Connecting Oil Compressor to Faucet for Garden Watering System Winterization
anaruku 13539 22
How can I connect an air compressor to a garden faucet to blow out an irrigation system for winter, and is there a ready-made adapter or do I need to make one myself?
You do not need to DIY the adapter: the forum answer says to buy a 1/2" external-thread adapter plus a standard 1/2" garden hose tap connector, which are sold in places like Castorama on the compressor accessories/garden fittings shelves [#16035339] [#16062853] One user used a similar ready-made tip purchased for this purpose and connected it with a hose and clamps/reducers [#16064156] The key is not tank size alone but airflow, so a compressor around 50 l/8 bar with about 120 l/min output can work, although slowly and with the compressor running continuously [#16040166] [#16035727] [#16064156]
  • #1 16034425
    anaruku
    Help: 6
    Rate: 10
    Hi, I have garden watering on my plot,
    so far, a guy came before winter (under warranty) and connected the oil compressor to the faucet in the façade (where the garden watering system is connected).
    He turned on the compressor and, under pressure, cleaned the entire circuit of any remaining water in the pipes and capillaries.
    The warranty on the watering system has expired and the guy wants PLN 250 for coming and blowing it out. The price is outrageous - especially since a sufficient compressor at Castorama costs less than PLN 200.
    I just need a tip that will allow me to attach the compressor to the tap.
    Can you buy something like this? where to look for it?
    Or do I need to DIY the tip? just as...
  • #2 16034448
    zyzy52
    Help: 126
    Rate: 368
    We don`t know what type of "faucet in the facade" you have. You can buy various tips and connectors in gardening stores in large supermarkets.
  • #3 16034480
    anaruku
    Help: 6
    Rate: 10
    1/2 tap valve - the ends are screwed in in every store, I know about it, the question is whether there are ready-made solutions for compressors or do I have to modify such a end myself, basically?
    Tip + hose + clamping ring etc..
  • Finding a ready-made compressor-to-faucet adapter
    #4 16034898
    Wawrzyniec
    Help: 392
    Rate: 1075
    anaruku wrote:
    Are there any ready-made solutions for compressors or do I have to modify the terminal myself?
    No you do not have to. When you go to the store and buy a compressor, it`s enough to ask for the hose end to be modified if making an adapter yourself is such a problem, but then we`ll have the next topic: "Compressor - an end to be connected to the valve" and a question: I only need an end that will allow me to attach the compressor to the wheel. .
    Or do I need to DIY the tip? just as....
  • #5 16035055
    anaruku
    Help: 6
    Rate: 10
    The question was whether there is such a ready-made ending, because I need it and I don`t know what phrases to look for.
    If not and I have to do it myself, I can handle it. But why do it when she`s ready? That`s what I`d like to know.
    Leave sarcastic posting just for the numbers on your profile for another topic :)
    1/2-inch adapter and tap connector for compressor hookup
    #6 16035339
    jesion40
    Help: 100
    Rate: 127
    I use a similar tip purchased for this very purpose. I bought it at Castorama for a few zlotys. Unfortunately, I don`t remember the symbol, but you can easily find it on the compressor accessories shelf. On the one hand, a connector typical for connecting pneumatic devices, on the other, typical for garden hoses.
    Self-correction after checking: there are no adapters directly for the garden stub, but for a few zlotys you can buy an adapter for 1/2" (external thread) and a typical 1/2" tap connector for a garden stub and that`s it :D
  • #7 16035352
    kkknc
    Help: 1916
    Rate: 6721
    For PLN 200 from Castorama, you`ll be blowing it all day long.
  • #8 16035520
    anaruku
    Help: 6
    Rate: 10
    Hmmm... I haven`t seen such a beauty, so I`ll go again...
    8 bars 24 or 50 l should have no problems - unless...
  • #9 16035538
    kkknc
    Help: 1916
    Rate: 6721
    I guess it`s a boat in the water. The compressor must have exhaust. First, you charge the compressor, then you release the air through the system in 15 seconds and another 5 minutes of waiting for the pressure. And so on all day long.
