Assessing the Capacity of 18650 Cells for Power Bank Using XTAR VC2 Plus Charger
marcinek19992 13827 12
How can I cheaply measure the capacity and internal resistance of used 18650 cells so I can sort them for a power bank?
A cheap 18650 capacity tester from AliExpress is accurate enough for sorting cells for a power bank [#16508626] Measure capacity by discharging the cell with a stable resistive load, because the calculation is based on current and voltage over time and an impulse load can distort the result [#16541512] If you want to shorten the test, you can reduce the load resistance, but keep the discharge current reasonable so you do not damage the cell; in the shown meter it is just under 1 A [#16540227] For internal resistance, measure the open-circuit voltage, then the loaded voltage, and calculate it as R = (Uo - Ur) / Ir [#16510086] The smaller the internal resistance, the better the cell [#16510209]
  • #1 16508602
    marcinek19992
    Rate: 34
    I have a housing for a power bank and generally want to make a PB-power bank like a colleague in the subject:
    https://www.elektroda.pl/rtvforum/topic3345177.html
    I have already dismantled the cells and charged with the XTAR VC2 plus charger. Now the only question is: How to check their capacity?
    All cells have the same V, but I don't know their capacity, i.e. how much energy they have.
    And now I would like to ask you if it could be checked at a low cost?
    I would like to divide them into such better ones, e.g. for the flashlight I have, i.e. convoy.
    To powerbank, so average
    and those that have less than 1000 mAh, i.e. to discard or to some ledowe.
    I already have 26 pieces of 18650 batteries available, now I just need to measure their capacity.
    I found something like this:
    aliexpress
    I would ask for advice.
  • #2 16508626
    Xantix
    Help: 686
    Rate: 1657
    aliexpress
    Well, such a measure has sufficient accuracy for your application. It can be done.
  • #3 16510076
    marcinek19992
    Rate: 34
    From what I read on the internet, resistance is also important. How to measure it?
  • #4 16510086
    Xantix
    Help: 686
    Rate: 1657
    You can by technical method. You measure the voltage on an unloaded cell, then connect the load and measure the voltage again. The cell resistance can be calculated from the formula: R = Uo-Ur / Ir where Uo - voltage without load, Ur - voltage under load, Ir - load current.
  • #6 16510201
    marcinek19992
    Rate: 34
    Since you wrote that it might be so I bought it today, I will have it in a month's time.
    I will measure the capacity and check which ones are the best. And this resistance is the smaller the better or the larger the better?
  • #7 16510209
    Xantix
    Help: 686
    Rate: 1657
    The smaller the better.
  • #8 16540199
    marcinek19992
    Rate: 34
    Yesterday a package from Aliexpress came to me and I already checked 2 cells. One is 1876 mAh and the other is 1920 mAh. Now I would only have to measure the resistance.
    It takes some time to test these links. On average, you need to count about 2-3 hours per link. Could it be accelerated?
  • Reducing load resistance to shorten measurement time
    #9 16540227
    PiotrPitucha
    Help: 201
    Rate: 424
    I can see that almost world record during delivery with ali .....
    Do not mix with the measurement time, after all, you do not do it every day, generally, shortening the measurement time requires reducing the load resistance, I do not know the design of the meter, you can probably shorten it, but note that now you have a discharge current of just under 1A.
    In the advertisement on ali ... there is a link to resistors, so a change of current is probably possible.
    18650 can be treated with higher currents, but by testing other cells you can overdo it and destroy it.
    By the way, an excellent price for a system for such measurement :)
    best regards
  • #10 16541342
    marcinek19992
    Rate: 34
    I was so surprised that they were able to send me this meter so quickly.
    However, I wonder if instead of a 5W7om ceramic resistor, it is better not to give there a led or something useful.
    Well, so far this measure comes 24 hours / h at night I wake up, I change batteries and go to sleep.
  • #11 16541512
    PiotrPitucha
    Help: 201
    Rate: 424
    I think the load must be resistive and relatively stable, the procedure for counting capacity is based on sequential measurement of current and voltage, if we give some impulse load, the measurement could fall at the peak of current consumption and disturb the average capacity displayed on the display.
    That's how simple systems work, I don't have a schematic but I think aloud ....
    best regards
  • DIY Arduino tester still measures only one cell
    #12 18094404
    marcinek19992
    Rate: 34
    Welcome back
    I bought a 18650 cell tester but there is a problem ... Because it measures one cell. And the charger that I have has been testing the cells for a very long time (about 10 hours)
    And now I think maybe it is better not to do some tester yourself. Would something like that be appropriate?
    https://www.instructables.com/id/DIY-Arduino-Battery-Capacity-Tester-V10-/
    It is also only for one link :(
  • #13 18094797
    PiotrPitucha
    Help: 201
    Rate: 424
    The picture from Arduino has 8 analogue inputs, two are occupied by the display, i.e. you can supervise 3 cells at once :)
    If the display can be connected in software configuration, it will be possible to monitor 4 cells.
    As little as I suggest an external 16-channel ADC and 8 cells for each ADC :)
    I don't think you need more, but you can always connect several ADCs :)
The discussion revolves around assessing the capacity of 18650 lithium-ion cells for use in a power bank, utilizing the XTAR VC2 Plus charger. The user seeks low-cost methods to measure the capacity of 26 available cells, aiming to categorize them based on their energy storage capabilities. Responses suggest measuring voltage under load to determine internal resistance, with lower resistance being preferable. The user has already tested two cells, yielding capacities of 1876 mAh and 1920 mAh, and is exploring ways to expedite the testing process. Suggestions include using resistive loads for accurate measurements and considering DIY solutions for testing multiple cells simultaneously.
