Audi 80 B3 1.8: Persistent Interior Cold Air Issue Post-Bendix Replacement
piomin 9357 3
  • #1 16892413
    piomin
    Hello, I have an Audi 80 B3 1.8.
    I have a problem heating inside the car. Some time ago everything was ok and it was very good. I couldn't stand it sometimes because it was hot. He was at the mechanic's to replace the bendix. After this period, these problems began. It is possible that this is a problem with it not venting. But I'll leave it to your opinion, because I don't know anymore. Today I changed the thermostat, but as you can see it was good because it is still the same problem. The temperature shows 50 degrees. The pointer will start for 3 lines and that's it. There is such a temperature all the time, and the fan turns on, i.e. the engine is already about 90-95 degrees. All tubes are warm.
    What may be the problem?
  • #2 16899884
    Gunslinger
    Level 30  
    Help: 114
    Rate: 460
    Do you have a breather on the pipe to the heater? If so, it's worth using it, as you can't try to pull the return hose from the heater, but it's with your head, because it's easy to get a severe burn.
  • #3 16899904
    marqqv
    Level 32  
    Help: 162
    Rate: 606
    And what is the condition of the coolant at your friend's? Bigger / smaller / the same? After driving 2 - 3 km the upper pipe from the heat or cold radiator? Thick pipes to the radiator after warming up the engine are normal or hard, difficult to knead?
  • #4 16901849
    piomin
    I had a sensor down because it didn't show me the temperature. There was 2-3 lines and that's it. I exchanged and it's git. The pipe is warm. Everything works well in the pipes. It is possible that the problem was in the heater. Because the valves should have a sponge, and it crumbled on some and fell off. I covered the plates and everything is put on. The new heater was put in because this plastic had fallen apart, more precisely this tube from the heater and it was necessary to remove the entire interior and fold it. Tomorrow we will pass the test and let you know if it heats up. Because I have to pour the liquid and bleed it.
    Added after 4 [minutes]:
    Well, there is no vent. I took off this hose and vented just like that. But the heater tube was already broken and the second time wanting to do it broke completely. She's already broken from old age, I think. Because it is made of plastic. But everything is done, and as I wrote above, I pour in the liquid and bleed it tomorrow. I will let you know what effects ;)
