Fiat Ducato 3.0 Multijet 180 HP (2012) - Locating & Replacing Shaft Position Sensor with Photos
bartosz750 11064 3
  • #1 16195341
    bartosz750
    Rate: 39
    Maybe someone will help me.
    In the Fiat Ducato 3.0 Multijet 180 HP engine (2012)
    I cannot locate the shaft position sensor.
    I need to replace it, I just don't know where it is.
    Maybe someone has a photo with the above-mentioned sensor.
    Thank you in advance and best regards.
  • #2 16197481
    drdrug
    Help: 25
    Rate: 178
    Look at the gearbox at the height of the shaft axis
  • #3 16205228
    szymon_nowy
    Help: 8
    Rate: 42
    at the rear of the engine the alternator
  • #4 16345078
    bartosz750
    Rate: 39
    ok thank you i located it
