Charging 6V 12Ah Gel Battery: Comparing 5.7V 800mA vs 7V 800mA Chargers, Safety & Efficiency
dziamber007 13683 9
Can I safely charge a 6V 12Ah gel battery with a 5.7V or 7V 800mA charger, and which one is better?
The 7V charger is the better choice, but it may still not fully charge the battery; 5.7V is likely too low to charge it properly [#16964216][#16964310] The battery’s own data says it wants about 7.20–7.50V for cyclic charging and 6.75–6.90V for standby, so the charger voltage is the main issue, not the 800mA current [#16964467][#16976899] An 800mA charge current is within the battery’s 3.6A maximum and is also below the usual Q/10 rule for a 12Ah battery (1.2A), so it is conservative from a current standpoint [#16976899][#20370795] Because these chargers may not be designed for gel batteries, you should watch the battery with a meter and stop around 7.2–7.25V; if you keep forcing charge past that point, the battery can gas and lose efficiency [#16964467][#16964645] If the 7V charger’s real output is closer to 7.4V, it would be better still [#16964216]
  • #1 16964199
    dziamber007
    Hello. Is it possible to charge a 6V 12Ah gel battery with a 5.7V 800mA or 7V 800mA charger? If so, which one will be better? Is it safe for the battery? I am asking because I have such chargers at home.
    The battery has the following information:
    Rechargeable gel battery
    Charging voltage characteristics:
    7.20V - 7.50V cyclic operation
    Standby 6.75V - 6.90V
    Maximum charging current 3.6A
  • #2 16964216
    spinacz
    Help: 1206
    Rate: 2658
    The 7V charger is the closest one, but it would be good if you were charging with a 7.4V power supply.
  • #3 16964310
    k9mil
    Help: 23
    Rate: 16
    Simply a 7V charger will not charge this battery fully and that's it.
  • #4 16964426
    dziamber007
    From what I know, batteries do not fully charge, only preferably 80% to extend its life. So the 7V power supply is too weak and I was afraid it might be too strong. At alledrogo they sell chargers for gel batteries and described e.g. output 6v 800mA so according to the description on the battery (that you should charge with 7.20-7.50V) is also not suitable. My someone has 12aH and charges with a value of 0.1A from the amount of aH (I found this information on the forum but I don't have the knowledge to confirm it), so I conclude that the best power supply would have 7.35V 1.2A but probably 7V 800mA will also charge only that longer?
    The second case the 7V 800mA charger is original from an old screwdriver that had 10.8v 1.3aH li-ion batteries. So when I saw that, I was stupid at all.
  • #5 16964467
    adamGazda
    Help: 10
    Rate: 24
    Theoretically, it can be charged with a 7 V charger. The gel battery from the theme (has three cells) and is a lead battery, so it is different from those for which the charger was intended. It can be easily assumed that the battery charger has a final charging voltage of 12.5 V (also three cells). It's too much for the gel battery from the subject. Personally, in order to check if it could be charged, I would connect the charger to the battery and use a multimeter to check if the charging current does not exceed the nominal current of the charger (800 mA). If the current does not overload the charger, I would periodically check the voltage increase on the battery being charged (with the charger connected and working). After reaching a voltage of 6.9 - 7.20 V, the battery can be approximately considered to be fully charged. Depending on how the battery was discharged and what is its actual capacity (new or used battery?), The charging process with this charger may vary from a few minutes to even a dozen or so hours. The final conclusion - it can be recharged but you have to make sure that something doesn't burn or when you finish charging. The battery, when it is charged and is being charged further "by force", loses its efficiency because the electrolyte density and volume change by accelerated decomposition of water into hydrogen and oxygen, which gases are irretrievably released into the atmosphere.
    You can try this second 5.7 volt charger. Often, the chargers' voltages are given as conventionally accepted for various types of batteries and do not reflect the real values that the charger achieves, i.e. it should be experimentally determined (measurements by means of a current and voltage meter) whether charging will begin at all and if so, as before or not charger current and at the end of charging does not overcharge the battery or vice versa can not be able to fully charge?
  • #6 16964509
    dziamber007
    As I wrote earlier, the charger is 7V 800aH originally from 10.8v 1.3aH Li-ion batteries. After charging the battery from the screwdriver, the green LED was on and the red LED was off.
