[Solved] Choosing the Right Compressor Hose: Affordable Options for Occasional Use & 10-Meter Length
grzegorz041 24609 13
What inexpensive 10-meter compressor hose should I buy for occasional use at about 8 bar so it stays flexible in frost and does not crumble quickly?
For occasional use at 8 bar, a rubber hose for fuel/oil or an oxygen hose is the most practical choice; use 8 mm inner diameter for blowing and inflating, and at least 10 mm if you need more airflow [#17461326][#17460950] Ordinary PVC hoses are cheap and light, but they are not very resistant to mechanical damage and can become hard and brittle after frost, so they are a poor choice for winter use [#17461114][#17461206] Silicone hoses were also suggested because they stay flexible and do not break in frost, but they were noted as more expensive [#17468647] The thread’s final outcome was that the original poster bought an oxygen hose cheaply and reported that it worked very well [#17522559]
  • #1 17460715
    grzegorz041
    Help: 7
    Rate: 142
    Hello to all forum members.
    Due to the fact that my compressor hose is starting to crumble with age, I was faced with the choice of buying another one.
    But as it is now, there is everything to choose from, but also different prices ....
    I don't use the compressor professionally every once in a while. The compressor is of own production, it gives about 8 atmospheres.
    I would like to buy about 10 meters of cable, which would last for a while. So that after the winter it does not turn into a 'cat's tail' and after the first frost, it does not break like a match ... But I do not want to spend PLN 1000 either. !! Maybe you can suggest something optimal?
    Oh, and maybe not a spiral - just plain simple ...
  • #2 17460950
    mariuz2
    Level 19  
    Help: 28
    Rate: 67
    Get yourself a hose from an oxygen cylinder (gas welder).
  • #3 17461006
    grzegorz041
    Help: 7
    Rate: 142
    I had just one. A bit too stiff and bulky for me.
  • #4 17461114
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    I suggest a plain, armored PVC hose. Light, cheap, flexible. Among the disadvantages, it is not very resistant to mechanical damage and to some extent not resistant to UV radiation (unless something has changed in this matter).
  • #5 17461115
    kkknc
    Help: 1916
    Rate: 6721
    In the past, Castorama had ready-made, good-quality, forged rubber hoses. Or buy a spiral one it will be more expensive. How is it supposed to be good, of course.
    It can also be dedicated to pneumatics. So rubber covered with PVC.
  • #6 17461206
    grzegorz041
    Help: 7
    Rate: 142
    From what I heard, an ordinary flexible PVC wire, after one frost visit, there is already a 'cat's tail'. Hard and brittle ..
    I have 90 km to the nearest Castorama. I would prefer something from the Internet ... What kind of rubber do you mean?
  • #7 17461278
    kkknc
    Help: 1916
    Rate: 6721
    The one from Castorama was Semperit and German quick couplings.
    The materials themselves were expensive to buy than the shackled one.
    Now I see that the chained Yato costs about PLN 60.
  • #8 17461326
    archanoid
    Help: 76
    Rate: 251
    Hello . First of all, what you will be using the hose for (what will be connected to it). If a gun for blowing or inflating wheels, the diameter may be smaller, e.g. 8mm inside. However, if you want to connect a pneumatic wrench or something with a greater demand for air, the diameter inside is 10mm minimum. As for the hose itself, I recommend that you buy a rubber hose for fuel and oil in the automotive or agricultural industry. I have one myself and the pressure from the 10 atmospheres compressor does not impress it. For example
    this
  • #9 17461714
    grzegorz041
    Help: 7
    Rate: 142
    A blowing and inflation gun will be attached to the hose, but sometimes a maintenance and painting gun (for small items). I do not provide a pneumatic wrench.
    Maybe actually fuel is a good option ..
    I was still looking at one like this; https://allegro.pl/gumowy-waz-pneumatyczny-do-kompresora-10m-10mm-i7523826364.html It's ready, chained ...
  • #10 17468647
    wiesiekmisiek
    Help: 259
    Rate: 525
    Good, but will be a pain at work. If you found one with a smaller diameter, it would be OK. A few years back, I bought a 20-meter silicon casing, reinforced with an internal diameter of 6 mm (the purchase was "useful"), and for two full seasons I use it for the nailer (AN 902). The cross-section is sufficient, the hose is very flexible, it does not break even in frost. Maybe look for this type - but the price will not be low. But for many years.
    Although here you have something similar
    https://allegro.pl/silikonowy-pirect-pneumatyczny-8x12mm-10m-kupczyk-i7570177957.html
  • #11 17468680
    kkknc
    Help: 1916
    Rate: 6721
    Silicone is probably the mold in which it is used.
    I have already written about this type of cable.
  • #12 17468701
    WędkarzStoLica
    Help: 146
    Rate: 301
    I use a gas hose for PLN 2 per 1 meter.
    After a few years, I did not notice any flaws - but I have no idea how he behaves in the cold.
  • #13 17469233
    grzegorz041
    Help: 7
    Rate: 142
    All in all, this convinces me and the silicone one and the gas one ...
