DEFRO OPTIMA KOMFORT PLUS Boiler: Ideal Temperature for 0°C Outside, 2 Weeks Continual Use
jacek_0707 16155 9
What boiler controller temperature should I set for a DEFRO OPTIMA KOMFORT PLUS with about 0°C outside, and is 37–40°C too low for continuous operation for two weeks?
Set the boiler temperature fairly high all the time, around 60–70°C, and regulate room heat separately with a 3-way valve; 37–40°C is too low and can make the boiler run inefficiently and be more prone to low-temperature corrosion [#16170025][#16169845] For wood and coal, higher boiler temperatures are preferred because they improve efficiency and keep the return temperature high enough [#16169845] If the house gets too warm, use proper hydraulic control rather than lowering the boiler temperature too much [#16169845][#16170025]
  • #1 16169440
    jacek_0707
    Rate: 60
    Good morning,
    DEFRO OPTIMA KOMFORT PLUS boiler. Single-family house.
    What temperature should be set on the controller if we have about 0 degrees outside?
    For example, is 37-40 too little for continuous boiler operation for 2 weeks?
    Should I increase the temperature on the controller from time to time?
    Someone said the temperature should be set to 50 all the time.
    I am asking for a hint.
    Four-way valve enables high-efficiency boiler operation without overheating
    #2 16169845
    marek49ae
    Help: 57
    Rate: 254
    The right temperature is one that ensures thermal comfort for users, one that is optimal for the boiler and optimal for burning the fuel used. Wood and coal burning preferably high temperatures (the highest efficiency of the boiler), and we have a sufficiently high return temperature. But in many cases it will be too hot at home, then the solution is to use a four-way valve. 37-40 degrees is the temperature of fuel pickling, little heat, the fuel also decreases, the furnace does not work efficiently, it is most susceptible to low-temperature corrosion which shortens its life.
    Maintain 60–70°C boiler temperature with a 3-way valve
    #3 16170025
    Sono2020
    Help: 36
    Rate: 146
    Exactly on the boiler you should keep the temperature quite high all the time around 60-70C for the boiler the best but you should have how to regulate the temperature in the apartment e.g. through a 3D valve (not 4D I do not recommend). Write something more about installation and we will help you, I suppose you have a boiler that is too big for your home.
    Make an OZC on the website and provide a link to the result:
    http://cieplowlasciwie.pl/
    Then enter exactly what your boiler and installation will help you improve because it looks like you don't have heat control at home.
    And here you have about the techniques of operating coal boilers read everything is described there.
    http://czysteogrzewanie.pl/
  • #4 16170689
    jacek_0707
    Rate: 60
    I have the boiler as in the subject. 20 kW
    The house has an area of 250 m.
    The valves on the radiators do not have a thermostat. These are just the usual taps for turning off.
  • #5 16797766
    jacek_0707
    Rate: 60
    DEFRO OPTIMA KOMFORT PLUS Boiler: Ideal Temperature for 0°C Outside, 2 Weeks Continual Use DEFRO OPTIMA KOMFORT PLUS Boiler: Ideal Temperature for 0°C Outside, 2 Weeks Continual Use DEFRO OPTIMA KOMFORT PLUS Boiler: Ideal Temperature for 0°C Outside, 2 Weeks Continual Use DEFRO OPTIMA KOMFORT PLUS Boiler: Ideal Temperature for 0°C Outside, 2 Weeks Continual Use
    Can these valves regulate the temperature of the radiators?
  • #6 16797998
    gersik
    Help: 164
    Rate: 639
    No. You can, however, restrict the flow through the radiator by closing the valves on the radiator return.
  • #7 16798017
    jacek_0707
    Rate: 60
    How to do it? Which valves are these and how to close them?
    Will replacing valves with thermostats solving the case?
  • #8 16820369
    jacek_0707
    Rate: 60
    [Quote = "jacek_0707"] DEFRO OPTIMA KOMFORT PLUS Boiler: Ideal Temperature for 0°C Outside, 2 Weeks Continual Use DEFRO OPTIMA KOMFORT PLUS Boiler: Ideal Temperature for 0°C Outside, 2 Weeks Continual Use DEFRO OPTIMA KOMFORT PLUS Boiler: Ideal Temperature for 0°C Outside, 2 Weeks Continual Use DEFRO OPTIMA KOMFORT PLUS Boiler: Ideal Temperature for 0°C Outside, 2 Weeks Continual Use
    Which valves with thermostat should be installed?
  • #9 16864783
    adamkaspro
    Rate: 16
    I have the same boiler, I installed thermostatic valves on all radiators, of course, properly positioned for the room, three-way valve. The temperature on the stove was kept 60 degrees for 50 degrees radiators. The 35-degree floor paddle for this 300-liter tank heats up to 58 degrees. House 180 m2 insulated with 15 cm styrofoam wool in the attic 45 cm, piles in it from above with coal and wood traditionally because it is not going to control burning wood from above but this is the detail. I recommend thermostatic valves for comfort and economy. Greetings .
  • #10 16867105
    jacek_0707
    Rate: 60
    Do you burn a lot of coal a day?
The discussion revolves around the optimal temperature settings for the DEFRO OPTIMA KOMFORT PLUS boiler in a single-family house during cold weather (around 0°C). Users suggest maintaining a higher temperature (60-70°C) for efficient operation and to prevent low-temperature corrosion, as lower settings (37-40°C) may lead to inefficient fuel burning and potential damage to the boiler. The importance of using thermostatic valves for better temperature control in the radiators is emphasized, along with the recommendation to assess the boiler's size relative to the home’s heating needs. Users also discuss the installation of valves and the impact of different heating techniques on fuel consumption.