  • #7 16964645
    adamGazda
    Help: 10
    Rate: 24
    The diodes signaling the charger were working with original lithium batteries - now there is nothing to count on. Often, chargers use the ?V function, which detects a slight voltage drop at the end of the charging period, and lead batteries show quite large voltage fluctuations throughout the entire charging process, which can confuse the charger and turn off sooner than needed. Let's assume that both chargers will charge (the ?V function will not disturb), so that you do not overcharge the battery, you need to assess for yourself whether it is already charged or not. Preferably by measuring the voltage quite often with a meter, details as I mentioned in post No. 5. However, there is a risk that we will miss the moment of charging the battery because it is not known to what extent the discharge is connected and how much time the charger needs at its performance to charge it. If we do not stop charging in time it will be to the detriment of the battery.
    This charger with lower voltage gives some hope, but the charging process must be carried out experimentally and conclusions should be drawn. Try and write what came out. I will add that chargers may react to an uncertain connection with a battery by lighting a diode indicating the end of charging. For this reason, we measure the current at the beginning only to assess whether the charger is charging too high current and then connect the cables securely and only make the voltage measurements until the battery reaches the final charging voltage. If it reaches 6.9 V, we start to observe the voltage more often. If it exceeds the value of 7.2 V, we strongly increase vigilance and if it continues to increase, the final limit is 7.5 V. Personally, I would stop charging at 7.25 V with the conviction that the charger, unfortunately, does not turn off automatically and you need to finish charging yourself.
  • #8 16972103
    dziamber007
    One more question: what current should one charge two 6V 12Ah connected in series which have 12V 12Ah after short circuit? I mean voltage how many volts and how many amps? Because I have two and I could load them simultaneously.
  • #9 16976899
    adamGazda
    Help: 10
    Rate: 24
    dziamber007 wrote:
    what current should be charged with two 6V 12Ah connected in series which have 12V 12Ah after short circuit
    The principle adopted by convention is: charging current = Q / 10 - what is meant by the capacity of the battery being charged divided by 10, i.e. in this case we have 12 Ah / 10 = 1.2 A. Everything is clear if the charger has the ability to set the charging current. If it gives less - charging will take longer. If the charging current is greater than 1.2 A, then the charging will be shorter, but unfortunately it affects the battery life and especially when we exaggerate with the charging current because the high current density heats the active mass of the battery plates locally and can also cause strong point gassing the active mass peels off the surface of the lead mesh that forms a current drain from the battery plate.
    When it comes to the final charging voltage, it is obvious that by connecting two 6 V batteries in series we double the values applicable for a single six-volt battery and we get:
    - voltage close to the end of charging 6.9 V * 2 = 13.8 V (from this moment we control the voltage increase on the battery pack more often)
    - 7.2 V * 2 = 14.4 V is the final charging voltage. At this voltage, the charging current should already be much smaller and approach zero. If the charger itself does not reduce the current, then the voltage will continue to increase and depending on the parameters of the charger it can reach 18 to even 24 V but this means that the battery has already been partially or completely destroyed by too long and too intensive charging. In cars, damage to the voltage regulator can lead to an increase in voltage up to 60 V and sometimes above 100 V (alternators are very efficient), unless the engine driver is damaged.
    Therefore:
    It is better to charge with a current less than or equal to Q / 10
    Do not allow the battery to overheat during charging.
    Do not overcharge the cells, i.e. turn off the charging in time or use the charger with efficient automation and designed only for this type of battery.
    The final charging voltage can vary depending on the condition of the battery by a few tenths of a volt up or down. Thus, the values given above are helpful but do not specify conditions for all lead-type batteries.
    If you want to expand the topic of charging two batteries in series or in parallel.
  • #10 20370795
    azaghorth
    Rate: 12
    Usually the batteries are charged with q/10, where q is the battery capacity. Example: a 12Ah battery is charged with 1.2A for 10h, or with 2.4A for 5h...and so on. So, when charging a battery not only the voltage of the charger matters but its current too.
The discussion centers on the feasibility and safety of charging a 6V 12Ah gel battery using either a 5.7V 800mA or a 7V 800mA charger. It is noted that the 7V charger is closer to the required charging voltage of 7.20V - 7.50V for optimal charging, but it may not fully charge the battery. Concerns are raised about the potential for overcharging, especially since the 7V charger is originally designed for lithium batteries, which may not be compatible with the charging characteristics of lead gel batteries. Users suggest monitoring the charging process with a multimeter to ensure the current does not exceed 800mA and to check the battery voltage regularly. The ideal charging current is discussed as being approximately 1.2A for a 12Ah battery, emphasizing the importance of using a charger that can provide the appropriate voltage and current without risking battery life.
