Audi A3 2003: ESP Light Stays On After Battery Issue - Fixes?
zaora93 62090 16
Why does the ESP light stay on after a battery voltage drop in an Audi A3, and how can I reset it?
The ESP light usually comes on after a low-voltage event because the steering angle sensor/basic settings are lost, so this is more likely a calibration issue than a broken ESP unit [#10606867][#10606894] Read the fault codes first with VCDS/diagnostics, then repeat the basic settings or recalibrate the steering sensor/ABS [#10606981][#10607032] One suggestion was to drive slowly and turn the steering wheel fully left and right, but if the light stays on, that alone will not fix it [#10607202] In the thread, the problem was ultimately fixed at an Audi dealer, where they said the disconnected terminals had caused low voltage and the computer needed to be decoded/reprogrammed [#10619040]
  • #1 10606821
    zaora93
    Rate: 25
    I have an Audi A3 from 2003.
    everything was fine until my battery started dying. I didn`t know what it was about because it turned off for literally a moment and then worked again. It turned out that the terminals were not tightened. After one of these "battery resets", the ESP light started to illuminate. I checked if it works and unfortunately I must say that it doesn`t. I clicked the ESP button to turn ESP on and off but nothing happens, it stays on. And here I have a question: what should I do about it? Has my ESP broken or what?
    I would like to ask for help as soon as possible
  • #2 10606867
    panam
    Help: 82
    Rate: 419
    You know, in these cars, all computers are sensitive to lack of voltage, so after such an action you have to connect the computer or restart it yourself.
  • #3 10606894
    rox1
    Help: 16
    Rate: 169
    Hello . The steering sensor adaptation has probably failed and you will need to repeat the "basic settings"
    best regards, rox1
  • #4 10606900
    zaora93
    Rate: 25
    and how can I reset it myself? turning off the battery? or in some other way, if only turn it off for how long?
    Added after 1 [minute]:
    best regards, rox1
    Do you know what the amount of such settings could be?
  • #5 10606936
    rox1
    Help: 16
    Rate: 169
    I know because I do it on a regular basis, first the vcds diagnostics, reading the errors, and then we can talk about the costs, but I think it will be around PLN 250.
    best regards, rox1
  • #6 10606940
    zaora93
    Rate: 25
    and as for restarting, do you know how to do it?
  • #7 10606981
    rox1
    Help: 16
    Rate: 169
    nothing is reset, only if nothing has happened, the steering sensor is calibrated again, or the ABS coding is repeated. If you live near my city, I can sort it out for you, you can`t fix it yourself!!!
    best regards, rox1
  • #8 10606985
    panam
    Help: 82
    Rate: 419
    , my question, have you driven the car after the problem?
    best regards rox1, this is what it is, it`s just driving, turn all the way left and right and adaptation should be done
    I pasted it wrong, but try the above
  • #9 10607015
    zaora93
    Rate: 25
    I was driving, I was doing gas tests in the snow, to check if the ESP works, but unfortunately it doesn`t, but there`s no point in hiding the fact that it`s certain since the light is on.
    Added after 23 [seconds]:
    and I live in Olsztyn, so there`s a bit of it :(
  • #10 10607032
    trans-serwis
    Help: 297
    Rate: 2259
    Diagnosis first, then repair.
    Such shamanic advice will not help.
  • #11 10607202
    fuelinyourblood
    Help: 226
    Rate: 1391
    It`s not magic, just normal procedure.
    You drive 5 km/h and turn the steering wheel left and right. If not, diagnostics, calibration of the steering sensor or replacement should help.
  • #12 10607548
    zaora93
    Rate: 25
    After how many turns should it turn off?
  • #13 10607619
    fuelinyourblood
    Help: 226
    Rate: 1391
    Does the power steering work? light goes out?
    Literally after a few.
  • #14 10611049
    zaora93
    Rate: 25
    the power steering works and the light is still on, I made a few turns like that and it didn`t do anything ;(
    I have an additional question: how much does a computer diagnosis cost in your city?
  • #15 10611417
    trans-serwis
    Help: 297
    Rate: 2259
    Diagnosis or error reading - there is a difference.
    Error reading PLN 80.00.
  • #16 10619040
    zaora93
    Rate: 25
    the car was repaired, I managed to get it done for free at an Audi showroom. It turned out that there was little voltage from the disconnected terminals and the computer was decoded.
  • Steering wheel disassembly likely triggered ESP fault
    #17 19145987
    Szakalbro
    Rate: 11
    Hello, I have the same problem, Audi A3 8p 2003. 2.0 TDI, my friend changed my turn signal lever, it was old, it had some punctures, when I turned the blinker to the right, it flashed once to the right and then to the left, generally a circus. He unscrewed the entire steering wheel, took out some plates, pulled out the old direction lever and installed a new one. Direction, act normally. But there is an error esp yellow exclamation mark. It doesn`t want to go away, I connected it to the computer and the guy removed the errors, but the light is still on. I turned off the battery and the error is still there. Damn, he fixed one and broke the other. What could be the reason for this?
The discussion revolves around an issue with the ESP light remaining illuminated on a 2003 Audi A3 after a battery problem caused by loose terminals. Users suggest that the ESP system may require a reset or recalibration of the steering sensor due to the voltage drop. Recommendations include using VCDS diagnostics to read errors and perform necessary calibrations. One user successfully resolved the issue at an Audi showroom, where it was determined that low voltage had caused the computer to malfunction. Another user reported a similar problem after replacing the turn signal lever, indicating that the ESP error persisted despite attempts to reset it by disconnecting the battery.
