Skoda Octavia I 1.9tdi 90 1998 - The heating of the coolant does not work.
7530 7
  • #1 16192404
  • #2 16192517
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1418
    It seems to me that there is no control from the external temperature sensor (besides, a small inflection with points for viewing the photo because you are counting on help and you delete it for it)
  • #3 16192930
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6402
    kitikontiO wrote:
    Hello, there is a problem with heating the coolant.
    The first thing we do in such a situation is to connect the VAG and check if the conditions for lighting candles are met.
    The ECu controls the candles.
  • #4 16193066
  • #5 16193451
    szczupx
    Level 19  
    Help: 29
    Rate: 94
    I'm not sure, but there are probably two separate external temperature sensors - one for the ECU and the other for the clocks.
  • #6 16194786
  • #7 16195280
    szczupx
    Level 19  
    Help: 29
    Rate: 94
    The liquid temperature definitely has two sensors, one for the ECU and one for the clocks.
    The fact that the temperature is shown on the clocks does not mean that the ECU has the correct reading
  • #8 16612055
✨ The discussion revolves around a heating issue in a 1998 Skoda Octavia I 1.9 TDI, where the coolant heating system is not functioning despite the relays receiving current. Users suggest checking the external temperature sensor and connecting a VAG tool to verify if the ECU conditions for activating the glow plugs are met. It is noted that there are likely two separate temperature sensors: one for the ECU and another for the dashboard. The author later confirms that the problem was due to a defective fluid temperature sensor, which displayed the correct temperature but failed to relay data to the heating relay.
