Small compressor for cleaning / blowing - instead of compressed air
KSRhaziel 39936 19
Is a small compressor without a tank suitable for cleaning and blowing out computer equipment, or should I buy one with a tank instead?
That Stanley Air Kit can be used for occasional dusting of a laptop or similar light tasks, but it is noisy, weak in continuous blow mode, and not very convenient; for proper cleaning of computer equipment a compressor with a tank is the better choice [#20721666][#15614597] Users note that an oil-free unit is important for electronics, but tankless designs make the motor run all the time and the airflow drops if you keep the trigger pressed [#15614597][#20721666] One owner reported that it is limited to about 1.5 minutes of continuous use followed by 8 minutes of rest, and that the hose can be a weak point [#20721666] For more serious dust removal or dirty PCs, contributors recommend a compressor with a cylinder/tank, at least 5 L, and preferably around 25 L if mobility is not needed [#15622939][#15673539] If you only blow out equipment occasionally and can tolerate the noise, it will do; if you want comfortable and effective cleaning, buy a tanked compressor instead [#15616805][#15622939]
  • #1 15613760
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    Due to the frequent need to clean / blast equipment (mainly computer equipment), I am thinking of replacing the compressed air with a small compressor. Yes, I know that the topic has been discussed many times on the electrode - the topics are from 2011, 2014, etc. Also, google returns a lot of results, but mainly just different tips.
    I have read both the electrode topics and google results, and I already have my own thoughts. Now I would like to ask you for specific advice. What do you think about this compressor (intended for cleaning / blowing):
    Stanley Air Kit - http://www.ceneo.pl/37515304
    Has anyone used it and can say if it will work in such a role?
  • #2 15613834
    Tommy82
    Help: 455
    Rate: 1074
    If you go to the workshop statically, it's better to have something bigger with a tank.
    I have some kind of made in china in the basement with a tank, a dehydrator / oil separator, a gun with a longer lance, when it blows, it is strength, and in the basement it is gray with dust.
  • #3 15614276
    zdzisiek1979
    Help: 563
    Rate: 1256
    The description says that it is without a tank. It's probably a wheel pump rather.
    From the small ones, I used to watch the Stanley 5l, small, portable and it had a blower :D it was only a little loud.
  • #4 15614597
    ^ToM^
    Help: 495
    Rate: 2939
    We have one, oil-free - which is important for electronics and apart from the fact that it makes noise, it is a nice and handy solution.
    I think that the one you indicate in the link will be equally good for this application. Well, it's only worth paying attention to the noise. These devices are quite loud by nature, so as much as 1-2dB difference is worth the higher price. Colleagues pay attention to the tank to be larger. It is completely unnecessary for blowing out and simple work.
    Cheers!
  • #5 15616805
    bratyslaw
    Help: 35
    Rate: 98
    I would just like to confirm the above statement of my colleague ^ ToM ^ - I have had such a compressor for 9 years, it is relatively light and easy to carry. It is enough for pumping the wheels and blowing it out. If there is a need to obtain a temporarily greater blast, it is enough to press the trigger of the gun every few seconds so that the air spring in the hose. Disadvantages: noisy and rides on the floor when working in an upright position.
    Greetings!
  • #6 15622939
    rubens
    Help: 209
    Rate: 301
    Cheers!
    You probably haven't dealt with a really dirty computer.
    Such equipment is a toy with a capacity slightly greater than that of compressed air in an aerosol.
    For cleaning electronics with a lot of dust, only equipment with a bottle of min. 25 liters.
    Unless there is only one piece of equipment to be cleaned once in a while and we have a lot of patience and free time.
    I have friends who deal with computer service and they also used to have such toys - after a few months they changed it to a classic compressor with a cylinder.
    Professionally, a nitrogen cylinder is used for cleaning and blowing.
  • Portable compressor works for dusty electronics despite frequent cycling
    #8 15628367
    ^ToM^
    Help: 495
    Rate: 2939
    Such equipment is a toy with a capacity slightly greater than that of compressed air in an aerosol. For cleaning electronics with a lot of dust, only equipment with a bottle of min. 25 liters. Unless there is only one piece of equipment to be cleaned once in a while and we have a lot of patience and free time.
    I am writing from my own experience. For most applications, even in the case of extremely dirty printers or copiers, just such a portable compressor is sufficient. It just turns on more often than a compressor with a 25 L shoe. In the practice of dust removal, however, it does not matter at all.
    Cheers!
  • Assessing compressors for occasional PC cleaning and inflation
    #9 15672286
    Robinson74
    Rate: 159
    The topic for me is on time.
    I do not know if this equipment from the links of the author of the topic is the same compressor as on Agito:
    http://www.agito.pl/kompresor-stanley-stn595-1-5-cp-8-barow-8215190stn595/pd/DL23JBBBM/
    Stanley STN595 compressor, 1.5 CP, 8 Bar
    I need to occasional blowing the computer, sometimes to inflate wheels or balls. No professional uses.
    I assume that's enough?
