Seeking Software for Telefunken 43 Inch TV with Vestel 17MB110 Main Board Reset/Update
rakeshsukhpreet 6906 10
How can I find the correct reset/update software for a Telefunken 43-inch TV with a Vestel 17MB110 main board that only flashes a red light?
To get the correct reset/update software for this Telefunken TV, you need the exact TV model and the panel/matrix code, not just the Vestel 17MB110 board [#20124845][#20124870] The panel code is on a sticker inside the TV and should start with VES430 [#20126796] The model was identified as 43TFN-SFVPFHD, and the panel code found was VES430UNDA-2D-N12 [#20126605][#20126815] No firmware file was actually provided in the thread, and one reply asked for the NAND contents for further diagnosis [#20155829]
  • #1 20124563
    rakeshsukhpreet
    Hello I'm looking to reset/update my Telefunken 43 inch TV that has a Vestel 17MB 110 main board, TV turns on but only flashes red light. Does anyone have the software for it please?
  • #2 20124845
    Michał99
    Help: 140
    Rate: 345
    The matrix type should be specified
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    Give your friend the exact tv model, matrix model.
  • #4 20125578
    jeloi
    Help: 285
    Rate: 597
    VES430UNDL-2D-N12 ?
  • #5 20126605
    rakeshsukhpreet
    i attached photo, tv model is 43TFN-SFVPFHD. Where do i find matrix number? this is the tvhttps://www.123pricecheck.com/p/electronics/telefunken-43tfn-sfvpfhd-full-hd-1080p-smart-43-in/b01m1rhbkx.html
    Seeking Software for Telefunken 43 Inch TV with Vestel 17MB110 Main Board Reset/Update Seeking Software for Telefunken 43 Inch TV with Vestel 17MB110 Main Board Reset/Update Seeking Software for Telefunken 43 Inch TV with Vestel 17MB110 Main Board Reset/Update
    billobirillo
    Help: 338
    Rate: 797
    there is a sticker inside the tv: panel code should start with VES430
  • #7 20126815
    rakeshsukhpreet
    Where do I find matrix number?
    yes I found it now, it says VES430UNDA-2D-N12
    jeloi wrote:
    VES430UNDL-2D-N12 ?
    VES430UNDA-2D-N12
  • #8 20134211
    rakeshsukhpreet
    nobody has the software?
  • #9 20155829
    vadim3008
    Rate: 13
    ни у кого нет софта?
    Can you show the contents of nand?
  • #10 20438508
    WhiteWolfHellas
    Hello, I have the exact same problem and I need the firmware update file please.
  • #11 21370513
    maikwelle104
    elmo071 wrote:
    Give your friend the exact TV model, matrix model.
A Telefunken 43-inch TV with a Vestel 17MB110 main board exhibits a red light flashing issue and requires a reset or firmware update. The exact TV model is 43TFN-SFVPFHD, and the panel (matrix) model identified inside the TV is VES430UNDA-2D-N12. Participants emphasize the importance of specifying the matrix type and exact TV model to locate the correct software. Requests for the firmware update file remain unanswered, and no software has been provided. Suggestions include verifying the NAND contents for further diagnostics.
