Mio Moov M610 - no software and the possibility of its installation
kamil1102 4770 1
  • #1 16173771
    kamil1102
    I have an unusual problem with the navigation mio m610, someone removed all the software (format) from the navigation. I have an original box with a start key, etc., as well as an original CD. At the very beginning, of course, I tried the installation with Mio More Deskop 7.30, unfortunately without any reaction. Then I installed the newer version 7.50, still the same, the disc is spinning in the drive and the navigation system does not install. I decided to go around it from another side, download a ready-made backups from one of the hosting portals we know. I simply pasted it on the memory of the navigation and attention after disconnecting and turning it on again, the navigation moved a step further, displaying the language selection and then a request to enter the startup code, here my joy ends because after entering the code, a message about its error pops up ... Not giving up and browsing the infinity of the Internet, I decided to upload one of the unlocking packages found on the Internet, here booom, unplug the cable, reset, the equipment turns on and a few icons are displayed on the navigation desktop (Mio, Automapa, iGO), unfortunately, as it is easy to guess in the memory devices have not been loaded with any map files, so when I click Automapa or iGO an error pops up and after clicking Mio, it returns to selecting the country and entering the Start Up Key.
    I would like to add that I found questions on the Internet such as where to upload maps or a software problem, but I did not find the answer.
    I covered the topic as detailed as I could. I would like to move this navi because it's a pity to throw it away.
    I am asking for help and I hope for its solution, which will surely help many users.
  • #2 16178867
    japycz321
    Help: 92
    Rate: 141
    As long as I understood your utterance correctly and you have communication with the device, the easiest way is to install some alternative navigation software (automapa, igo, navigo, etc.).
    To run through the icons you have in the panel to work, you must have the correct path to them, i.e. to the exe file that starts the map. Each panel has a text file (navi, desktop etc) with a configuration that you can edit, e.g. with a notebook as needed.
