Skoda Fabia 2 (2008) Radio Code - Buying 2013 Radio Blues 5, No Code & Unplugging Power Supply
marekwodniak 10275 4
  • #1 17052179
    marekwodniak
    Help: 14
    Rate: 194
    I have the opportunity to buy a radio for Skoda Fabia 2. 2008. The radio comes from Fabia 2013. The seller is from my area. He says that there is no code because there was no. He unplugs the plug behind the radio and it works. Is it possible that the radio is without the code if it does not lose it after unplugging the power supply. Radio Blues 5 .
    LWD11
    Help: 223
    Rate: 486
    In his car, the radio may not request the code after disconnecting the power supply. Perhaps, due to the comfort function, the computer remembers the radio that was factory-installed (if I wrote something wrong, please correct me). Generally the radio is coded, when you put it on outside "your" car, it will ask for a code.
  • #3 17052459
    marekwodniak
    Help: 14
    Rate: 194
    It is difficult to buy another with the code because there is a payment for coding reportedly 50 PLN. Thank you.
  • #4 17052463
    LWD11
    Help: 223
    Rate: 486
    Maybe you will get along with him and he will leave the price for the cost of decoding.
  • #5 17052565
    marekwodniak
    Help: 14
    Rate: 194
    I called the Skoda website, the guy said that the decoding was about PLN 200. Shock I'm looking for another way where to do it because it does not pay off. The radio has a cool Blues 5 model from 2013. And he only wants PLN 150. and radio for PLN 220. And I think about the marten, only some people write that it may not always fit the car and there may be problems after the divider. Some write that they had some problems with reception.
