Chomikbox Fails to Launch on Windows 7 x64: Reinstalling & Chomikuj Technical Support Issues
headshot 4083 8
  • #1 16165717
    headshot
    Help: 32
    Rate: 128
    Hello, I have a problem with this program, it suddenly stopped starting overnight, I tried reinstalling in various places and it did not help. Chomikuj technical support is spreading his hands. What could be wrong ?
  • #2 16168254
    Adamek161
    Help: 5
    Try uninstalling again (you can try IObit Uninstaller , by the way, removes the remnants of the program), clean the registry (e.g. Glary Utilities , you can also look for some on the internet) and install the beta version of the chomikbox. If it still doesn't work, wait a while, don't turn it off, an update window should pop up, then maybe it will work fine.
  • #3 16168983
    headshot
    Help: 32
    Rate: 128
    I cleaned the registers and nothing gave betaversion, I can not download because the current version is downloaded immediately.
  • #4 16169054
    Adamek161
    Help: 5
    Or maybe some antivirus is blocking? Try shutting down for a while and reinstalling.
  • #5 16169255
    headshot
    Help: 32
    Rate: 128
    I have microsoft essential and it's not his fault, I had such a situation before and after some time I don't know why the program started working. Now it doesn't work at all and it has been going on for a long time.
  • #6 16170157
    Adamek161
    Help: 5
    Try to enable as administrator (right click).
  • #7 16170209
    headshot
    Help: 32
    Rate: 128
    I've tried everything already.
  • #8 16170358
    Adamek161
    Help: 5
    Check that the firewall or firewall is not blocking the Internet access to the hamster box
  • #9 16170373
    headshot
    Help: 32
    Rate: 128
    Did you read the post above ?! Thanks for such advice.
The discussion revolves around issues with the Chomikbox application failing to launch on Windows 7 x64. The user reports that the program stopped working suddenly and attempts to reinstall it have been unsuccessful. Suggestions from other participants include using IObit Uninstaller to remove remnants of the program, cleaning the registry with tools like Glary Utilities, and trying a beta version of Chomikbox. There are also recommendations to check if antivirus software or firewalls are blocking the application. The user has already attempted several solutions, including running the program as an administrator, but the issue persists.
