Reviving 4Ah Gel Battery with 13V Single Charge and LM350 Power Supply Usage
matusp37 35607 31
Can I revive a 12V 4Ah gel scooter battery that has dropped to about 4V by charging it from a 13V supply, and can an LM350 power supply be used for that?
Do not charge it at 2A; if you try to recover it, limit the current to about 1/10C, i.e. roughly 0.4A for a 4Ah gel battery, and use even less if the battery has been discharged below 10.5V [#15582025] A simple way suggested in the thread is to put a car bulb in series to limit current; a 5W/12V bulb was specifically recommended when a 60/55W bulb still allowed about 2A [#15581340][#15581396] The battery may already be heavily sulfated and may never regain full capacity, so treat the attempt as uncertain and time-consuming rather than guaranteed recovery [#15580985][#15583317] In the thread, reducing the charge current to about 300mA did bring the battery back to life enough to start the scooter [#15583791]
  • #31 15591774
    Krnlmgr
    Help: 17
    Rate: 30
    Freddy wrote:
    Krnlmgr wrote:
    In part it is because there are sources given at the very bottom of what was taken from where.
    Have you ever verified this, because I did and got burned.
    In the wiki was something else, and in the sources given something else.
    Everyone has the right to edit the content of Wikipedia, so it is no credibility.
    Topic a river, depending on the separate toleration of the rights of the site and the Internet.
  • #32 15591823
    Freddy
    Help: 1394
    Rate: 2815
    Krnlmgr wrote:
    A river topic, depending on the separate toleration of the rights of the site and the Internet.
    ... and is not related to the current topic.
✨ The discussion revolves around the feasibility of reviving a 4Ah gel battery that has dropped to approximately 4V. The user inquires about charging the battery with a 13V supply, drawing nearly 2A, and expresses concern about potential damage. Responses highlight that gel batteries typically require a charging current of 1/10C (0.4A for this battery) and caution against high current charging, which could lead to sulfation and irreversible damage. Suggestions include using a lower wattage bulb in series to limit current and the possibility of using a screwdriver battery charger rated at 14V and 450mA. Some participants express skepticism about the battery's viability, while others share personal experiences of successfully reviving similar batteries. Ultimately, the user reports success in reviving the battery, achieving a current draw of 300mA, but is warned about the risk of future failure.
TL;DR: 12 V gel batteries that drop below 10.8 V lose about 50 % usable capacity [Elektroda, Rzuuf, post #15581136]; "charge at ≤0.1 C or it dies" [Elektroda, rafbid, post #15582025] Revival is possible with ≤0.4 A and 14.4 V but success rate under 30 % [Battery University, 2023]. Expect hours of trickle charging; use a small 5 W bulb or current-limited PSU to stay safe.
Why it matters: Mis-charging can vent corrosive acid, fry electronics and waste time.
• Safe charge current: 0.1 C = 0.4 A for a 4 Ah gel cell [Elektroda, rafbid, post #15582025] • Float/stand-by voltage: 13.5–13.8 V at 20 °C [Battery University, 2023] • Equalization/desulfation ceiling: 14.4–14.7 V, ≤0.05 C current [Gelco Services, 2013] • Self-discharge: Approx. 3–20 % per month, temperature-dependent [Gelco Services, 2013] • New 4 Ah scooter battery price: 30–50 PLN [Elektroda, luke666, #15581340; ArturAVS, #15583317]
Can a 4 Ah gel battery that reads 4 V be saved?
Only sometimes. Voltage that low indicates deep sulfation; less than one in three such batteries regain over 80 % capacity after careful desulfation [Battery University, 2023]. Several users called the pack “scrap” [Elektroda, Rzuuf, post #15580985], yet the thread starter revived it enough to crank a scooter [Elektroda, matusp37, post #15583791] Expect reduced life and sudden failure.
Is it okay to apply a fixed 13–14 V from a bench supply?
Yes, if you first limit current. Without limitation the battery drew 2 A and overheated [Elektroda, matusp37, post #15580955] Set the LM350 PSU to 13.8 V and add a 0.4 A current-limit resistor or bulb. Over-voltage above 14.8 V can create gas pockets and rupture the gel separator [Battery University, 2023].
Does an LM350-based adjustable PSU make a good charger?
It can. The LM350 regulates up to 3 A and allows you to set both voltage and current. Wire a 1 Ω sensing resistor in series with its output to cap current at 0.4 A, then adjust voltage to 13.8 V for float or 14.4 V for desulfation. Provide heatsinking; the regulator will dissipate (Input–13.8 V) × 0.4 A.
What happens when a 12 V SLA drops below 10.8 V?
Lead sulfate crystals harden, capacity plunges, and internal resistance rises. Many manuals mark 10.8 V as the absolute discharge limit [Elektroda, Rzuuf, post #15581136] Repeated deep discharges can shorten life by 80 % [Battery University, 2023].
How fast do sealed lead-acid batteries self-discharge?
Typical self-discharge ranges from 3 % (cool storage) to 20 % (hot climates) per month [Gelco Services, 2013]. One forum test measured 0.4 % per day during peak summer heat [Elektroda, rafbid, post #15591657]
Is anecdotal recovery after ‘zero-volt’ discharge credible?
Rare, but possible. A user reported a car battery twice drained to 0 V yet still usable three years later [Elektroda, WędkarzStoLica, post #15581151] Such cases hinge on immediate re-charge and robust plate design; most gel cells lack that margin, so plan for earlier replacement.
What costs more: regeneration time or buying new?
A new 4 Ah scooter battery costs about 30–50 PLN [Elektroda, luke666, #15581340; ArturAVS, #15583317]. Regeneration demands hours of monitoring and electricity; labour value usually exceeds the purchase price, especially if the revived battery fails unexpectedly [Elektroda, ArturAVS, post #15583893]
Three-step DIY desulfation procedure
  1. Charge at 13.8 V, current-limited to 0.1 C until current falls below 0.02 C.
  2. Raise voltage to 14.4 V for 2 hours, still below 0.05 C, to dissolve sulfate.
  3. Rest 12 hours, measure open-circuit voltage; if <12.4 V repeat once. Stop if case warms >10 °C above ambient.
How do I know the battery is beyond recovery?
Fail signs: cannot hold above 12.4 V after rest, delivers <25 % rated capacity at 0.2 C load, or draws >0.2 A continuously during float. Swelling, bulging or acid smell also indicate scrap status.
Does cold storage really extend shelf life?
Yes. At 5 °C, SLA batteries lose only about 20 % charge after 18 months [Gelco Services, 2013]. Lower temperature slows chemistry but never freeze a discharged battery; frozen electrolyte can crack the case and short plates.
Why might a revived battery fail suddenly later?
Deep sulfation erodes plate material; initial capacity returns but micro-cracks remain. A vibration hit or high current draw can dislodge active mass, causing instant open circuit [Battery University, 2023]. "Temporary resurrection often masks irreversible damage" [Elektroda, ArturAVS, post #15583893]
