver could also be grasped, it would be great. Day / night camera - color, distance from the gate is about 10m. The mounting height is yet to be determined. I will use a tin pole for this purpose. About 7m high
  • #7 15542171
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    tomrom1985 wrote:
    which external camera to use to monitor the gate.
    Are you asking about the company or the exact model?
    How much do you want to spend on a webcam?
    OMNI-SAT
  • #8 15542181
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    I am asking for specific models. How much do I want to spend? I will not say that as little as possible because that is not the point. I think that the maximum cost for the camera is 1000 PLN.
  • #9 15548354
    bohunmike
    Rate: 32
    I can honestly tell you that PoE is an electrical signal, I used a twisted pair category 7 at 150m and a PoE power supply + continuous camera 8W with IR and Lan fastened to 100 Mb / s (average is 9
    In decline on 100m cat. 5)
  • #10 15548361
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    I will probably do this by pulling the cable first and checking if it will be OK, and if something does not work, I will add an expander. I have already found out that it all depends on what cable and what is in the vicinity. Power cables don't help :-)
  • #11 15548393
    bohunmike
    Rate: 32
    Correct approach, let me know how and how it turned out.
  • #12 15548399
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    I'll let you know. I just don't know when because I've been running out of time lately. I think maybe a month.
  • Use 50 V over two pairs with local 12 V conversion
    #13 15549558
    Arbiter
    Rate: 101
    I would try to do it differently: power, let's say 50v, as we know, the current will be smaller, so the drops in resistance will be smaller. Of course, let go in two pairs. And in front of the camera itself, there are step down converters to 12V. This should solve the power problem. Alternatively, if it does not work, i.e. it does not catch the protection signal, the twisted pair should only release the ethernet and the power supply on an ordinary current cable to the ground. I would not make a repeater on the way because it will be an emergency solution I mean water, frost and general erosion of connectors and devices
  • #14 15549575
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    If I mount the expander, I will do it in a hermetic box. I want to keep the number of wires pulled to a minimum. Of course, the idea of raising the voltage and then stabilizing to the expected value is also OK, only ..... it is all about synchronization and here I would be afraid of failure the most
  • #15 15549593
    Arbiter
    Rate: 101
    Overall you have to take a chance. You should buy the cable anyway, black, ie gelled to the ground or to the air. It will not be of a good category, i.e. it will not be cheap. But I would prefer a more expensive cable than enclosing the equipment in a muffle
  • #16 15549659
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    This is the cable I bought. Gelled, screened due to the conditions that may prevail.
  • #17 15550173
    treborsz
    Industrial cameras specialist
    Help: 124
    Rate: 240
    Have your colleagues considered the issue of packet loss when transmitting over non-standard distances?
    Did colleagues consider the fact that the camera can be effectively powered in PoE technology and data transmission will be impossible? It seems to me that the topic of this thread is detached from reality (considering whether the rocket will reach another galaxy, but ... without taking into account that the cosmonaut in this rocket will no longer be alive ...).
    Arbiter wrote:
    if it does not work, i.e. it fails to synchronize, then use the twisted-pair cable to turn on the Ethernet itself
    tomrom1985 wrote:
    this is all about timing, and that is where I would fear failure the most
    I must admit that I was interested in these statements about synchronization in Ethernet. Can my colleagues explain what this synchronization is about, what is synchronizing?
  • #18 15550369
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    For me, the term synchronization specifically in this topic is the correct transmission of the vision to the recorder. I'm going to put the whole shielded cable in and see what happens. If there is a problem, I will add expanders. The topic may be helpful for others who want to connect equipment over a long distance. I will. He experimented but others will have clear paths :-)
  • #19 15551153
    treborsz
    Help: 124
    Rate: 240
    A very original definition ... It indicates an innovative approach to the existing reality ... :D
    A commendable intention, however ...
    First of all - I suggest checking / reading what all types of screens are used for in cabling.
    Second - does the use of a shielded cable extend the transmission range in computer networks?