  • Small compressor works for 100 m² irrigation blowout
    #10 16035550
    anaruku
    Help: 6
    Rate: 10
    irrigation is not located on 10 hectares, but on 100 m2, so there is not much of an actual irrigation system. The guy who previously cleaned the system of water for the winter did not have a spectacularly large compressor, max 90l, and maybe even 50l, which he wants to buy, hence the reason for this ;)
  • #11 16035556
    Wawrzyniec
    Help: 392
    Rate: 1075
    anaruku wrote:
    8 bars 24 or 50 l
    It can be 10 bar and 500l, and if the air pipe is 4mm in diameter, you can blow into your mouth...
  • #12 16035578
    anaruku
    Help: 6
    Rate: 10
    Well, as standard they provide a cable, if I`m not mistaken, a 5.5 mm spiral - can`t you do it? what do you suggest?
  • #13 16035615
    kkknc
    Help: 1916
    Rate: 6721
    What matters is the air flow, not the size of the tank. I have been watering for 10 years, so I know what I`m writing about. I`ve already done it once with this little guy.... Now I`m hooking the screwdriver onto the hook. I had all the threads blown out at once in 30 minutes.
    Wawrzyniec
    Help: 392
    Rate: 1075
    Have you ever seen a tire repairer close a tubeless truck tire? 30-40l cylinder, 1" valve, the same pipe flattened at the end. When you blow it, the tire closes. This would not be possible with a compressor. Air flow is important. You need a compressor not so much with high pressure, but with high flow (many liters). has a minute).
    10 bar/50 l compressor adequately winterizes 300 m² irrigation
    #15 16035727
    jesion40
    Help: 100
    Rate: 127
    I don`t know what compressors they sell for PLN 200, but I`ve already done it twice with a completely average 10bar/50l oil compressor bought for about PLN 400 at Praktiker. It could probably be done a bit faster with better equipment, but for me it takes about 15-20 minutes, so I don`t see the point in spending more money to shorten this time. The compressor is sufficient for my needs, including simple painting works (e.g. painting doors, tables), which are probably the most demanding of what I do.
    As for the diameter, it is the smallest in the section from the compressor to the adapter, and then it is wider. Why would lower performance cause any problems? I don`t know. And I`m not going to wonder. It works, it does what it needs to do in an acceptable (for me) time and that`s it. I don`t want to argue with wise men.
    Added after 7 [minutes]:
    For such an area, a small compressor is certainly enough, for comparison, my installation irrigates approximately 300 m², but there are also mains supplying water to the intakes (valves in cans recessed into the ground), which are quite long (over 100 m) and also pipes. 3/4".
    However, if you are planning to buy a compressor, consider other applications, in my opinion 10bar/50l is a reasonable minimum.
    Moderated By Krzysztof Reszka:
    Please, no sarcasm. Further posts like this end up in the trash
  • #16 16035763
    Wawrzyniec
    Help: 392
    Rate: 1075
    jesion40 wrote:
    Why would lower performance cause any problems? I don`t know. I don`t want to argue with wise men.
    Well, try blowing into a hose as performance doesn`t matter.
  • #17 16036035
    kkknc
    Help: 1916
    Rate: 6721
    I also no longer feel like having a discussion with a 5-year-old, because a 6-year-old is already starting to understand the basic laws of physics and knows that without expenses, there will be no pressure.
    The minimum age for this forum is 13 years old.
    3.1.9. Don`t be ironic or mean to the other side of the discussion. Respect different opinions and other opinions on the forum.
  • Gravity-draining outdoor lines prevents winter damage without compressor blowout
    #18 16036410
    Walery K
    Help: 32
    Rate: 100
    For the first two years, I also played with blowing out the installation. Now, for 15 years, before winter, I only close all the valves in the house and open all of them outside, and nothing has been damaged so far, so even though I have a compressor, I don`t use it to blow out the installation. However, when you want it All right blow through, the expense really matters. I pumped air into a 300l hydrophore tank and only when I reached the maximum pressure did I open the valves, when the pressure dropped I closed the valves and repeated this several times. Constantly pumping air into the installation didn`t help much, but you can do whatever you want.
