OKI B412 Printer: Reset Administrator Password, Default 'aaaaaa' Not Working
kwabedz 39693 14
How can I reset the administrator password on an OKI B412 printer when the default password "aaaaaa" does not work?
The factory login for the OKI B412 is root with password aaaaaa [#18511895] If that does not work because the password was changed, the thread says to use the OKI B412 maintenance manual and follow the System Maintenance Menu path to CHANGE PASSWORD in section 3.1.4 to unlock or reset it [#17779398] Another reply confirms that a maintenance manual page contains instructions for unlocking the admin password [#16266974]
  • #1 16169761
    kwabedz
    How to reset the administrator password, the default password 'aaaaaa' does not match.
  • #2 16169826
  • #3 16169876
    kwabedz
    OKI B412dn last 6 characters of MAC card does not match.
  • #4 16169897
  • #5 16170633
    kwabedz
    The password was changed, maybe someone knows the factory reset method?
    kemotix
    Help: 27
    Rate: 69
    Went to PW.
  • #7 16221496
    gnomek20
    Rate: 35
    I have the same problem with the administrator password, can I ask for help?
  • #8 16261396
    martinkrys
    Photocopiers specialist
    Help: 42
    Rate: 44
    Try aaaaaa.
  • #9 16261581
    gnomek20
    Rate: 35
    Aaaaaa, my friend kemotix helped me unlock the password.
  • #10 16261635
  • #11 16266974
    gnomek20
    Rate: 35
    I found a printer Maintenance Manual page and there was an instruction on how to unlock the admin password.
    I don't remember what this page is and what the keyboard shortcut was, I think it won't be a problem to find it.
  • #12 17779337
    marcinstyk
    Hello, how do you reset this administrator password?
  • #14 17779480
    marcinstyk
    Thanks, it also works on 432, the same family of printers, after all :)
  • #15 18511895
    rychub
    The factory login details for the OKI B412 printer are:
    login: root
    Password: aaaaaa
The discussion revolves around resetting the administrator password for the OKI B412 printer, as the default password 'aaaaaa' is not functioning for some users. It is suggested that the correct password may be the last six characters of the printer's MAC address, although this has not worked for all. Users are seeking methods for a factory reset or alternative ways to regain access. A maintenance manual is referenced, which may contain instructions for changing the password. The factory login details are confirmed as username 'root' and password 'aaaaaa'.
