Audi A6 C6 - 2.0TDI - Glowing ESP after 10 minutes of driving
krzybag01 13077 11
Why does the ESP warning light come on after about 10 minutes of driving in an Audi A6 C6 2.0 TDI, and how can it be fixed?
The thread does not give a confirmed repair, but the reported fault codes point to a CAN/engine-side problem rather than the ESP system itself [#16629535] The codes were P1941 (“incorrect message from the battery adjustment control module”) and 18265 (“Load signal, incorrect message from the engine control module”), and the advice was to focus on those two errors [#16629535][#16629612] The suggested direction was to check the fuel system, including injector/pump parameters and engine ECU faults [#16629612][#16630801] Another reply said to start with a full computer diagnosis because there can be many causes, commonly injectors [#16534629]
  • #1 16534598
    krzybag01
    I have an Audi A6 from 2005, in which after 10 minutes the ESP indicator started to pop up, there is no driving without the appearance of this error, after switching off the engine the indicator disappears and the next time the error pops up again. My question to audi owners, what is the reason? how can this be fixed? I mention with the alternator and battery voltage regulator. I was with this problem at various electricians and "professionals" from audi, unfortunately no one but the proposed solutions regarding the replacement of the alternator and regulator can not cope with the problem Thank you in advance for your help
  • #2 16534629
    bucek21
    Help: 14
    Rate: 86
    Start with a computer diagnosis. There can be many reasons. The most common is some of the injectors!
  • #3 16629535
    krzybag01
    Hello. The problem persists. I come back from the diagnostician errors that shows:
    P1941 -CAN; incorrect message from the battery adjustment control module
    - Constant
    18265- Load signal, incorrect message from the engine control module
    -Constant
    Asking for help what to do next. I will add that the problem also occurs when the car is started without driving.
  • #4 16629612
    andrzej20001
    Help: 1578
    Rate: 6669
    Focus on 2 errors. Something is wrong with the fuel system.
  • #5 16630034
    henryk777
    Rate: 36
    I had a similar problem and the reason was wrong convergence.
  • #6 16630450
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Namely what?
  • #7 16630795
    krzybag01
    The convergence was set. As I wrote, it is enough that I start the car and without any ride after 10 minutes an ESP message appears. So whether the vehicle is moving or not the message pops up.
  • #8 16630801
    andrzej20001
    Help: 1578
    Rate: 6669
    Pump parameters and engine errors in ECU
  • #9 16630940
    krzybag01
    Pump injectors checked, no other errors are found. Tomorrow I will connect to another computer, see if it shows something else
  • #10 16631150
  • #11 20054238
    mihalypiskolczi
    @krzybag01 what was the solution?
  • #12 20364498
    veroyk
    krzybag01 wrote:
    I have an Audi A6 from 2005, in which after 10 minutes the ESP indicator started to pop up, there is no driving without the appearance of this error, after switching off the engine the indicator disappears and the next time the error pops up again. My question to Audi owners, what is the reason? How can this be fixed? I mention with the alternator and battery voltage regulator. I was with this problem at various electricians and "professionals" from Audi, unfortunately no one but the proposed solutions regarding the replacement of the alternator and regulator can not cope with the problem Thank you in advance for your help
    Did you find a solution to this?
The discussion revolves around an issue with a 2005 Audi A6 C6 2.0TDI, where the ESP indicator activates after approximately 10 minutes of driving. The owner has consulted various professionals, but solutions have primarily suggested replacing the alternator and battery voltage regulator. Diagnostic errors indicate problems with the battery adjustment control module and engine control module. Responses suggest focusing on fuel system errors, checking pump parameters, and verifying the vehicle's electrical components. The owner has also confirmed that the ESP message appears even when the vehicle is stationary, indicating a persistent issue that requires further diagnostic checks.