  • #19 16040047
    jesion40
    Help: 100
    Rate: 127
    ......... And why should there be "pressure"? How big? And where? Apart from the fact that, without any expenditure, the pressure will be as high as desired, e.g. in a closed tank. But this is not the case. Here, the movement of air under relatively low pressure pushes water out of the pipes. At first, water comes out, then a mixture of water and air, and finally almost only air. It is not necessary to remove all the water from the pipes, as long as they are not filled with it.
    If it`s such a miracle, maybe I should turn it into a spectacle and sell tickets? We`ll have to get down to it in the next few days. Anybody interested in the show?
    I removed the offensive text.
    Moderator Krzysztof Reszka
  • #20 16040076
    Wawrzyniec
    Help: 392
    Rate: 1075
    jesion40 wrote:
    the pressure will be as high as required, e.g. in a closed tank
    Well, someone here doesn`t understand the word "expense".
  • Compressor cleared 40 m of irrigation line successfully
    #22 16062853
    jesion40
    Help: 100
    Rate: 127
    A small autocorrect. Yesterday I was blowing water out of my installation and found out that I had made a mistake in the description. This is not a direct adapter for a garden hose quick connector, but an adapter for a 1/2" external thread on which a typical 1/2" adapter for a garden quick connector is screwed. Sorry for the misleading, but I haven`t opened it for so many years (and I use it once a year, in autumn...) that I remember both elements as a whole.
    By the way: a miracle happened again and I blew the water out of the installation without any problems. Out of curiosity, I connected the compressor disconnected from the power supply - it removed water from the power supply line, approximately 40 meters long, without any problems (I do not have a longer single line). By the way, I measured the time. After connecting the pressure, water gushed out of the tap for about 60 seconds, then for another 60 seconds there was less and less water intensively sprayed with air, and finally almost only air. Most of my time is spent running around the garden and opening/closing valves.
    I probably don`t understand. In my naivety, I believe that the "expense" is the value of the momentary air flow from the compressor. For comparison, "efficiency" is the output that the compressor can continuously deliver to the system at a given pressure. Finally, I connected the entire installation to the compressor, increased the pressure (with the outlet valves closed) to 2at and closed the valve on the compressor side. Yes, it took a while, because a large amount of pressurized air accumulates in the system when it is emptied of water (which is not present when there is water in it). But at the end of all the fun, the expense is zero, so a compressor with any small capacity can do it.
    Another thing is that it is not necessary for anything - I did it out of curiosity to check the tightness of the installation.
    As for the moderator`s comments - maybe you should have reacted faster to the wise men`s taunts, such as the comment quoted above? Then there would be no need or reason to be sarcastic...
  • 120 L/min compressor drains the watering circuit
    #23 16064156
    anaruku
    Help: 6
    Rate: 10
    Okay people, here`s the thing. The compressor actually has an output of 120 liters - it is not much, but enough to pump water out of the circuit.
    It is actually difficult to work because the compressor has to work constantly to have any effect. An 8bar compressor with a 50 liter tank and a 120l output is a poor choice - enough for 20 minutes. draining, but it could be stronger.
    I found the reducing tips in Castorama, a piece of hose, 2 reducers and the system was ready.
    Case solved - thank you for your help.
    Sogi for people who write with sense and are helpful on the topic.
    Regards :)
The discussion revolves around connecting an oil compressor to a garden faucet for winterizing a watering system. The original poster seeks advice on how to attach the compressor without incurring high service fees. Various responses suggest purchasing connectors and adapters from gardening stores or DIY solutions. Specific recommendations include using a 1/2" external thread adapter compatible with garden hose connectors, which can be found at Castorama. The importance of air flow over pressure for effective water removal from the system is emphasized, with users sharing their experiences and equipment specifications. Ultimately, the original poster successfully found the necessary components to complete the task.
