Audi A6 C6 2005: ESP Fault 18265 P1941 - Causes and Solutions for Battery Control Module Errors
mihalypiskolczi 7941 2
  • Battery control module CAN message fault diagnosis
    #1 20054279
    mihalypiskolczi
    I have an Audi A6 from 2005, in which after 10 minutes the ESP indicator started to pop up, there is no driving without the appearance of this error, after switching off the engine the indicator disappears and the next time the error pops up again. My question to Audi owners, what is the reason? How can this be fixed? I mention with the alternator and battery voltage regulator. I was with this problem at various electricians and "professionals" from Audi, unfortunately no one but the proposed solutions regarding the replacement of the alternator and regulator can not cope with the problem Thank you in advance for your help. The problem persists. I come back from the diagnostician errors that shows:
    P1941 -CAN; incorrect message from the battery adjustment control module
    - Constant
    18265- Load signal, incorrect message from the engine control module
    -Constant
    Asking for help what to do next. I will add that the problem also occurs when the car is started without driving.
  • #2 20461434
    zedeerip
    I had the same problem. Alternator voltage regulator failure or replacement of a non-factory part is causing this fault. Among other things, the rear windshield heater and the rear view mirror heater are also missing.
  • #3 21004297
    JacekWietrak
    If you could help me, please contact me on 785945684
