anode voltage supplyLithium Ion 18650 Capacity Checker - Adam's Arduino Projects
arsonus 2520 8
  • #1 15784037
    arsonus
    Dear Colleagues,
    I would like to ask you to explain the operation principle and practical suitability (advantages) of the additional Q1 transistor as I believe
    - current source?
    Does it improve the stabilization of the output voltage?
    Charles
    • anode voltage supplyLithium Ion 18650 Capacity Checker - Adam's Arduino Projects zas.wys.nap.tube.gif (8.86 KB) You must be logged in to download this attachment.
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    trymer01 wrote:
    In addition - the value of R7 in combination with C5 and the value of C6 will cause that Uwa will slowly grow after switching on.
    This can be an advantage of the system.
  • #5 15784204
    arsonus
    trymer01 wrote:
    This current source on Q1 stabilizes the current flowing through DZ1, which causes that the voltage at these Zener diodes = 285V is more stable - because it reduces the effect of supply voltage, including grid voltage at Uwa = 280V.
    It's just that there is an error because the R5 value is too big - 560 Ohm gives the source current around 1mA, and it should be about 5-10mA.
    In addition, the value of R7 in combination with C5 and C6 will cause Uwy to slowly increase after switching on.
    Right, even a small current value for diodes has come to me ...
    And can you still improve - increase the rise time?
  • #6 15784300
  • #7 15784345
    arsonus
    I have probably expressed myself wrong ... I meant to increase the time of increasing the output voltage, and reducing the capacity is probably the opposite effect?
  • #9 15784384
    arsonus
    ... now everything is clear on the subject
    Thank you for the explanation and best regards
    Charles
  • Topic summary
    The discussion centers around the operation principle and advantages of an additional Q1 transistor in a lithium-ion 18650 capacity checker circuit. The Q1 transistor serves as a current source that stabilizes the current through Zener diodes (DZ1), enhancing the stability of the output voltage at 285V by mitigating the effects of supply voltage fluctuations. However, it was noted that the resistor R5 is incorrectly sized, leading to insufficient current (1mA instead of the desired 5-10mA). Suggestions were made to adjust component values, such as reducing the capacitance of C4, C5, and C6, and modifying R7 to improve the rise time of the output voltage. The conversation concluded with the author expressing gratitude for the clarifications provided.