    And would it be like that? significantly better?
    http://www.agito.pl/stanley-kompresor-bezolej...cja-pne-pl-990098-c6bb304stp608/pd/DK9G9MBBM/
    Stanley Oil-free compressor 6L / 1.5KM / 8BR + BC set
    And how is he different from that? I understand that with some additional set?
    http://www.agito.pl/stanley-kompresor-bezolej...-5km-8br-pl-990101-c6bb34stn039/pd/D79G9MBBM/
    Alternatively Black & Decker compressor ASI300 (this one has both 230V and 12V):
    https://www.mall.pl/kompresory/blackdecker-asi300
    But will these devices be suitable for blowing the computer from time to time?
    Studio Języka Angielskiego
    Piastowska 18, Krosno, 38-400
  • Prefer a 25 L tank; advertised capacity may halve
    #10 15673539
    rubens
    Help: 209
    Rate: 301
    All of these compressors for use from time to time will suffice.
    And so their parameters are "a fingerprint".
    When you buy it only with a cylinder (even the 5l one).
    I recommend looking for videos on youtube.
    for example, the 5L 10ba AIR-BOSS compressor has a "paper" capacity of 180l, and in the test, e.g. https://www.youtube.com/watch?v=l77gvpjvhrQ, the actual capacity is about 90l / min
    If you don't need a portable one, buy with a 25l cylinder, as you must have a portable one even with a small cylinder.
  • #11 15674015
    Robinson74
    Rate: 159
    Are there any models with a 5L cylinder, but at the same time for 230V and 12V?
  • #12 15677038
    wasyl32
    Level 19  
    Help: 30
    Rate: 44
    How do you deal with falling dust after cleaning in confined spaces?
    After cleaning, for example, a computer working in a production hall or a warehouse in an office, I have a crap that I don't touch is all dirty. And it happens that you need to clean a few such computers a day.
  • #13 15678295
    zdzisiek1979
    Help: 563
    Rate: 1256
    Maybe the vacuum cleaner should be used first and caressed with air only for a better glance :D
  • #14 15678499
    kkknc
    Help: 1915
    Rate: 6709
    I go outside and smoke. In the middle, it has not been cleaned for years, the massacre is being done, and if a few times it is already .....
  • #15 20720991
    mnowak_24
    Rate: 13
    What kind of compressor did you finally buy? Because I'm also looking for due to the fact that I live in a block of flats is (the smaller the better) but sometimes needs to blow in the computer laptops for personal use, etc.
  • #16 20721396
    ^ToM^
    Help: 495
    Rate: 2939
    mnowak_24 wrote:
    What kind of compressor did you finally buy? Because I am also looking for due to the fact that I live in a block of flats it (the smaller the better) but sometimes needs to blow in the computer laptops for personal use, etc.
    Best buy silecery. The difference in noise is colossal:
    Link
    Link
  • Noisy tankless compressor with weak airflow
    #17 20721666
    ZnAl
    Help: 9
    Rate: 12
    I own a Stanley Air Kit, without a tank, the one from the link in the 1st post. I've never had a compressor with a tank, so I don't have a comparison.
    For the occasional blowing dust off a laptop, it may be suitable, but in general working with it is not convenient. The only advantages are the low price, weight and compact size (all accessories and the power cord hide inside).
    Noisy it terribly (according to the instructions 97 dB), and the motor must work all the time since there is no tank. To blow something meaningfully out of dust, you have to press and release the trigger every now and then. When constantly pressed, the airflow is so weak that it hardly blows anything out. The maximum time of continuous operation is 1.5 minutes and then there should be 8 minutes of break.
    Mi once broke the hose at the initial section, it easily bends there. I managed to replace it under warranty. On the new one I put a bow for pex pipes, so that this will not happen again.
    Rather do not recommend and next time I will probably buy something with a tank.
  • Mattress pump as a quiet blower alternative
    #18 20721689
    wada
    Help: 168
    Rate: 732
    I in domestic applications (and not only) first vacuum with an industrial vacuum cleaner, and then blow with a mattress pump, especially those blowers what are directly on 230 V, some supposedly have a capacity of up to 500 l / min.
    Bought in the market for 40 zl, it draws only 150 W and is quiet.
    And for firing up the grill - ideal. ;)
    There are also pumps (blowers) for mattresses 500-600 W, with capacities up to 2000 l/min - but they already make noise like a regular vacuum cleaner.
    Elefant
    Wagonowa 34, Wrocław, 52-231 | Company Website: literyzmetalu.pl
  • Silent compressor recommendation and FATMAX premium question
    #19 20722389
    mnowak_24
    Rate: 13
    Link
    Link
    You may know the difference between FATMAX and non-FATMAX. I read somewhere Fatmax is a premium product?
  • #20 20722907
    ^ToM^
    Help: 495
    Rate: 2939
    Probably the difference is only in the paint job. Compare the parameters, although for me they are identical. Not worth overpaying in my opinion. The yellow ones are cool too. :) .
  • Topic summary
    The discussion revolves around the use of small compressors as an alternative to compressed air for cleaning electronic equipment, particularly computers. Users share their experiences with various models, including the Stanley Air Kit, which is noted for its portability but criticized for being noisy and lacking a tank, leading to limited airflow. Some participants recommend larger compressors with tanks for more effective cleaning, especially for heavily soiled equipment. Others suggest using vacuum cleaners prior to blowing to manage dust effectively. The conversation highlights the importance of noise levels, portability, and the need for sufficient airflow in selecting a compressor for cleaning tasks.