    Please also read about the mounting recommendations for the installation of a shielded cable.
    tomrom1985 wrote:
    The topic may be helpful for others who want to connect equipment over a long distance. I will. He experimented, but others will have clear paths :-)
    I sincerely wish you successful conclusions in the experiments! Let me just mention that countless researchers have experimented in the past, which results in adopted standards. In short: for category 5 or higher twisted-pair cable, the appropriate transmission quality is ensured over a distance of up to 100 meters.
  • #20 15551182
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    I know what the screen is for and I am aware that it will not extend the range, but I am already saying why I want to put it on. Well - in my existing installation - the unshielded cable from the managed switch goes straight to my apartment and is connected to the router. Since then, it has started to disturb me terribly with the radio in the technixa tower, which is about 4m away from the router. At first, I thought that it was the power supply that started to sow - replacing it with another one did not help. Only after a moment of reflection did I check that when I disconnect the twisted pair, the radio starts to play quietly again. In this way, I put another shielded cable next to it, along with shielded rj (adds it, so I wouldn't forget it). Result - my favorite station sounds clean. When I scan the VHF band, I still look for these specific interference somewhere. The disturbances arise from the fact that I have everything on an unshielded twisted pair located in electrical conduits in the vicinity of countless power cables and other installations. To sum up - shielded cable is placed in order to minimize interference. Unfortunately, I didn't do it at the very beginning, but I covered utp cat.6. PS. the mentioned section from the switch to the router is about 35m of cable. I am not a specialist in the subject of CCTV, I learn from my own and others' mistakes. I appreciate the constructive criticism and thank you for it.
  • #21 15552335
    NTI-NT
    Rate: 8
    Home Switch TP-Link TL-SF1008P ---- Twisted pair Cat 6 .------- Camera BCS-TIP5200IR IP 2MPX 1080P IR 20M at the end, and all this on a 196 m twisted pair works without any problems.
    In the middle of the line, if necessary, there is a switch for the switch, but not used because why, so let no one say that POE is 80 m because I will not believe it, anyway, here I was also surprised that it works, even with such a switch.
  • #22 15552493
    treborsz
    Help: 124
    Rate: 240
    I suggest that my colleague @ NTI-NT submit a protest note to TP-Link, the producer of the TL-SF1008P network switch. TP-Link clearly misleads its customers by saying that the length of the UTP / STP cable cannot be longer than 100 meters! This is reported in catalog card (for the inquisitive: page 3, Network Media (Cable) item).
    The protest note should also be sent to the organization for information IEEE because in their standards (e.g. IEEE 802.3af ) post heresies that were irrefutably refuted by one of the forum members of the elektroda.pl portal! In addition, the document is not available for free for readers who want to confront the nonsense contained there with reality! :D
    It's so jokingly - I am asking the moderator for understanding (I could not resist, although I reckon with the fact that the post may end up in the trash as harmful to impatient readers who will read only the first paragraph of this post) and possible readers who will treat the above text seriously.
    Now seriously. I strongly agree with my colleague @ NTI-NT's indignation about limiting the PoE supply distance to 80 meters. You can successfully power a device (e.g. an IP camera) consuming 6W (PoE Class 2) from a PoE power source (PSE 50VDC / 15W, using 4 pairs) away from this source for ... 900 (nine hundred) meters.
    However, as I wrote earlier in one of the posts - PoE power range should not be considered in isolation from the quality of transmission via the same data cable in Ethernet technology:
    treborsz wrote:
    Have colleagues considered the fact that the camera can be effectively powered in PoE technology and data transmission will be impossible? It seems to me that the topic of this thread is detached from reality (considering whether the rocket will reach another galaxy, but ... without taking into account that the cosmonaut in this rocket will no longer be alive ...).
    Moderated By suworow:
    As far as my memory is correct, the regulations forbid mockery and malice, but does not mention anything about substantive statements kept in a playful tone, which our colleague from time to time regrets us. Regards
  • #23 20967741
    Tabeusz
    It`s actually a UPT plug, camera -Switch 150m, Switch-Recorder 150m, total 300m, this is a gel in the ground option.
