Bosch Dishwasher SMV53L00EU: Error E-15 Tap, Troubleshooting and Solutions (Cleaning, Reset)
robsfate 20148 9
How do I diagnose and fix Bosch dishwasher error E15 when the machine keeps draining/sucking from the bottom even though there is no visible water in the tray?
E15 means the dishwasher’s anti-flood system has tripped, so the machine is detecting water in the floor tray rather than a problem with the inlet valve or supply hose. Check the bottom pan for water and, if needed, tilt the dishwasher to the left to drain it and then look for the leak that triggered the safety switch [#16765699] [#16768848] [#16769026] If there is no water in the tray and no visible leakage under the dishwasher, inspect the wires and connectors to the flood switch/safety circuit [#17448700]
  • #1 16765171
    robsfate
    Rate: 9
    As in the description - the dishwasher at the end of the cycle "had", displays the message and that's it. I found in the forums a way to dismantle the left side, where I found a mechanism containing a "siphon" with a sleeve in the middle. After unplugging it and disassembling the entire tank - I rinsed it with hot water and liquid using a shower hose without a "headphone". After almost a hour of rinsing, I brought the whole tank practically to the state of novelty. The strainer in the solenoid valve is clean. After turning on the equipment, the message is repeated. The dishwasher sucks the water all the time, which does not exist anyway. I tried to turn on the program reset but the dishwashers still had and try to siphon the bottom (in the filter in the floor). It seems to me that after starting the program, the hose from the water valve through the solenoid valve to the supply hose should get stressed from the water pressure but I miss this phenomenon. I am asking for suggestions on how to check whether the above mentioned valve works, how to replace it, and of course, for advice on where to look for the fault and how to eliminate it. Best wishes and thanks in advance.
  • #2 16765699
    Piotr2608
    Help: 851
    Rate: 4487
    E15 - Water collection system error - Active safety switch on the floor tank - Check the cause of the water in the floor tank
    ZimTech Piotr Zimny
  • #3 16766111
    robsfate
    Rate: 9
    As I wrote above - "the dishwasher is trying to pull from the bottom tank, although this water is not there" and that's why I thought about the hose supplying the dishwasher with water from the network, but if it can help - how to diagnose the tank safety switch?
  • #4 16768848
    Piotr2608
    Help: 851
    Rate: 4487
    How can a dishwasher take water from the dishwasher?
    The anti-flood system worked, you probably have a leak and water under the dishwasher.
    ZimTech Piotr Zimny
  • #5 16769026
    mario151515
    Rate: 24
    Tilt to the left side and pour water from the dishwasher floor, find a leak.
  • #6 16769120
    robsfate
    Rate: 9
    I will try and let you know how it went
  • #7 17446661
    gajek1981
    Rate: 8
    The Siemens SR65M030EU / 14 dishwasher showed an error E: 15 - protection against flooding - So the scheme of conduct as above.
    In addition, the mouse chewed on my cable, and I was afraid that it was just because of this that I had a mistake :)
  • #8 17448192
    mario151515
    Rate: 24
    But are there any signs of flooding the swimmer?
  • #9 17448627
    gajek1981
    Rate: 8
    There is nothing, no traces of flooding, leakage under the dishwasher.
    Swimmer, I do not know where it is ???
  • #10 17448700
    Piotr2608
    Help: 851
    Rate: 4487
    E15 is a problem with filling the dishwasher and now: if there is no water in the tray, there are no leaks,
    check the wires and connectors.
    ZimTech Piotr Zimny
The Bosch Dishwasher SMV53L00EU is experiencing an E-15 error, indicating a water collection system issue, likely due to the anti-flood safety switch being activated. Users suggest checking for water accumulation in the floor tank and diagnosing potential leaks. The author has already cleaned the siphon mechanism and solenoid valve but continues to face the error, indicating that the dishwasher is attempting to siphon water that is not present. Recommendations include tilting the dishwasher to check for leaks and inspecting the wiring and connectors for faults. The discussion also references a similar issue with the Siemens SR65M030EU/14 model, highlighting common troubleshooting steps for E-15 errors.
