BCS 0404LF-AS Recorder: Reset & Recover Lost Password, Removal of Battery Method
MateuszPilarski 18048 2
  • #1 16398893
    MateuszPilarski
    Hello, I am asking for help, namely to recover the password I tried to remove the battery but the bowel is nothing
  • #2 16398925
    Zdzicho
    Help: 77
    Rate: 71
    locally you can log in as admin and the password is the last 6 digits from the equation = 8888 x DD x MM x YY, where DD is the day the recorder displays, MM - month, YY-year (last two digits)
  • Removing backup battery blocks the password reset method
    #3 16407013
    treborsz
    Industrial cameras specialist
    Help: 124
    Rate: 240
    Removing the battery backing up the recorder memory effectively prevents using the password reset method given in the above post.
    As a side note - I wonder what drives people thoughtlessly pulling out the battery that supports the memory of the date ... There are quite a few - on privie I have requests from several hundred (!) "Heroes of the house" ...
    The author of the topic received a solution to the problem on priv - he can therefore close the topic.
