Loewe Connect 26 SL - Vestel 17mb71 TV: Resetting Issue, Console Error, and Firmware Update Process
satanistik 14091 7
  • #1 16167748
    satanistik
    Help: 61
    Rate: 762
    TV as in the subject:
    Loewe Connect 26 SL
    chassis mb180
    from the album:
    V2210 MB71
    17mb71-4
    The problem was that the TV was resetting - there was some strange error in the console (a lot of digits and something like a stack error).
    I found the file to update, but it was impossible to enter the update menu, but autorun.sh was missing in the console.
    The file was renamed and after changing it got up, but only the kernel is updated and then it crashes:
    STARTING UPDATE
    Updating Kernel [mtd2]
    Kernel update complete
    Updating Kernel Initrd [mtd3]
    Kernel initrd update complete
    Updating RootFS [mtd4]
    RootFS update complete with squashfs file sytem
    JFFS2 doesn't use OOB.
    Empty flash at 0x00260850 ends at 0x00261000
    Empty flash at 0x00261f64 ends at 0x00262000
    Empty flash at 0x00262aac ends at 0x00263000
    Empty flash at 0x00263b50 ends at 0x00264000
    Empty flash at 0x00264b50 ends at 0x00265000
    Empty flash at 0x00265b50 ends at 0x00266000
    Empty flash at 0x00266b50 ends at 0x00267000
    Empty flash at 0x00267b50 ends at 0x00268000
    Empty flash at 0x00268b50 ends at 0x00269000
    Empty flash at 0x00269b50 ends at 0x0026a000
    Empty flash at 0x0026ab50 ends at 0x0026b000
    Empty flash at 0x0026bb50 ends at 0x0026c000
    Empty flash at 0x0026cb50 ends at 0x0026d000
    Empty flash at 0x0026db50 ends at 0x0026e000
    Empty flash at 0x0026eb50 ends at 0x0026f000
    Empty flash at 0x0026fb50 ends at 0x00270000
    Empty flash at 0x00270b50 ends at 0x00271000
    Empty flash at 0x00271b50 ends at 0x00272000
    Empty flash at 0x00272b50 ends at 0x00273000
    Empty flash at 0x00273b50 ends at 0x00274000
    Empty flash at 0x00274b50 ends at 0x00275000
    Empty flash at 0x00275b50 ends at 0x00276000
    Empty flash at 0x00276b50 ends at 0x00277000
    Empty flash at 0x00277b50 ends at 0x00278000
    Empty flash at 0x002793a0 ends at 0x00279800
    Empty flash at 0x0027b3a0 ends at 0x0027b800
    Empty flash at 0x0027cba0 ends at 0x0027d000
    Empty flash at 0x0027e3a0 ends at 0x0027e800
    Empty flash at 0x0027f3c0 ends at 0x0027f800
    Empty flash at 0x002e1a30 ends at 0x002e2000
    Empty flash at 0x002e29f8 ends at 0x002e3000
    Empty flash at 0x002e3c24 ends at 0x002e4000
    Empty flash at 0x002e4b60 ends at 0x002e5000
    Empty flash at 0x002e5c24 ends at 0x002e6000
    Empty flash at 0x002e6b88 ends at 0x002e7000
    Empty flash at 0x002e7818 ends at 0x002e8000
    Empty flash at 0x002e8c24 ends at 0x002e9000
    Empty flash at 0x002e9c24 ends at 0x002ea000
    Empty flash at 0x002eac24 ends at 0x002eb000
    Empty flash at 0x002ebc24 ends at 0x002ec000
    Empty flash at 0x002ecb60 ends at 0x002ed000
    Empty flash at 0x002eebe8 ends at 0x002ef000
    Empty flash at 0x002f00cc ends at 0x002f0800
    Empty flash at 0x002f18cc ends at 0x002f2000
    Empty flash at 0x002f30cc ends at 0x002f3800
    Empty flash at 0x002f48cc ends at 0x002f5000
    Empty flash at 0x002f589c ends at 0x002f6000
    Copy ExtraPictureSettings files to tmpfs.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x0011e800:
    read 0xa9d6fb3d, calculated 0x57d620a3.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002c9000:
    read 0x44b9caf4, calculated 0x46e66795.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002d7800:
    read 0xcba612bb, calculated 0x9f6d95a7.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002d2800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002c6800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x0029a800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00290000:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00287800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00285800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002ec800:
    read 0x300ae7ef, calculated 0x45e5ff77.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002e4800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002cc000:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002c7800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x000ff000:
    read 0x7c140f56, calculated 0x6cef8ca6.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x000df000:
    read 0x36c78524, calculated 0xa275aa74.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002dc800:
    read 0x93c55f64, calculated 0x890a5f07.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002d1800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00298800:
    read 0x93c55f64, calculated 0x38b5746.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00283800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00262800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x001cc000:
    read 0x6fbdca42, calculated 0x7c05c0ee.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00195800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00261800:
    read 0xd45c197b, calculated 0xf4cb1c09.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x000ee800:
    read 0xa8eb9ed, calculated 0x8512a9d5.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x000de000:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x0006b000:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00064800:
    read 0x2c51d10e, calculated 0xfe765bd8.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002de800:
    read 0xc65b130a, calculated 0x5b7801e1.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002db800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00293000:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00284800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00277800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00276800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00275800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00274800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00273800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00272800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00271800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00270800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x0026f800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x0026e800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x0026d800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x0026c800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x0026b800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x0026a800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00269800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00268800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00267800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00266800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00265800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00264800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x00263800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002f5800:
    read 0x24aeb5d0, calculated 0xaecc1f53.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x001dd000:
    read 0xe0f47c4d, calculated 0x175a7bb1.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002f7000:
    read 0xab95af61, calculated 0x28b57fa5.
