Medion MD30580 17MB70-5P: Seeking Charge for Vestel Board, LG LC420EUD Panel, 17PW07-2 Supply
Duduś74 19134 14
  • #1 16176112
    Duduś74
    Moderator of HydePark
    Help: 71
    Rate: 225
    As the topic:
    Medion 30580 DE-A
    Vestel 17MB70-5p V1 board 050511 10070964 23033535
    17PW07-2 power supply
    LG LC420EUD SDM1 panel
  • #2 16332429
    Traper54
    Do you need a full load or update. You can find the update on the Medion website and I can send you what I have, also downloaded from the official Medion website for this vestel 17mb70-5p V1 050511. You need to unpack, upload to USB, preferably put 1Gb into the turned off TV, press OK on the remote control and turn on network, if you have a USB with a diode it will start blinking then you can release the button.
    • LC-40LE343E DUMP U103 U107.rar (24.84 KB) You must be logged in to download this attachment.
    • 12.1.rar (29.16 MB) You must be logged in to download this attachment.
    • LC-40LE510E_e.zip (17.66 MB) You must be logged in to download this attachment.
  • #3 16333113
    jaculek
    Help: 17
    Rate: 24
    These are ripples from sharp and there is a 40 inch matrix and often samsung so it may not move.
  • #4 16334613
    Traper54
    I have Medion MD 30566 also with a problem, it turns on after about 20 minutes. I bought a 17MB70-5p disc on ebey as a defect and it turned out that everything was fine with the TV 32 "and mine is 42" and everything is displayed normally. I ordered the programmer and when it comes I will try to download from both programs. In one 42 "there is the V.0.12.1 MED version, and on the other disc with 32" V.0.7.8.14, both on the LG matrix. For now, I was able to download the dump from U 103.
    • 24c64_beckup U103.bin (8 KB) You must be logged in to download this attachment.
  • #5 16505333
    Dydelmax
    Help: 654
    Rate: 965
    The subject may be a little outdated, but let me put the ripples ripped from a working TV Medion MD 30580 42 ".
    The archive in the annex contains bone entries U13 (24C02), U18 and U103 (24C64).
    • md30580.zip (6.99 KB) You must be logged in to download this attachment.
  • #6 16606791
    jedrek250
    So connecting to what you write about here. I have md30580 42 "in which the motherboard sat down. I looked for I ordered 17mb70-5. I installed it as someone wrote somewhere above. I can turn it on. Turn off and in the meantime only the matrix lighting can be observed. The board, however, differs slightly from the one that was installed. next to the sockets for connecting the tapes. And supported 32 "screen
    Is this a software issue? These differences under construction? Something can be done about it? Help me please. I will add that the board I ordered was checked with a boot guarantee. And as I noticed someone already used a 32 "to 42" inch tv plate and writes that it correctly displays the image ...
  • #7 16642742
    almou
    Rate: 55
    Me i have tried this bootloader so many times but i don't know if it works for somebody
    If somebody have a solution, he can make us know
  • #8 17026068
    Traper54
    Buddy jedrek250 I have this old motherboard for Medion MD 30566 42 '' I do not know if it is exactly the same, and there is still a small problem the TV turned on after about 10 minutes when it warmed up, maybe these are problems with a cold solder, I can plate with 17MB70 5P.
  • #9 18570704
    boras2
    Rate: 20
    Thanks buddy dydelmax, your set has put your medion on your feet
  • #10 18612716
    almou
    Rate: 55
    This bootloader works with the plus program (P +) and not with the OK button
  • #11 19307963
    mxtestview
    Help: 5
    Rate: 8
    And this batch from the u103 system is responsible for? Matrix configuration or something else?
  • #12 19309804
    Traper54
    I am very sorry, but I have not dealt with TV repairs for a long time, but I have a scheme for the vestel 17MB70 I can send it.
    • vestel_17mb90_chassis.pdf (8.89 MB) You must be logged in to download this attachment.
  • #13 19572400
    mxtestview
    Help: 5
    Rate: 8
    This is not a 17MB70 schematic, only 17MB90 in the attachment.
  • #14 19572521
    GanCegall
    Help: 339
    Rate: 1631
    mxtestview wrote:
    This is not a 17MB70 schematic but a 17MB90
    Congratulations on your perceptiveness, it is important to them that it is correct on the front (17MB) :-)
    2017 theme ... may not be alive anymore.
  • #15 19573097
    Traper54
    I agree, I made a spelling mistake.
The discussion revolves around the Medion MD30580 television, specifically issues related to the Vestel 17MB70-5P V1 board, the 17PW07-2 power supply, and the LG LC420EUD panel. Users share experiences with firmware updates, troubleshooting power issues, and compatibility between different board versions. Some mention successful repairs using firmware from the Medion website, while others report problems with cold solder joints and the need for specific bootloaders. There are inquiries about the functionality of certain components and requests for schematics related to the Vestel board.
