Audi A3 8P - "ESP Fault" message, the car will not start.
LeoMinor 31938 3
  • #1 15940752
    LeoMinor
    My car greeted me with this error today:
    I will add that yesterday I had the impression that the car stopped starting at the touch of a button. It took him literally a moment longer, but it started without a problem.
    Today is what you hear in the video. It sounds like a machine gun, and the display says: "ESP Fault, See owner`s manual."
    Is there anything else I can do before I tow it to the mechanic?
    buncza
    Help: 10
    Rate: 94
    Yes, charge the battery or replace it.
    Clearly too little current - especially as the clocks dim
    dr.master
    Help: 518
    Rate: 927
    I would suspect lack of communication with the engine controller.
    Without computer diagnosis, it will be difficult to help.
  • #4 15943373
    LeoMinor
    Indeed, the 7-year-old battery was to blame.
    After the replacement, everything works fine, the ESP error message no longer appears, it was a secondary issue.
    Thank you for your helpful entries!
