Renault Laguna II - Xenon HID Conversion: H7 Bulbs Flickering Issue in both Filaments, Chinese Kit
jastrzab772 4860 8
  • Xenon bulbs flicker in both filaments after H7 conversion
    #1 16178382
    jastrzab772
    Rate: 54
    Yesterday I bought hidy china for lagoon II 2 which previously were halogen lamps I replaced them with H7 xenon with inverter but I have a strange symptom I turn on the xenons and they shine nicely for a while but the flashing symptom is the same in both filaments the same on the ignition and on the engine not I already know what it can be. Anyone have any idea?
    Moderated By CameR:
    Before converting vehicle lighting to xenon, LED ...
  • #2 16178437
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    For such practices - mounting HIDs to lamps not intended, they should commandeering the car. It's great that you can see well, but it's fun for me when it follows me and the worst of it is such a TUNER and blinds others. I wonder whose fault I would hit someone walking along the side of the road because YOU blinded me. They flash them - the only solution is - put on branded bulbs and widths.
  • #3 16178475
    jastrzab772
    Rate: 54
    I have branded bulbs lying in the garage because I took out to put on the hides, my friend is on and he was on the inspection and the guy has set his lamps and drives
  • #4 16178574
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    A diagnostician may be responsible for It and, above all, for his stupidity. Add also sprinklers, a self-leveling system and a few other small things. Isn't it strange that the lamp for my car costs about PLN 5,000 and up to your 500? And we both have xenons. I don't want to discuss any further because it doesn't make sense. Return to branded light bulbs, or wash the reflectors if they are dirty or have them regenerated. Don't be a beet on the road and don't kill anyone.
  • #5 16178828
    jastrzab772
    Rate: 54
    Yes, I have lamps from another lagoon, I have a bumper with sprinklers, the lens is all the same as Cb, only no auto-leveling but it is not needed. So what is the problem. My doll had a broken front, she got another one with xenon, but someone took the converters, the filaments and the bulb fits them nominally, so until I wanted to play, I went on H7 halogen
  • #6 16179098
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    jastrzab772 wrote:
    a light bulb fits them
    And how, in place of the D2S burner, you will not normally put H7, well, you broke off the Christmas tree?
    See if you have efficient converters, new ones.
    Second, see how the supply voltage is at the connector.
  • #7 16179312
    Ireneo
    Help: 747
    Rate: 2472
    tomrom1985 wrote:
    (...) Go back to branded light bulbs, possibly wash the reflectors if they are dirty or have them regenerated. Don't be a beet on the road and don't kill anyone.
    Well positioned and without sprinklers will not dazzle. Do you think if you spray it, it will stop? Instead of theorizing, note that, for example, delivery vans without xenons or suvs with them, i.e. generally cars with high lamps, despite spraying and leveled, blind.
  • #8 16179346
    tomrom1985
    Level 30  
    Help: 133
    Rate: 644
    Read with understanding - I wrote about something like self-leveling, which is an integral part of the system, but it can get damaged. You write about dazzling in delivery vans. Haha, I will go even further in passenger cars the same and even on super light bulbs. Why? Because people have no idea that you can lower the headlamps manually with the knob if the rear is loaded. Stupid logic - someone blinds it and I will, my colleague managed to do a review and I will go and give it a hit and he will do it. If someone killed you will you go too? First, go back to the regulations and look for the word approval. One word like that closes your discussions. Maybe you will be a brave at home because you have great lights, but for most normal people you will be just a guy who blinds others. As for me, this topic should go to the trash because it is only a threat on the road.
The discussion revolves around the flickering issue experienced after converting halogen lamps to H7 Xenon HID in a Renault Laguna II. The user reports that both filaments flicker upon ignition and while the engine is running. Responses suggest that improper installation of HID kits, lack of necessary components like self-leveling systems, and the use of non-branded bulbs may contribute to the problem. Recommendations include returning to branded bulbs, checking the efficiency of converters, and ensuring proper voltage supply at the connectors. The conversation also touches on the legal and safety implications of using non-compliant lighting systems.