TL;DR: A 1/2" BSP-to-quick-coupler adapter (≈PLN 15) and a compressor delivering ≥120 L/min at 3 bar clear most 100 m² irrigation loops; remember "air flow is important" [Elektroda, Wawrzyniec, post #16035694]
Why it matters: Using the wrong adapter or pressure can crack pipes, flood valves, and waste hours.
• Faucet outlet on Polish façades: 1/2" BSP male thread [Elektroda, anaruku, post #16034480] • Safe blow-out pressure: 2.8–3.5 bar (40–50 PSI) for PVC lines [Rain Bird, 2023] • Typical DIY compressor: 50 L tank, 120 L/min at 6–8 bar, PLN 200–400 [Elektroda, anaruku, post #16035520] • Brass compressor-to-faucet adapter price: USD 6–8 (≈PLN 25) [Amazon, “Sprinkler Blowout Adapter”] • Flow >140 L/min clears six rotor heads in one pass [Hunter Industries, 2022]
What exact adapter do I need to hook a compressor to a garden faucet?
Use a female 1/2" BSP-thread adapter that accepts a pneumatic quick coupler, then clip on the standard hose quick connector [Elektroda, jesion40, post #16035339] Total cost is about PLN 15–25 [Amazon, “Sprinkler Blowout Adapter”].
Can I buy a ready-made connector instead of DIY?
Yes. Castorama, OBI, and online stores sell pre-built “sprinkler blowout” adapters packaged with 1/2" threads and Euro quick couplers [Elektroda, jesion40, post #16062853] Look in the compressor-accessory aisle, not garden hoses.
Why does flow rate matter more than tank size?
Water exits only when air volume replaces it quickly. A 24 L unit needs 5-minute refills after 15 s of discharge, while a 120 L/min unit keeps flow continuous [Elektroda, kkknc, post #16035538] High flow prevents trapped water pockets.
How much compressor flow is enough for a 100 m² lawn loop?
120 L/min at 3 bar empties a 40 m manifold in about 2 minutes [Elektroda, jesion40, post #16062853] Hunter reports 140 L/min clears up to six rotors in a single pass [Hunter Industries, 2022].
What pressure should I set to avoid pipe damage?
Stay between 2.8 and 3.5 bar (40–50 PSI) for PVC and 4 bar max for polyethylene lines [Rain Bird, 2023]. “More pressure will not speed things up—only risks cracks” [Rain Bird, 2023].
Will a cheap 24 L, 8 bar compressor work at all?
It works but slowly. Expect dozens of recharge cycles, taking “all day long” on small units [Elektroda, kkknc, post #16035352] Efficiency improves if you isolate zones and blow one at a time.
Is it safe to skip blowing and just open outdoor taps?
On small above-ground loops, some users reported 15 years without damage by simply draining gravity [Elektroda, Walery K, post #16036410] However, buried valves or drip lines can still freeze and split below −5 °C [Hunter Industries, 2022].
Could too much air burst emitters?
Yes. Exceeding 5 bar may pop drip emitters or mist heads, an edge-case failure documented in service bulletins [Hunter Industries, 2022]. Keep a gauge on the hose for safety.
Step-by-step: How do I blow out the system?
  1. Close indoor feed valve and attach the 1/2" adapter to the faucet.
  2. Set compressor regulator to 3 bar, then trigger zone valves one at a time.
  3. Run each zone until only air exits (≈60 s), then move to the next [Elektroda, jesion40, post #16062853]
Does hose diameter between compressor and tap matter?
Yes. A 4 mm airway chokes flow; even 500 L tanks become ineffective [Elektroda, Wawrzyniec, post #16035556] Use at least 6 mm internal diameter pneumatic hose.
Can I use a screw compressor or large storage tank instead?
A 300 L buffer tank gives high surge flow and empties zones faster, but adds cost and footprint [Elektroda, Walery K, post #16036410] Screw compressors excel for contractors blowing multiple properties daily.
What if some water remains after blowing?
Tiny puddles are fine. The goal is to remove standing columns; residual droplets freeze harmlessly because they have expansion space [Rain Bird, 2023].
