Bosch Dishwasher SMV58M70EU50 - Error E22 Explanation & Troubleshooting Guidance
waldek.grom 128982 4
  • #1 16097419
    waldek.grom
    Help: 6
    Rate: 88
    Hello colleagues. I am asking for a hint related to the Bosch dishwasher. Error E22 appears at the end of the washing cycle. Please tell me what it means? Best regards.
    widaw
    Help: 21
    Rate: 173
    The controller receives information that there is still water in the dishwasher.
    Clogged muddy drain, hydrostatic tube. Disassemble, clean all plumbing.
    This is for starters.
    Gretz
    Rate: 38
    :arrow: Error E22 - residual water in the tank, and here's the rest for the future:
    E01 - Power failure. All the codes E01, E02, E03, E04, and E05 indicate a problem with the power supply module.
    E06 - Problems with the door contactor. Check the door switch.
    E07 - Drying fan defective.
    E08 - Low water level in the tank.
    E09 - Error of the heating element (heater).
    E10 - Flow sensor error (poor water flow can lead to overheating of the heating element).
    E11 - NTC is damaged. Damaged cable or safety thermostat.
    E13 - High system inlet temperature (greater than 75?C). If the dishwasher is connected to hot water, this error
    may indicate a temperature sensor fault or the temperature is too high.
    E14 - Water meter defective. Perhaps the pressure in the water supply network is too high.
    E15 - Water in a bowl. The AQUASTOP system has been activated. Eliminate the cause of the water leaks.
    E16 - Faulty inlet valve. Do not fill with water. Check inlet valve (Aquastop).
    E17 - High water level - water meter needs to be checked.
    E18 - The water level is too low - check the water supply valve.
    E20 - Faulty circulation pump. Short circuit or open circuit in the winding pump.
    E21 - The circulation pump is blocked. This can be caused by clogging or poor water pressure in the circulation pump.
    E22 - Residual water in the tank.
    E23 - Faulty drain pump. Drain pump coil shorted or broken.
    E24 - Drain error. Pump failure.
    E25 - Drain pump is blocked or pump cover is missing.
    E26 - Faulty water flow sensor.
    E28 - Turbidity sensor error (aqua-sensor).
  • #4 16097645
    waldek.grom
    Help: 6
    Rate: 88
    Thanks my friend, this is the list I also have but E22 is missing :idea:
  • #5 16097710
    h jaworski
    Home appliances specialist
    Help: 466
    Rate: 717
    After all, you have the E22 error described at the beginning of your friend's post Gretz .
