- Using SLE-4428 Magnetic Stripe Smart Card or UID Changeable IC Card for Windows Login
kamilalek1 9735 9
Can I use an SLE-4428 magnetic stripe smart card or a UID-changeable IC/NFC card to log in to Windows with smart-card authentication?
Not as a normal Windows smart-card logon card: the listed cards are described as memory cards with protected EEPROM, not typical microprocessor smart cards with cryptographic functions and certificate management [#16168111] Windows smart-card login needs a proper microprocessor card, a suitable reader, and software/middleware that supports smart-card authentication [#16166467][#16174152] One example given that does work is a Carbon card used with PKI World Championship (ADCA) for workstation logon [#16190735] If you use third-party tools such as mysmartlogon or Aloaha, they may provide an alternative login method, but one reply warned that this can behave like keyboard emulation rather than secure certificate storage on the card [#16189641]
  • #1 16166356
    kamilalek1
    Rate: 41
    If I buy any of the following cards, can I use it in windows as a login using a smart card.
    CHIP
    https://pl.aliexpress.com/item/10-pcs-lot-Con...073_10102_10096_10052_10050_10107_10051_10106, searchweb201603_0, afswitch_5 & btsid = 55a024c3-6206-45d2-bc18-23a4b8ba2d43
    NFC
    https://pl.aliexpress.com/item/5pcs-UID-IC-ca...-S50-MF1-libnfc-RFID-13/32480648720.html?spm= 2114.010108.3.320.70Al6k & ws_ab_test = searchweb0_0, searchweb201602_0_10065_10068_10000009_10084_10083_10080_10082_10081_10060_10062_10056_10055_10054_10059_10099_10078_10079_426_10103_10073_10102_10096_10052_10050_10107_10051_10106, searchweb201603_0, afswitch_5 & btsid = e8693707-cf73-4d09-9031-126168ede794
    or
    https://pl.aliexpress.com/item/White-10Pcs-Pa...-RFID-Readable-Writable/32605721999.html?spm= 2114.010108.3.58.70Al6k & ws_ab_test = searchweb0_0, searchweb201602_0_10065_10068_10000009_10084_10083_10080_10082_10081_10060_10062_10056_10055_10054_10059_10099_10078_10079_426_10103_10073_10102_10096_10052_10050_10107_10051_10106, searchweb201603_0, afswitch_5 & btsid = e8693707-cf73-4d09-9031-126168ede794
  • #2 16166467
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    it is possible.
    However, you need a proper reader of these cards along with the software that will enable alternative login.
    For example, I have a notebook with a fingerprint reader, the appropriate software allows you to log in by entering a password or by dragging your finger through the sensor (previously I had to enter all acceptable fingerprint patterns during installation).
  • #3 16168111
    is-smok
    I'm afraid not. You may be able to store your certificate and keys on them, but it's not the same. Rather, they are memory cards, simply having a certain amount of secure (pin protected) eeprom memory. They do not have a processor responsible for cryptographic functions, key generation and certificate management. So these are not typical smart cards. I've never played NFC, only contact cards, but it looks like you'll have the same problem with them.
    Dragon.
  • #4 16173556
    kamilalek1
    Rate: 41
    If you cannot use capacitive cards to log in to windows, then where can you buy cards that are suitable for that.
    Somehow, I can't find a microprocessor card on aliexpress
    I am interested in buying about 10-20 pieces of cards.
  • #5 16174152
    is-smok
    I do not know how the case looks quantitative (do they sell small quantities), I also did not want to do surreptitious advertising, but since you ask ... I bought my test cards at CryptoTech in Krakow: http://www.cryptotech.com.pl/. I can recommend them as implementation partners.
    You must also be aware that in addition to purchasing cards, you will need to implement (if you do not already have) AD (or other network system supporting login with a smart card) and PKI in your network. I have not heard of the fact that smart card login can be implemented on self-signed certificates (besides, it makes average sense outside the laboratory environment).
    Dragon.
  • Seeking secure free alternative to MySmartLogon
    #6 16189641
    kamilalek1
    Rate: 41
    https://www.mysmartlogon.com/nfccsp/
    I am looking for the best free alternative to the above program.
    from what I understood, the windows server has the built-in ability to use only chip cards with a microprocessor, the price of the cards is about PLN 75 and it does not support proximity cards, e.g. MFare or capacitive chip cards.
    Here you need to look for alternatives in the style of aloaha or mysmartlogon.
    The price for mysmartlogon is 15 euros for one computer while aloaha is about 230 zlotys, i.e. acceptable
    However, I have a big reservation about security
    I am not sure, but aloaha, I probably simulate a keyboard, i.e. I put the card on and the data are entered in plain text, i.e. the certificate is not stored on this card.
    @ is-smok - I tried to contact cryptotech but they do not answer the phone, could you reveal how much you paid for the card for testing and possibly provide the model of this card and information whether you used it to log in to windows using windows software
  • #7 16190735
    is-smok
    Unfortunately I can't give you the price. The card model is Carbon. It has both a qualified and non-qualified signature element. Yes, it works without any problems with the PKI World Championship (ADCA), also in terms of logging into workstations.
    Dragon.
  • #8 16269231
    tomas69
    I have a question for you regarding logging in using a wifi network card, the point is that I created the .crt certificate and the key .key, if downloading the certificate is not a problem, I am not able to upload the key to the smartcard.
    I need to upload the wifi key, but I have a problem with it, so I decided to check my other openvpn, ipsec certificates and certificates imported correctly, but the keys do not. Does anyone have an idea how to solve this dilemma?
    PS.
    Certificates and keys are generated using openssl, maybe in the case of smartcard, you need to generate them differently, but I found nue on the internet.
  • #9 16273850
    is-smok
    I didn't play with openssl certificates, but in Windows CA there is such a function as "mark the key as exportable" in the certificate template. Maybe there is something like this here? The key import is done via the card's middleware and you may need to look for something in the software's documentation.
    Dragon.
  • #10 16342161
    lehastar
    Help: 19
    Rate: 21
    Software Required. I used a program that locks / unlocks the computer. It is associated with the access control system. I left the room - the computer is locked.
The discussion centers around the feasibility of using SLE-4428 Magnetic Stripe Smart Cards and UID Changeable IC Cards for Windows login. Users express that while it is possible to use smart cards for login, the cards in question lack the necessary cryptographic capabilities, as they are primarily memory cards without processors for key management. Recommendations include acquiring proper smart cards with microprocessors and implementing a Public Key Infrastructure (PKI) system for secure login. Users also inquire about suitable vendors for purchasing such cards and mention software alternatives for managing smart card logins. The importance of using qualified smart cards for secure authentication is emphasized.
