Opel Vivaro 2.5DTI 2004 - does not start
czarny.furiat 19308 16
How can I diagnose why my 2004 Opel Vivaro 2.5 DTI cranks but will not start in cold weather?
Start by checking the glow plug system, because this engine can have starting problems in frosts around -10 to -15°C and a glow plug fault is a likely cause [#16184769] Locate the glow plug module near the left headlamp, unplug it (blue lock) and test whether voltage reaches the plugs with a meter or test lamp; each plug should make the test lamp light, and a weak or missing result means that plug is faulty [#16184769] If a plug is bad, replace it, but first clean/blow out the glow plug seats carefully so the plugs do not break during removal [#16184769] The later fault code P1635 also points to the glow plug module, so the module itself should be checked if the plugs test OK [#16311285] If the starting problem remains after that, continue with the fuel-rail pressure fault P0191 and the low-voltage history code, because those can also affect starting [#16311285]
  • #1 16184063
    czarny.furiat
    Level 4  
    Rate: 32
    I have Opel Vivaro from 2004 2.5dti engine Until yesterday everything was fine, but today I do not want to start. The starter is functional, the battery is functional, the fuel is in the tank. For 2 years, the glow plug glow indicator light was on, but I didn't do anything about it. Tonight at -10 refused to obey. Where do you think it would be worth to look, where to start?
  • #2 16184152
    zibi581
    Help: 36
    Rate: 174
    I think I think you are making fun of it, maybe it is glow plugs?
  • #3 16184156
    czarny.furiat
    Level 4  
    Rate: 32
    Not a mockery. And why candles when he smoked so far and there was no problem with anything since the arrow was smoking.
  • #4 16184166
    zibi581
    Help: 36
    Rate: 174
    Hands fall down, and why are candles, you know?
  • #5 16184188
    czarny.furiat
    Level 4  
    Rate: 32
    Well, they need to start the car. And the question is how to check if they are candles?
  • #6 16184239
    zibi581
    Help: 36
    Rate: 174
    The bulb after switching on the ignition, it should light on the candles for a moment, it means that the voltage comes on, then after removing the wires from the candles to each separately for a moment touch the battery cable, it should spark a little bit, the candle is good, if this is not exchange.
    pp_pablo
    Help: 93
    Rate: 405
    Buddy, what's your engine? Only the glow plug light is on or something else?
  • #8 16184317
    czarny.furiat
    Level 4  
    Rate: 32
    2.5 dti, and as for the controls, I still have a pillow and service (but both the pillow and service light up at one moment but it's damaged by a tape in the steering wheel).
    Testing glow plugs at the connector before removal
    #9 16184769
    pp_pablo
    Help: 93
    Rate: 405
    Buddy, the 2.5 engine can ignite nicely even in low frosts, but at temperatures of -10 ~ -15 can have problems. It's normal.
    So that you don't have to remove the filter to check the candles, look for a "candle machine" near the left lamp. Unplug the plug by moving the blue lock away and check with a meter, indicator light whether a normal light bulb is there a passage by connecting under the plus and subsequent pins. On each candle should shine nicely (indicator, light bulb). If one is not lit or shines weakly, it is a candle to be replaced. Beru candle cost about PLN 100-120, good quality candles about PLN 60, Chinese candles about PLN 30. Before removing the candles, clean (blow out) the candle seats well. Water likes it and there is a mess. If you turn the candles you will pay about 100 PLN / item. at the specialist for pulling out broken candles - also do it sensitively.
    Below are the photos for orientation.
    pp_pablo
    Help: 93
    Rate: 405
    If you are sure that this is a broken tape, it's OK, but a common cause of these lights is the lack of contact in the ankle under the seat -> no connection with the belt tensioner.