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002f4000:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002f2800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002f1000:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002ef800:
    JFFS2 notice: (359) check_node_data: wrong data CRC in data node at 0x002ee000:
    read 0xab95af61, calculated 0xfc719335.
    JFFS2 warning: (359) jffs2_do_read_inode_internal: Truncating ino #50 to 34992 b
    ytes failed because it only had 32768 bytes to start with!
    JFFS2 notice: (359) read_dnode: node CRC failed on dnode at 0x0a4fc0: read 0xfff
    fffff, calculated 0x7f89a010
    "default_settings.img" not found - settings will not be updated
    Copy tmpfs ExtraPictureSettings file to [mtd6]
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x0011e800:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x002c9000:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x002d7800:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x002d2800:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x002c6800:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x0029a800:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x00290000:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x00287800:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x00285800:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x002ec800:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x002e4800:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x002cc000:
    JFFS2 notice: (364) check_node_data: wrong data CRC in data node at 0x002c7800:
    Splash will not be updated
    Discretix DRM Data will not be updated
    [mtd5] : erase all...
    Copy database files to tmpfs.
    [mtd7] : erase all...
    Copy database backup files to tmpfs.
    [mtd8] : erase all...
    Copy tmpfs db files to [mtd7]
    Copy tmpfs db backup files to [mtd8]
    Empty flash at 0x002f78cc ends at 0x002f8000
    Updating MHP! [/dev/mtd9]
    MHP! update complete
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x0011e800:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x002c9000:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x002d7800:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x002d2800:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x002c6800:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x0029a800:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x00290000:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x00287800:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x00285800:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x002ec800:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x002e4800:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x002cc000:
    JFFS2 notice: (397) check_node_data: wrong data CRC in data node at 0x002c7800:
    Anyone have a repair program for this platform?
    There may be a different version.
    After installing the software from Loewe, I have:
    vcm_nvram_read[/mnt/settings/tune/bti_p.dat]: address = 0, read only 32768 of 34992
  • #2 16210284
    ssss
    Help: 470
    Rate: 1802
    Enter your current software number.
    Do you know the software upload procedure? Because if you don't, you'll damage the TV.
  • #3 16263186
    ssss
    Help: 470
    Rate: 1802
    The latest firmware for MB180 chassis.
    If someone hasn't uploaded the software yet. Please familiarize yourself with the order of loading the software first, because you can damage the TV. The zip contains software and bootloader.
    • MB180_V316_V77_V78_V8.zip (32.01 MB) You must be logged in to download this attachment.
  • #4 16287984
    satanistik
    Help: 61
    Rate: 762
    I do not understand my friend's answer - the TV came to me with a damaged firmware - the disc starts, but there were errors in the terminal and no image on the matrix. So you can't choose anything from the menu etc.
  • #5 16289324
    Renso
    Help: 11
    Rate: 77
    I don't understand something either. Colleague @ssss clearly wrote that the zip file contains soft and bootloader. The attached instruction gives two ways to update: with and without bootloader. Did the author of the topic unpack the zip and read this manual?
  • #6 16289697
    satanistik
    Help: 61
    Rate: 762
    I translated this text because I don't know German, but the description concerns updating the bootloader - that is, the content of such a small SPI memory on the board. There is a binary and a script that saves it.
    According to the description, the bootloader is updated after updating the firmware.
    In order for the main firmware to start updating, you must automatically remove the "-disabled" part from the autorun-disabled.sh file name.
    When you plug in a USB drive, the software looks for that file (something like autorun.sh not found).
    The update process starts - but it ends up writing to memory.
    Of course, all this can be seen by soldering the USB/UART adapter in a low-voltage standard to the TP points on the board.
    I do not recommend connecting USB/RS232 vias or directly to RS232, because you can damage the board (voltage levels +/-15V).
  • #7 16290038
    ssss
    Help: 470
    Rate: 1802
    If the TV has no picture, it is a fault, not the fault of the software. 99% of the boards I've repaired have cold solders under the CPU. What I did? You should remove the heatsink and give a lot of soldering liquid and then solder the processor with hot air. 99.9% helps. At the same time, on the other side of the board, there is the L8 coil, which should also be soldered.
  • #8 16290090
    satanistik
    Help: 61
    Rate: 762
    Well, in Vestel it is different - I have experience with the 17mb61 platform, where I managed to work it out somehow.
    Sometimes there is an error of some partition in the console - the system boots up, but the mounting of the partition fails, and later the files are missing.
    In general, NAND chips can get bad blocks.
    Another time the TV did not start and there was a communication error with the tuner in the console - replacing the head helped here.
    In this case, there are errors, but quite incomprehensible - it is possible that there is no contact on the RAM bus and this hangs the system.
✨ The discussion revolves around issues with the Loewe Connect 26 SL TV, specifically related to resetting problems, console errors, and firmware update processes. The user reports a stack error and difficulties accessing the update menu due to a missing autorun.sh file. Responses emphasize the importance of following the correct firmware upload procedure to avoid damaging the TV. Suggestions include checking the software number, using a zip file containing the software and bootloader, and ensuring the bootloader is updated correctly. Additionally, hardware issues such as cold solder joints under the CPU and potential NAND chip failures are discussed as possible causes for the lack of picture and other errors. The conversation highlights the need for careful handling of firmware updates and hardware repairs.
