How to Fix Error 0xc00007b on Windows 7 Ultimate SP1 64-bit: Solutions & Troubleshooting Tips
poszukiwaczpracy1 5679 4
  • #1 17028513
    poszukiwaczpracy1
    Rate: 9
    Windows 7 Ultimate SP1 64 bit
    • Addition.txt (77.33 KB) You must be logged in to download this attachment.
    • FRST.txt (56.47 KB) You must be logged in to download this attachment.
  • #2 17028551
    atomic99
    Help: 171
    Rate: 338
    First it is served complete computer configuration affected by the problem.
    Download and install all available Windows updates, and install [.NET framework 4.5.1] + updates.
    Download and install all [Visual C ++] packages that I added in this topic:
    https://www.elektroda.pl/rtvforum/topic3398939.html#16831596
    Update your graphics drivers.
  • #3 17028768
    poszukiwaczpracy1
    Rate: 9
    I have the version installed
    Microsoft Visual C++ Redistributable Package 2017 14.10.25008
    but the latest version is
    Microsoft Visual C++ Redistributable Package 2017 14.12.25810
    whether you need to install a newer one and whether I slide that slide first and install it on myself. Is the newer version always better. Could it be that some program will want an older version
    Added after 19 [minutes]:
    had it reinstalled via
    Visual C++ Runtime Installer (All-In-One) v56
    https://www.dobreprogramy.pl/Visual-C-AIO,Program,Windows,85825.html
    but here's a bit older version
    http://www.softpedia.com/get/Programming/Components-Libraries/Visual-C-Installer-Uninstaller.shtml
  • Uninstall eboostr to fix the error
    #5 17029165
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    It is not necessarily an infection, eboostr is a program that the Author installs at his own request (although sometimes it is related to the lack of reading messages - as accompanying soft for some other software).
    As for this one problem, if it is possible to uninstall in the control panel -> Programs and Features eboostr this will probably solve the problem. Considering that such garbage was installed on the computer - it may be worth uploading the full FRST log, there may be more garbage.