  • #11 16311285
    czarny.furiat
    Level 4  
    Rate: 32
    Hello, I have Opel Vivaro 2004 2.5dti. After connecting to the computer I checked and jumped out the following errors:
    P1635 - glow plug module mirrors (permanent)
    P0105 - boost pressure circuit - signal too low - discontinuous
    P0105 - boost pressure sensor: unstable - discontinuous
    P0191 - Fuel Rail Pressure Sensor Circuit, Signal Out of Range, Unstable - Discontinuous
    in addition to these errors, there were also:
    B0023 - passenger belt pretensioner: too high resistance (constant)
    B0011-driver airbag: too high resistance (fixed)
    B0027-driver's side airbag cartridge, high resistance-constant
    B0019 - driver belt tensioner, too high resistance - fixed
    U2110 - no information about vehicle speed - historic
    B0006 - incorrect supply voltage in the vehicle's electrical system - historic
    WHAT ABOUT THIS JUDGMENT? Is any expert on the forum able to help me in turn, it can not so much to remove but diagnose and fix it. I would like to mention that in freezing temperatures of -3, -5 there was a problem with firing recently and you had to hold it longer Kluczyk.As to the power of the rage is not once it was a lot better and the car flew on the roads.
    Moderated By tzok:
    Themes have been merged ...
    3.1.12. Do not post many similar topics in the forum, users will not know where to reply.
  • #12 16311505
    Ireneo
    Help: 747
    Rate: 2470
    If there is a candle error, it is probably understandable that it burns badly in frosts? Besides, why do you give SRS errors for lack of power? And when it comes to power, what errors are left after deletion? What do the parameters look like?
  • #13 16311519
    genek1000
    Help: 289
    Rate: 1057
    First, start by checking / replacing the glow plugs or the controller. Replace the pretensioners or repair driver and passenger pretensioner connections and driver side airbag, replace or repair the driver airbag retractor. Then delete all errors. Perform the route and connect the diagnoscope again and see what error appears :D
  • #14 16311686
    czarny.furiat
    Level 4  
    Rate: 32
    All candles give a spark. The question whether these permanent errors after removal if they appear is 100% e.g. glow plug module or after replacement will be this error again.
  • #15 16311706
    genek1000
    Help: 289
    Rate: 1057
    It's like the candles give a spark, you have to refuel Pb95 because it will not light up
    WHAT ARE YOU WRITING ABOUT !!!!
    I'm sorry I shouldn't scream but how can I shake someone ???
  • Verify glow plug voltage reaches them when keyed
    #16 16312132
    g107r
    Help: 811
    Rate: 993
    genek1000 , don't worry, read 6 posts in this new old topic :)
    czarny.furiat , such checking is an "eye" that candles are still alive, depends on who you think is sparking. That they work somehow, let's say you checked by giving them your own power supply, but this voltage reaches the candles "on the key" or not?
    You get a simple description of how to check it, then check and inform in the first topic, because you see what is happening ...
  • Warning against battery spark-testing low-voltage glow plugs
    #17 16312183
    genek1000
    Help: 289
    Rate: 1057
    zibi581 wrote:
    then after removing the wires from the candles, touch each one for a while with the battery cable, it should spark a little bit, the candle is good, if it is not replaceable.
    Don't teach people such ways. You have to know that it works with old type candles on 11V. He will read one with the other and will check candles in new (2006!) Diesels powered by 5-6-7V and will only see that it is a pity that it was a shame once :cry:
    Then they write nonsense that there is a spark on glow plugs :crazyeyes:
The discussion revolves around a 2004 Opel Vivaro 2.5DTI that fails to start despite a functional starter, battery, and fuel supply. The glow plug indicator has been on for two years, and the vehicle refused to start in cold temperatures of -10°C. Participants suggest checking the glow plugs, as they are crucial for starting in low temperatures. Methods to test the glow plugs include observing the indicator light during ignition and using a multimeter to check for voltage at the glow plug connections. The user later reports diagnostic error codes related to the glow plug module and other components, prompting further advice on checking and potentially replacing the glow plugs and addressing airbag system errors. The conversation emphasizes the importance of ensuring proper electrical connections and the condition of the glow plugs for reliable engine starting.
