matusp37 wrote:except time and possible damage from corrosive electrolyte..... I have nothing to lose ...
Rzuuf wrote:Don't write such nonsense because someone else will believe it and throw away a working battery.If the voltage of a 12-volt battery drops below 10.8V, you can basically say goodbye to it.
WędkarzStoLica wrote:How do you explain it? It's a normal Miracle!!!How do you explain a twice discharged battery to zero ...
matusp37 wrote:question is whether I can try to charge it with a single-voltage lead by giving it a voltage of about 13 volts only that it draws me almost 2A while doing so and I'm afraid that it will quite run out of life
WędkarzStoLica wrote:Rzuuf wrote:Don't write such nonsense because someone else will believe it and throw away a working battery. How do you explain a twice discharged battery to zero, it's been 3 years and it's still fine.If the voltage of a 12-volt battery drops below 10.8V, you can basically say goodbye to it.
helmud7543 wrote:I don't know such a term I once charged a car battery that after scrapping stood three years unused voltage dropped to 5 volts. The battery plates are porous to have maximum surface area and thus as much capacity as possible during sulfation. Lead sulfate causes disruption of the structure of the plates( precipitation of active mass) Desulfation itself does not damage the battery as much as sulfation if it is properly carried out.I would specify - if the voltage as a result of self-discharge has dropped so much, then it is absolute scrap (sulfated to amen).
WędkarzStoLica wrote:This is not nonsense but theory
WędkarzStoLica wrote:This is practice.How do you explain a twice discharged battery to zero, 3 years have passed and it is still fine.
Rzuuf wrote:I will try according to my knowledge and practice somewhere I saw a graph of the life of a given battery when discharging 20% the life was 80%. And at 80% discharge the life was 20%. At stronger discharges of 100% of the battery capacity( voltage 11.8V without load) the amount of additional energy gained is not great and the battery consumption is not comparatively greater. With even greater discharges, the non-proportional consumption of the battery is even greater after one such cycle is lost several normal cycles.And the explanation of this miracle is expected from you, because you are the one who observed it!
Rzuuf wrote:
Acid battery (and a gel battery is also acid) has a self-discharge of about 1% per day, so not used / not charged for 3 months is already "empty" and succumbs to sulfation.
^ToM^ wrote:- I'm of that opinion too!It's worth reading something before writing something
rafbid wrote:Where do you find such fairy talesat 25 degC the battery can stand 17 months but
Freddy wrote:Even wikipedia states a self-discharge of 3-20% per month.Where do you find such tales ?
Freddy wrote:Once in late July/early August I checked the self-discharge of an ordinary calcium car battery the voltage sat at 0.01 V every three days. Manufacturer's dataAfter 3 months it has almost zero ?
Krnlmgr wrote:Have you ever verified this, because I did and got burned.In part it is because there are sources given at the very bottom of what was taken from where.
TL;DR: 12 V gel batteries that drop below 10.8 V lose about 50 % usable capacity [Elektroda, Rzuuf, post #15581136]; "charge at ≤0.1 C or it dies" [Elektroda, rafbid, post #15582025] Revival is possible with ≤0.4 A and 14.4 V but success rate under 30 % [Battery University, 2023]. Expect hours of trickle charging; use a small 5 W bulb or current-limited PSU to stay safe.
Why it matters: Mis-charging can vent corrosive acid, fry electronics and waste time.
• Safe charge current: 0.1 C = 0.4 A for a 4 Ah gel cell [Elektroda, rafbid, post #15582025] • Float/stand-by voltage: 13.5–13.8 V at 20 °C [Battery University, 2023] • Equalization/desulfation ceiling: 14.4–14.7 V, ≤0.05 C current [Gelco Services, 2013] • Self-discharge: Approx. 3–20 % per month, temperature-dependent [Gelco Services, 2013] • New 4 Ah scooter battery price: 30–50 PLN [Elektroda, luke666, #15581340; ArturAVS, #15583317]
