Bosch SMV40M00EU / 04 Dishwasher - Error E24: Cleaning Filters, Pipes & Checking Salt Container
17325 17
Why does my Bosch SMV40M00EU/04 dishwasher show intermittent E24 errors, and what part should I check or replace?
E24 in this dishwasher is most likely caused by a failing washing/circulation pump rather than blocked filters or pipes [#16179585][#16181803] The control module monitors the current drawn by the pump, and if the pump current goes out of range it reports the error [#16181803] Bosch parts data shows pump 00654575 fits this model, and replacing that pump was reported to restore normal operation [#16182038][#16196611] One user found a large piece of glass in the old pump, which suggests debris can damage or jam the pump and trigger the fault [#16196611] The pump is described as having loosened impeller/bearing wear, and simply replacing sleeves was said not to be physically possible [#16181803][#16182065]
  • #1 16179529
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2658
  • #4 16180645
  • #5 16180672
    Lodxx
    Help: 105
    Rate: 245
    There is, you can always buy a stimulant for PLN 150 only you do not know how much it comes from. The allegro are new after PLN 340, apparently the originals.
  • #6 16180698
  • #8 16180740
  • #9 16180929
  • #10 16181090
  • #11 16181707
    Lodxx
    Help: 105
    Rate: 245
    You have in the auction written patterns to which it fits, yours is not exactly but it will fit, let me confirm that there are no other versions of this pump. As for me, it probably passes the sealant on the impeller to the center of the pump though I do not know because I did not undress the pump. It often happened with older pumps but it can be repaired.
    MARCIN.SLASK
    Help: 1037
    Rate: 2658
    The impeller gets loose on the bearings. The module measures the current consumed by the pump and if it goes out of range, the corresponding error is displayed (similarly with the emptying pump - eg how to thread the wire).
  • #13 16182038
  • #14 16182065
  • #15 16182070
  • #16 16196611
  • #17 16197587
    Lodxx
    Help: 105
    Rate: 245
    Probably not because if something blocked her, the electronics would break it.
  • #18 16197598
The Bosch SMV40M00EU / 04 dishwasher is experiencing an E24 error, which indicates a drainage issue. The user has attempted to clean the filters and pipes, finding them mostly clear, but the error persists intermittently. Responses suggest that the washing pump may be faulty, with recommendations to check and potentially replace it. Users discuss the cost of replacement parts, with prices ranging from PLN 150 to PLN 550. One user successfully replaced the pump after discovering a piece of glass obstructing it, which may have caused the pump to fail. The discussion includes links to parts and service instructions for further assistance.
