Will the HOW-TO-MIO-m400-menu.zip unlock method work on a Mio Moov M410?
Yes, it should work because these devices generally unlock on the same principle [#16497987] After unlocking, Automapa can be installed like on any other Windows CE 5/6 device [#16498077] In this case the device was a Navman version with a Smartst_ce file, and changing the path to "appstartupsec" made Automapa start successfully [#16499917][#16501105] If you need more space, remove map and voice files, which take the most space [#16501211] You also cannot fit all of Europe at once in Automapa, so you need to select specific countries for installation [#16501287]
And you have a fate. I installed the Polish automapa, the mio starts up the old way, I tried to replace the files as in this video, but it's different for me. I only have three configuration settings files in the ProgramFiles \ MioMap directory. I have no idea what to do, which files should be replaced to start with automapa. Please help
Hello, Yes, this is the navman version and there is the Smartst_ce. I changed the path to "appstartupsec" and it fired up the automap. Everything works. Thanks a lot for your interest. I wonder why I don't have a map choice and what I have to throw away to upload all of europe. little space there.
✨ The discussion revolves around the compatibility of the unlock method for the Mio Moov M400 with the Mio Moov M410. Users confirm that the unlock should work since both devices operate on similar principles. Additional inquiries focus on installing Automapa on the M410, with guidance provided on the installation process for devices running Windows CE 5/6. Users share experiences regarding issues with map selection and file management, leading to a successful launch of Automapa after adjusting the application startup path. The conversation concludes with advice on managing storage space for map files and the necessity of selecting specific countries for installation due to space limitations. Summary generated by AI based on the discussion content.