  • #14 17522559
    grzegorz041
    Help: 7
    Rate: 142
    I bought an oxygen hose at a bargain price. It's been working very well so far. Thanks to everyone for the hints and commitment.
The discussion revolves around selecting an appropriate compressor hose, specifically a 10-meter length for occasional use. Users recommend various options, including oxygen hoses, armored PVC hoses, and rubber hoses designed for fuel and oil. Concerns about durability in cold weather and flexibility are highlighted, with suggestions leaning towards rubber hoses for better performance. Some users mention specific brands like Semperit and Yato, while others share links to potential purchases. The conversation concludes with the author expressing satisfaction after purchasing an oxygen hose at a good price.
TL;DR: Need a 10 m hose for occasional use? Pick 8–10 mm ID; “the pressure from the 10 atmospheres compressor does not impress it.” Fuel/oil‑rated rubber (~20 bar) or quality PVC/silicone balance price and cold performance. [Elektroda, archanoid, post #17461326]
Why it matters: This FAQ helps DIY compressor owners pick an affordable, frost‑resistant 10 m hose that won’t crack or starve tools.
What hose diameter should I choose for blowers, inflators, or wrenches?
Use 8 mm ID for blowers and tire inflation. Choose at least 10 mm ID for wrenches or other higher‑airflow tools. That sizing avoids starving demanding tools and keeps performance consistent. [Elektroda, archanoid, post #17461326]
Is a plain PVC hose okay for occasional, budget use?
Yes, an armored PVC hose fits light, occasional work. It is light and flexible, which makes handling easy. “Light, cheap, flexible.” The trade‑off is lower resistance to mechanical damage and limited UV resistance, so store it indoors. [Elektroda, teskot, post #17461114]
Will PVC hoses stiffen or crack in frost?
One user warns that ordinary flexible PVC can stiffen after frost. It can turn into a “cat’s tail,” becoming hard and brittle. For regular sub‑zero use, consider silicone or rubber alternatives to avoid cracking. [Elektroda, grzegorz041, post #17461206]
Which hose stays flexible in sub-zero temperatures?
A silicone‑reinforced pneumatic hose stays very flexible in the cold. One user ran a 20 m hose with 6 mm ID for two full seasons on a nailer. He reports it “does not break even in frost.” Expect a higher price, but durable service. [Elektroda, wiesiekmisiek, post #17468647]
Can I use an oxygen/gas-welding hose as a compressor air line?
Yes. A user bought an oxygen hose at a bargain price and reports it works very well for compressor use. It’s a viable option when priced right and properly fitted. [Elektroda, grzegorz041, post #17522559]
Are welding hoses too stiff or bulky for home use?
They can feel stiff and bulky versus PVC or silicone. One user who tried a gas‑welder hose found it “too stiff and bulky.” If handling matters, test before committing to long lengths. [Elektroda, grzegorz041, post #17461006]
Is automotive fuel/oil hose safe and durable for compressed air?
Yes. A rubber fuel/oil hose (example: SAE J30 R6 around 20 bar) is recommended. The poster noted that a 10 atmospheres compressor does not challenge it. Choose the inner diameter that matches your tools. [Elektroda, archanoid, post #17461326]
What affordable ready-made options with couplings are available?
Castorama carried Semperit hose with German quick couplings. The same user saw a chained Yato hose for about PLN 60. He noted building from parts cost more than a ready‑made set. [Elektroda, kkknc, post #17461278]
Are spiral hoses worth paying more for?
Spiral hoses cost more than straight ones. If you choose spiral, buy a good‑quality model. Otherwise, a straight hose offers better value for occasional use. [Elektroda, kkknc, post #17461115]
Can a cheap gas hose work for light compressor tasks?
Yes for light work. One user runs a gas hose at about PLN 2 per meter. After a few years, he reported no flaws. He had not tested it in cold, so winter behavior is unknown. [Elektroda, WędkarzStoLica, post #17468701]
What pressure rating should I choose for an 8–10 atm compressor?
Pick a hose rated well above compressor pressure. The shared fuel/oil hose example is around 20 bar. The author said 10 atmospheres does not impress it, which gives a safe margin. [Elektroda, archanoid, post #17461326]
How do I choose a compressor hose fast? (3 steps)
  1. Match ID: 8 mm for blowers/inflation; 10 mm minimum for air‑hungry tools.
  2. Choose material: rubber hose for fuel/oil is a robust DIY choice.
  3. Verify pressure: around 20 bar rating; “the pressure from the 10 atmospheres compressor does not impress it.” [Elektroda, archanoid, post #17461326]
Does PVC degrade in sunlight or rough use?
Yes. PVC trades low weight and price for durability. It is less resistant to mechanical damage and has limited UV resistance outdoors. Store it out of sun to extend life. [Elektroda, teskot, post #17461114]
Is 10 m a practical length for occasional blowing, inflating, and small painting?
In this thread, the original poster planned blowing, tire inflation, and small painting. He considered a ready‑made 10 m, 10 mm pneumatic hose for that use. That reflects a practical, occasional‑use setup. [Elektroda, grzegorz041, post #17461714]