The discussion revolves around connecting a POE camera to an HP 2920-24G Switch (J9726A) over a distance of 160-170 meters using FTP twisted pair cabling. Participants share experiences and solutions regarding the limitations of POE, which typically supports up to 100 meters, and suggest using repeaters or specialized switches like the BCS-xPoE4/EXT to extend the range. Some users report successful installations beyond the standard limits, citing the use of high-quality cables (e.g., Cat 6, Cat 7) and proper power management techniques. The conversation also touches on the importance of shielding to prevent interference and packet loss, as well as the need for suitable camera models that can capture license plates from a distance of about 10 meters.
TL;DR: A 196 m Cat 6 run powered a 2 MP IP camera flawlessly [Elektroda, NTI-NT, post #15552335]; still, experts warn “it all depends on the hardware” [Elektroda, zuczek1987, post #15541311] PoE generally stays reliable up to 100 m per IEEE 802.3af.
Why it matters: Knowing the real-world limits lets you budget for extenders, avoid packet loss, and pick the right cable first time.
• IEEE 802.3af/at specify 100 m maximum channel length (90 m horizontal + 10 m patch) [IEEE 802.3af]. • BCS-xPoE4/EXT extender doubles reach to 200 m without local power [Elektroda, Fotodetektor, post #15541357] • Field report: 196 m Cat 6 link + TL-SF1008P switch works error-free [Elektroda, NTI-NT, post #15552335] • Voltage drop: 48 V feed loses ~3 V over 100 m of 24 AWG copper [Cisco, 2023]. • Typical extender cost: ~130 PLN (€30) per unit (Morele.net).
What distance does the PoE standard guarantee?
IEEE 802.3af/at guarantee reliable power and 100 Mbps data up to 100 m of channel length, including patch cords [IEEE 802.3af].
Which devices extend PoE beyond 100 m?
Mid-line switches like BCS-xPoE4/EXT or Cisco Catalyst Extend operate as PoE repeaters. They split the link into two ≤100 m segments and draw power from the first segment, so no local PSU is needed [Elektroda, Fotodetektor, post #15541357]
How much power is lost over long copper runs?
48 V over 100 m of 24 AWG copper loses about 3 V (6 %); at 200 m the drop doubles, risking Class 3 devices [Cisco, 2023].
Which <1000 PLN camera captures plates at 10 m?
Models like Hikvision DS-2CD2T46G2-IU (4 MP, IR 60 m) or Dahua IPC-HFW2431T-AS-S2 fit the budget and offer 2.8–12 mm varifocal lenses needed for plate legibility (Hikvision, 2024).
How should I test a long PoE link?
  1. Pull the permanent cable. 2. Connect camera directly to switch; monitor link speed and packet error counters for 24 h. 3. Verify night IR current draw; if errors appear, insert an extender [Elektroda, tomrom1985, post #15548361]
What cable suits long outdoor runs?
Use gel-filled, UV-resistant Cat6 F/UTP rated for burial or aerial spans; shielding limits EMI from nearby power lines [Elektroda, tomrom1985, post #15549659]
What failure symptoms show the link is too long?
You may see random video freezes, dropped packets, or a link that powers the camera but never establishes Ethernet sync [Elektroda, treborsz, post #15550173]
How do I install a PoE extender?
  1. Cut the run into two ≤100 m segments. 2. Crimp RJ-45 plugs and insert the extender between segments. 3. Re-test link; LED should show PoE passthrough and 100 Mbps. ‘Three steps, five minutes’ says installer Fotodetektor [Elektroda, Fotodetektor, post #15541357]
Is higher-voltage feed with local step-down safe?
Yes, bumping to 50 V reduces current and voltage drop; a DC-DC converter at the camera can then supply 12 V. Ensure converters are rated for outdoor use [Elektroda, Arbiter, post #15549558]
Does packet loss rise even if PoE power is solid?
Yes. Attenuation and return loss climb with length, degrading the eye diagram. Power LEDs may glow while TCP retransmissions soar, killing video [Elektroda, treborsz, post #15550173]
Has anyone pushed PoE to 300 m?
A forum user chained two 150 m segments via an intermediate switch buried in gel cable, achieving 300 m total, but long-term reliability remains unverified [Elektroda, Tabeusz, post #20967741]
What does a PoE extender cost?
BCS-xPoE4/EXT lists at approx. 130 PLN, under 10 % of a mid-range IP camera budget (Morele.net, 2024).
