Mio Spirit 7500 LM - Logo hinges after unlocking no USB communication
adaadam1 12597 13
How can I recover a Mio Spirit 7500 LM that is stuck on the Mio logo after a bad unlock and no longer communicates over USB?
Recover it by putting the m3618 recovery package on a 2GB microSD card, inserting it into the device, pressing reset, and waiting; this was reported to work [#16978902] If you only need to launch Total Commander first, create a folder named `JANGMI_S5010`, place `TotalCommander.exe` inside it renamed to `auto.exe`, copy it to the card root, and reset the device [#16192495]
  • #1 16191421
    adaadam1
    I got the Mio 7500 LM Windows Ce 6 navigation that was ineptly unlocked which hangs on the Mio logo with a chime sound. It doesn't detect its windows.
    I tried with Tootal Comander and changed the name to iBoot on the SD card but it has a reaction from the mio.
    Is there any way to save?
  • #2 16192495
    vaczak
    Help: 50
    Rate: 141
    Create a folder with this name: JANGMI_S5010 , then put the TotalCommander.exe file in it with the name changed to auto.exe. Copy to the root directory of the card and reset. TotalCommander should start.
  • #3 16197798
  • #4 16312394
    leko
    Hello, I bought a Mio Spirit 7500 LM navigation with a map of Poland. I have AutoMapa 6.22 installed on the SD card with the selected Mio Spirit 7500 LM device. After inserting the SD card into the Mio Spirit 7500 LM device and starting up, the screen with AutoMapa and Mio map icons to choose from appeared. AutoMapa whisks that it's nice to use. After removing the SD card, I have a device with the original map uploaded by the manufacturer. SO, I CONFIRM THAT YOU DO NOT NEED TO UNLOCK THE DEVICE TO USE ANY OTHER MAP. I mention that I was full of fears whether I could handle it myself, whether I would lose the warranty or block the device. Greetings to all unbelievers. The purchased device is great and there is no need to rummage in the system and then complain that it has locked.
  • #5 16977619
    zapola1992
    Unfortunately, I need to refresh the topic, I have the same problem as a colleague from the first post, I tried with Total Comander but it did not go, maybe someone knows a solution to this problem ??
  • #6 16978084
    koala106
    Help: 471
    Rate: 1240
    Flash from another model or disc change. The older versions were soft with m3618 boards, and new ones were missing.
  • #7 16978729
    zapola1992
    koala106 and could you describe how to flash this navigation ?? I honestly admit that the phones have been flashing but navigation is not yet. What program for this etc.
  • #9 16979030
    zapola1992
    koala106 Everything works beautifully, I don't know how to thank You. I would still like to ask how to restore the mio backup that I did two days ago, I connected the habit to the PC but MioMore Desktop does not detect it. I just want the previous navigation look so original. You know how to do it ????
  • #10 16979165
    koala106
    Help: 471
    Rate: 1240
    You will no longer make the original on it - unless you find a ROM that is not available anywhere.
    You have a functional device - unlocked - install something other than MioMap and you can drive ;)
  • #11 16979207
    zapola1992
    Here on the forum I found a backup from MioSpirit 7500 LM and I have BM. I put this backup on the device's memory and connected it to the computer again. MioMore Desktop detected the device normally and surprisingly before I could not install anything from the disc and now yes. I just want to change the look and nothing more than the original. Because I damn I made a backup of the BM version but I don't know where he is now.
  • #12 16980615
    koala106
    Help: 471
    Rate: 1240
    Backup won't start - license issue.
  • #13 16981206
    zapola1992
    I'll give it a rest, the software you gave me works great, as I wrote, I uploaded a backup from the LM version and detects my device in MioMore Desktop and I can load maps from the disc, but they don't work, but I can upload it, I downloaded the automap and it blows cool. Also, great respect for you koala106. Thank you for your time.
✨ The discussion revolves around issues faced by users of the Mio Spirit 7500 LM navigation device after an unsuccessful unlocking attempt, resulting in the device hanging on the Mio logo and failing to establish USB communication. Users suggest creating a specific folder on the SD card and renaming TotalCommander.exe to auto.exe to initiate recovery. Some users express concerns about the necessity of unlocking the device, noting that alternative maps can be used without unlocking. Others discuss flashing the device with software from different models and restoring backups using MioMore Desktop. The conversation highlights various methods to recover functionality and the challenges of restoring the original navigation interface.
