Audi A4 B6 Driver's Door Not Closing, Window Control Panel Issues & Interior Light Problem
maestropoland 6327 4
  • Suspect faulty door latch switch or wiring
    #1 16690246
    maestropoland
    Hello. I have a problem with the door. Well, after closing the cars with the remote control the driver's door does not close, the rest of the door closes. the window control panel and the panel from closing the door from the inside stopped working, windows cannot be opened in all doors. moreover, the skylights inside the car are constantly burning in the position of the door being opened because the door is closed.
    I checked the fuses, they are all good ... is the door switch gone or is there a relay that may have failed?
    Paul
  • #2 16690293
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. Let a colleague check the beam that goes in the rubber cover in the front wonders connecting to the driver post and certainly there will be several torn or incumbent wires that have crumbled due to corrosion.
  • #3 17053768
    maestropoland
    I checked the cables, I noticed that the desktop from closing the windows sometimes lights up the orange lamp on the button from blocking the windows of passengers Audi A4 B6 Driver's Door Not Closing, Window Control Panel Issues & Interior Light Problem
  • #4 17053799
    Pedros050
    Help: 2471
    Rate: 3926
    Undress and check what's with this control?
  • #5 17053830
    coperfild
    Help: 291
    Rate: 1697
    You need to look under the rug for a comfort module, not to combine.
