Selecting the Right Speed Class for a 16GB Memory Card for PSP 3004: SD or Micro SD?
wik192 28059 9
Which 16GB card format and speed class should be used in a PSP 3004 for fast game loading?
Use a 16GB microSD/microSDHC card in a Memory Stick Pro Duo-compatible adapter, preferably Class 10; a regular SD card will not fit the PSP's native slot [#16136492] [#16136746] The adapter is the necessary way to use microSD cards without modifying the console [#16136764] The replies suggest that differences between speed classes may not be very noticeable in practice, but Class 10 is the recommended choice [#16136481] [#16136492]
  • #1 16136099
    wik192
    Hello, I have a psp 3004 and I want to buy a 16gb memory card. And here I have a question, what speed class must the card have so that games launched from it do not cut and load quickly. Is it better to buy a regular SD or a micro SD with an adapter?
    https://saturn.pl/foto-i-kamery/card-memory-s...tm_medium=cpc&utm_term=ceneo&utm_campaign=xml
    Will something like this be ok?
  • #2 16136481
    PCG_PL
    Help: 10
    Rate: 8
    I don't think you notice any difference between the classes.
  • #3 16136492
    macgyver96
    Help: 31
    Rate: 65
    First of all, memory stick pro duo cards are included in the psp, not sd / micro sd. There are microSD adapters on the market, and it is best to take a class 10 card, which has become very cheap recently and there is no point in wasting your life on loading screens.
  • #4 16136619
    wik192
    So the one I put in won't fit?
  • #5 16136746
    macgyver96
    Help: 31
    Rate: 65
    No, unless you plan to modify the card slot, you can convert the psp to sd cards, but it's a higher school of driving.
  • #6 16136764
    arnoldziq
    Help: 789
    Rate: 300
    A colleague must buy something like the one in the picture and the appropriate micro SD cards. You can choose cards as you wish. In my experience, both cards don't even have to be the same size.
  • #8 16142750
    wik192
    So how, because I don't know which one to order?
  • #9 16170496
    xSzwagier
    Help: 35
    Rate: 72
    take the other one. But go to MediaMarkt, they have cheaper there ;)
  • #10 17091611
    szalony1
    Rate: 46
    memory stick to micro ds card adapter the cheapest option
The discussion centers around selecting a suitable 16GB memory card for the PSP 3004, specifically addressing the speed class and type of card (SD vs. microSD with an adapter). Users recommend opting for a Class 10 card to ensure fast loading times and minimal lag during gameplay. It is noted that the PSP 3004 uses Memory Stick Pro Duo cards, and while microSD cards can be used with an adapter, modifications to the card slot are not necessary for standard use. Users also share links to potential card options and suggest checking local retailers for better prices.
