Audi A6 C6 2.7 TDI - The car does not heat up after replacing the thermostat
RafalCeee 8253 4
  • #1 16176291
    RafalCeee
    Hello!
    I have a problem with the Audi A6 C6 2.7 tdi from 2006, and I recently replaced the thermostat in the car and after all the machine sent me to heat with warm air, and sometimes it heats up and sometimes not. I will add that I vented the system and before the replacement it was ok, maybe someone had a similar problem?
  • #2 16176456
    sk700
    Help: 173
    Rate: 420
    System poorly vented. There are solenoid valves shutting off the flow of fluid to the heaters, the heaters are not in circulation all the time.
  • #3 16177031
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Valves in the pit on the driver's side.
    Second, see the temperatures he sees.
  • #4 16177074
    RafalCeee
    I used this valve in the pit for venting but it doesn't do anything. The car shows about 90 degrees after bleeding the temperature drops
  • #5 17112292
    Łukasz KIELCE
    Rate: 8
    Hello Rafał Ceee.
    It's been a while since your post, but I have the same problem as you had in c6 2.7tdi.
    Did you deal with this problem somehow?
