[Solved] Mio Mivue 600 Not Saving Settings: Language Reset, Battery Replacement, Software Fault?
vcc 13134 13
How can I fix a Mio MiVue 600 that resets its language and settings after restart even after the battery was replaced?
The MiVue 600 probably needs a service-level firmware reinstall or repair, because replacing the battery and restoring defaults did not fix the lost settings [#16833537][#16886275] For this model, the software is installed with special software by connecting the recorder to a computer, and the standard Mio updater does not work [#16834445]
  • #1 16820192
    vcc
    Help: 163
    Rate: 466
    As in the topic, after restarting the English language and the whole thing after resetting the settings, the suspicion was that the battery does not hold, it was replaced with a new one and now it works on the battery but there is still no saved settings. The fault of the software or something else, because it happened like that overnight, the sounds just started appearing at startup and these were turned off. After the lack of memory, the recorder normally records even the last file after turning off the power.
  • #2 16833537
    rafaello4b
    Check if the problem will not be solved after restoring the default settings.
  • #3 16833552
    vcc
    Help: 163
    Rate: 466
    There was even a reset and a needle. And I took it without the card because my friend said that and it can be. Where can I get soft for this webcam, it can even be without Polish.
  • #4 16834445
    rafaello4b
    In this model, as long as I remember, the software is installed through a special software by connecting the webcam to the computer.
    The standard update that is in most Mio cameras does not work here.
  • #5 16836285
    vcc
    Help: 163
    Rate: 466
    So the website will someone take on the forum members ??
  • #7 16866853
    vcc
    Help: 163
    Rate: 466
    @ u08mlap Only my model is missing or I am looking wrong :D
  • #8 16886275
    rafaello4b
    Unfortunately, only the service remains.
  • #9 16925357
    u08mlap
    actually not up to 600
  • #10 16925845
    vcc
    Help: 163
    Rate: 466
    Any bearing where can they do this to me?
  • #11 16925988
    u08mlap
    Call the service and they will tell you what the cost is, e.g. the cost of replacing the battery with the courier is about PLN 120
  • #12 16926068
    vcc
    Help: 163
    Rate: 466
    I changed the batteries myself and the cost of PLN 30, if they have such prices, I will probably let go
  • #13 17709769
    Ziober1349
    And you solved the problem? What kind of batteries did you buy?
  • #14 17709782
    vcc
    Help: 163
    Rate: 466
    I changed the webcam to xblitz and I do not regret much better quality and less noise at night and I bought the batteries on the Allegro.
✨ The discussion revolves around the Mio Mivue 600 dashcam, which is experiencing issues with saving settings after a battery replacement. Users suggest restoring default settings and updating the software, as the standard update process for Mio devices may not apply to this model. A link to the Mio service page for software downloads is provided, but some users report difficulty finding the correct software. There are also mentions of service costs for battery replacement, with some opting to replace the battery themselves. One user ultimately switched to a different brand, xblitz, citing better quality and performance.
TL;DR: Mio MiVue 600 not saving settings often isn’t fixed by a new battery; “the cost of replacing the battery with the courier is about PLN 120.” Service flashing may be needed. [Elektroda, u08mlap, post #16925988]
Why it matters: This FAQ helps MiVue 600 owners quickly decide whether to try resets, seek firmware tools, or book service.
Why does my Mio MiVue 600 reset language to English every restart?
Users reported settings reverting to English after each power cycle even after replacing the battery. Recording continued to work, which points to configuration storage or firmware issues rather than power loss alone. Try updates via service tools or contact service if resets fail. [Elektroda, vcc, post #16820192]
Will restoring factory defaults fix the settings problem?
One user performed a full reset, including a pin-hole reset, and the issue persisted. This suggests the fault lies beyond corrupted preferences. If a reset changes nothing, plan for a firmware reflash or service intervention next. [Elektroda, vcc, post #16833552]
Do I need an SD card inserted for settings to save?
No. A user tested the camera without the microSD card and settings still failed to persist. That rules out the card as the configuration store on this unit and strengthens the firmware or internal memory hypothesis. [Elektroda, vcc, post #16833552]
How do I reinstall or update MiVue 600 software?
This model updates through special service software by connecting the camera to a PC; the standard Mio updater does not apply. How-To: 1. Connect MiVue 600 to a PC via USB. 2. Launch the dedicated service tool for this model. 3. Reinstall or flash the firmware following on-screen prompts. [Elektroda, rafaello4b, post #16834445]
Where can I download MiVue 600 firmware?
A support portal shared in the thread did not cover the MiVue 600 at the time, so a public download wasn’t available there. Owners seeking firmware typically needed the model-specific service tool rather than the general updater. [Elektroda, u08mlap, post #16925357]
Is service really my only option if resets don’t help?
One contributor concluded, “Only the service remains,” after resets and basic checks. If you can’t access the service tool, booking a service visit or mail-in is the pragmatic path to restore setting retention. [Elektroda, rafaello4b, post #16886275]
How much does official battery replacement cost?
A user reported a quote of about PLN 120 including courier for battery replacement. This gives a ballpark for service logistics if you decide not to do it yourself. “They will tell you what the cost is.” [Elektroda, u08mlap, post #16925988]
What did a DIY battery swap cost in this case?
The original poster replaced the battery themselves for about PLN 30. Despite the swap, settings still didn’t save, which indicates the battery wasn’t the root cause in that unit. [Elektroda, vcc, post #16926068]
Did the original poster solve it—and how?
The OP ultimately replaced the camera with an Xblitz model, noting better night quality and lower noise. They bought their replacement batteries on Allegro, but that did not resolve the saving issue on the 600. [Elektroda, vcc, post #17709782]
Why does my MiVue 600 record videos fine but not keep preferences?
The device wrote clips correctly and even saved the last file after power-off, while settings still reset. This split behavior suggests video storage works, but configuration storage or firmware integrity does not. [Elektroda, vcc, post #16820192]
Can I use the standard Mio update method on the 600?
No. Contributors state the common Mio update path doesn’t work on the 600. It requires a specific service application with a PC connection to install or recover firmware. [Elektroda, rafaello4b, post #16834445]
I tried a pin reset and removing the SD card. What next?
Those steps were tested by a user and did not resolve the issue. When resets and SD removal fail, plan for firmware reinstallation via the service tool or arrange service. [Elektroda, vcc, post #16833552]
Who should I contact for costs or repair options?
Call the service center for model-specific guidance and a price. One user shared a phone-quoted battery replacement price including courier, which sets expectations for logistics and turnaround. [Elektroda, u08mlap, post #16925988]
