Bosch SRS55M78EU Dishwasher - Error Code E24 & Tap Symbol: Causes & Solutions
minstal 240844 9
Why does my Bosch SRS55M78EU dishwasher show E24 and the tap symbol, and need repeated power cycles to start?
E24 indicates a drain problem: the pump is blocked or the drain path is choked. Check the drain pump compartment, the pump chamber, and the flap on the pump, and make sure the drain is completely clear [#6774372][#6774503] Several users fixed it by removing foreign objects from the pump/impeller such as a toothpick, a stone, or wires caught under the inner rotor cover [#14118188][#18742757] One case was caused by a detached gray horseshoe-shaped plastic part near the strainer that had moved into the impeller area; after removing the obstruction and cleaning out debris, the dishwasher worked normally again [#16234324] Cleaning the filter/strainer inside the dishwasher is also worth doing, as it may clear the blockage [#18742757]
  • #1 6772202
    minstal
    Rate: 47
    Recently, the dishwasher has started to go crazy, displays the code E: 24 and the tap symbol lights up. I have to turn it on and off several times, including removing the power plug, to make it click.
    What could it be?
  • #2 6772240
    beba
    Rate: 28
    Hello, I had a similar error in Hoover, cleaning the filters on the water supply helped, it may be too low water pressure, I also encountered this. I personally clean all filters and 98% helps.
  • #3 6772310
    minstal
    Rate: 47
    The strainer on the AquaStop is clean. The water pressure does not change in such a short time.
    Does the location of the AquaStop (horizontal / vertical) matter? For me it is horizontal from the beginning, but the problem appeared only now.
    birre
    Help: 38
    Rate: 469
    E 24 is a water drain error, pump blocked or poor drain - choked.
  • #5 6774503
    minstal
    Rate: 47
    Confirmed by Bosch service:
    There may be several reasons for this
    - drain not completely clear
    - pump chamber obstructed
    - incorrectly positioned flap on the pump.
    Please check the drain pump compartment in accordance with the operating instructions.
    Now it went without a sensation, but you already know what's going on.
  • #6 14118188
    godeksik
    Rate: 33
    Welcome,
    I wanted to share my experiences
    I also had an e-24 error (drain).
    The dishwasher hummed as it washed, the voice tapping against the spokes of a bicycle :)
    Thanks to the electrode people, I got into the pumps.
    The smaller one had a seed in the gears, but that was not the reason.
    The bigger one had a stuck toothpick and a big stone, they were tapping it.
    dishwasher Siemens SN56M580EU.
    if someone is struggling with removing the underside, I suggest:
    - unscrew the bottom sheet metal panel - two screws (exactly below the door on the front)
    - unscrew the side walls (two screws in the seal)
    - put the dishwasher on the back (note, there may be some water)
    - in the upper part of the bottom, on both sides, you will see one latch, you just need to move it with a screwdriver
    - there is a bent soft plate in the lower part, you need to straighten it
    - in the very center of the bottom there are two latches, loosen both and push them inside
    - now we gently pull the bottom, looking if something is still holding
    - watch out for snakes, water will fall when they fall
    thank you to everyone who contributes here
    I became a hero in my home :D :D :D
    Mariusz
  • #7 16234324
    gksm
    Rate: 25
    Hello, I also had a code 24 (E24) on the display and constant water in the dishwasher, it did not want to drain.
    For me, there is a small plastic near the strainer where the dishwasher filter (probably during the last selection of food waste). Such a gray horseshoe-shaped plastic.
    In my opinion, it detached itself when cleaning the strainer recently and after a dozen or so washes it probably moved to the impeller responsible for the drainage of water. When the rotor is blocked, an E24 error has probably popped up regarding problems with water drainage.
    After selecting the water, cleaning it from waste (by the way of failure) and inserting a horseshoe-shaped plastic (such a flat, approximately 7 centimeter plastic), I did a RESET (hold the START button for 3 seconds, time 001 appears and you close the dishwasher for 1 minute).
    After the complete and reset, the Bosh dishwasher works beautifully without calling a service technician, wasting time and money.
    best regards
  • #8 18142417
    Fixxxer1
    Rate: 61
    Digging out - is there an emergency water drain in the dishwasher? I chose what did not drain, checked the pump impeller, and would now like to drain the rest of the water from the system to the sewer. Is there any option to run the pump for a short time?
  • #9 18142455
    Ssaab
    Help: 16
    Rate: 54
    https://en.dream-home-ideas.com/27536-how-to-drain-water-from-the-dishwasher-bosch
    So in turn
    Select a program on the control panel to drain the water.
    Wait for the machine to start it.
    Disconnect the power to the dishwasher.
    Turn off the water supply and remove the hoses.
    On the right wall of the dishwasher there were rags on the floor.
    We unscrew the garbage filter and the salt reservoir cover.
    Gently tilt the device on the right side. Some water may still run off.
    We drag the dishwasher to a warm, well-ventilated place and open the door to let the machine dry inside.
  • #10 18742757
    leonada
    Rate: 27
    In my dishwasher, it was enough to clean the filter from the inside. Remove the plastic rotor cover from the inside of the dishwasher, and take out the wires there, which I don't know where they came from, but the problem is gone.
The Bosch SRS55M78EU dishwasher is experiencing an E24 error code, indicating a water drain issue, often associated with a blocked pump or poor drainage. Users suggest checking and cleaning filters, the AquaStop strainer, and the pump chamber to resolve the issue. Some have reported that debris, such as food particles or small objects, can obstruct the pump, leading to the error. Solutions include cleaning the internal filter, ensuring proper water drainage, and performing a reset of the dishwasher. Additionally, users have shared methods for manually draining water from the system if necessary.
