Sandblaster Compressor Recommendations for 350L, Starter Regeneration at Affordable Price
sledz73 12894 11
What affordable compressor should I choose for frequent sandblasting of starter motors with a 350-liter machine?
For frequent starter sandblasting, prioritize compressor air delivery over receiver size: choose an efficient two- or three-piston unit producing roughly 400–550 L/min at 6–8 bar, with a 300–500 L tank if affordable. [#16288968][#16288972][#16306904] An 1.8 mm nozzle reportedly uses about 250 L/min at 7 bar, while approximately 550 L/min can support a 3 mm nozzle. [#16288968][#16306904] At PLN 1,500, a suitable ready-made compressor will be difficult to find; a market compressor rated around 400 L/min may be possible, but cheap Metabo or Stanley units were considered unsuitable for repeated work. [#16288968][#16312988] For small starter parts, a cheap sandblasting gun and a reasonably sized market compressor may still work, particularly for short jobs, and a pressure-pot setup was suggested as a low-cost alternative. [#16312717][#16312988][#16313141] The used market, including domestic Airpol/Pomet units such as the N70, is another option, although a suitable used screw compressor was estimated at well above this budget. [#16288341][#16289768]
  • #1 16288139
    sledz73
    Rate: 14
    I want to buy a compressor that will be used for the sandblaster 350 liters, I will use it often, because it is to regenerate starters.
    What compressor would you recommend to me at a reasonable price.
    Greetings.
  • #2 16288270
    1 PAWEL
    Help: 674
    Rate: 1364
    Enter the amount of your budget that you can spend on buying a compressor.
    New or used?
  • #3 16288341
  • #4 16288930
    sledz73
    Rate: 14
    I will say this - I don't have big money, about PLN 1,500. Theoretically, I would prefer a new one, but if it got a good drug it could also be.
  • Recommended compressor specs for sandblasting on a budget
    #5 16288968
    aftys6
    Level 19  
    Help: 8
    Rate: 97
    sledz73 wrote:
    I will say so big money I do not have about PLN 1,500 theoretically I would prefer a new one but if there was a good drug it could also be
    Have you already sanded something ??
    If you want to start playing, think about a 300-500 L tank, preferably around a thousand.
    It is best if it was a 3 piston or 2 piston system with high efficiency.
    You need about 6-8 bars for sanding.
    The air demand of the 1.8-nozzle gun is about 250 liters at about 7 bar.
    Forget about market Metabo or Stanlej because after 2-3 robots you will throw them out with garbage.
    For 1500 it will be difficult for you to buy anything suitable for sanding.
  • #6 16288972
  • #7 16289001
    sledz73
    Rate: 14
    Well, I think that the tank is less important here, and unfortunately with compressors 300 liters is PLN 1500 I will pay for the tank itself.
    Yes, I sanded, I have been making some extra money after work for some time. I have a 90 sandblaster for now, but it will change in a while, and I worked on the Maktek 50 liters compressor, with one piston, and somehow I managed.
  • #8 16289768
    aftys6
    Level 19  
    Help: 8
    Rate: 97
    Just with such a small budget can save a large tank and 2-3 pistons.
    You shoot up to 8 bars, a few mini-robots and a break.
    The cost of a screwdriver with a capacity of 2-2.5 m3 is well over PLN 1.5 thousand.
    I think that the drug in tolerable condition is a minimum of 5 thousand in high
    The guest to whom he gives sandblasting parts has a screwdriver driven by some small disel and an expansion tank about 100 liters.
    The frame for a motorcycle makes an hour to flash.
  • 550 l/min compressor suffices for 3 mm nozzles
    #9 16306904
    patryk44gks
    Help: 11
    Rate: 74
    But we are talking here about equipment for sandblasting starters, i.e. not very large in size.
    Also a screwdriver will not be necessary something that will have a capacity of 550l / min will pull nozzles 3mm at 7 bars and that's enough for sandblasting starters.
    but for 1500 PLN you will not buy ready.
    Only the self-made remains, but probably only on the rice three-piston pump with 90mm pistons and it already has a capacity of about 700l / min should also pull 4mm nozzles.
  • Cheap sandblasting gun and 400 l/min compressor suffice
    #11 16312988
    patryk44gks
    Help: 11
    Rate: 74
    robokop wrote:
    Starters can be successfully sanded with a gun for a few zlotys - http://www.ceneo.pl/17387794, http://tynaxtools.pl/160-pistolet-do-piaskowania-kpl-dysz-4-7mm-5cz.html. And here even a larger market compressor is enough.
    Such a gun will be a bit of a bad idea better to make yourself a pressure for PLN 300, moreover, there is a lot of it on the forum. And the compressor is enough for a market for 1500 you can buy one with a capacity of 400l / min
  • #12 16313141
    robokop
    Help: 1763
    Rate: 6372
    It is a good enough idea where rare and small objects are sandblasted - it is cheap, requires any air source, unlike any, even the smallest sandblasting machine.
The discussion revolves around recommendations for a compressor suitable for a 350L sandblaster, specifically for regenerating starters. The user has a budget of approximately PLN 1,500 and prefers a new compressor but is open to used options. Responses highlight the challenges of finding a quality compressor within this budget, emphasizing that new, affordable models often lack reliability. Suggestions include considering used compressors or specific brands like Airpol and Pomet, with a focus on models that offer 300-500L tanks and 2-3 piston systems for efficient operation. The required air pressure for sandblasting is noted to be around 6-8 bars, with a nozzle gun air demand of approximately 250 liters at 7 bars. Some participants recommend DIY solutions or smaller market compressors that can meet the necessary specifications for sandblasting starters.
