Audi A4 B6: No Power to Fuel Pump Relay, Water Damage, Bent Cables, and Fuse Issues
KRZYSIEK* 13053 2
  • #1 17255778
    KRZYSIEK*
    Rate: 122
    Hello, as it happens in this Audi model, water got into the box on the shaft in which the relays are and the computer, as a result of which the cables from the fuel pump relay were bent. with the signal from the computer to the pump relay. I am asking because when I made the cables and put everything in this box, there was a problem of the lack of mass from the computer to the fuel pump relay and at the same time the current on the fuel pump fuse died. moment to break itself.
  • #2 17255783
    decybel91
    Help: 1024
    Rate: 4231
    You will need to open the engine controller.
  • #3 17256235
    KRZYSIEK*
    Rate: 122
    The controller controls the pump relay, but the fuse power supply shouldn't it?
