Location of Crankshaft Position Sensor in Peugeot 407 SW HDi 2.0 136 hp - P0337 & P0338
hellgt 62112 9
Where is the crankshaft position sensor located on a Peugeot 407 SW 2.0 HDi 136 hp with P0337/P0338 faults?
The crankshaft position sensor is on the front of the engine, near the crankshaft pulley, and it can be seen from the front passenger side with the steering wheel turned fully right. [#16364660] [#16602120] One reply adds that it is in the same line as the camshaft sensor and that, on this engine (RHR/DW10BTED4), the job is straightforward: remove the screw, unplug the cable, and replace the sensor. [#16602120] [#16602280]
  • #1 16364532
    hellgt
    Rate: 9
    Hello or maybe someone knows where in the Peugeot 407 SW 2.0 HDI 136 HP is located sensor A position of the crankshaft. The computer shows me P0337 and P0338 but I have no idea where the sensor is. Maybe someone will explain to the layman the best pic or diagram with the exact marking of the sensor position. Thanks in advance
  • #2 16364660
    moto-kord
    Help: 137
    Rate: 505
    The front of the engine near the crankshaft pulley.
  • #3 16365135
    hellgt
    Rate: 9
    As I wrote, I am a complete layman, so I have to look down or take the wheel from the passenger side?
  • #4 16365426
  • #5 16367502
    hellgt
    Rate: 9
    If I know, the mechanics use electric motor construction schemes, etc. So if the mechanic needs a schematic (visualization) of the given element and location, then I am the more. Just this sensor if you are not mistaken from the side of the passenger's seat so I can not see it and I do not have the channel. Replacing the sensor is also a philosophy to unscrew the screw, disconnect the cable and replace the sensor. Only first you need to know what and where! Please do not give me such help if it deviates from the topic.
  • #6 16602120
    dazer91
    I had exactly the same problem. I could not locate where the sensor is located. I had bought a new one, but I could not find it. Reading the user's post 766630, I thought that maybe he was right. I called the mechanic and told me PLN 150. O_O
    I got angry like hell. It can not be that difficult. I opened the hood, locate where the camshaft sensor is and deduce that they must be in the same line. It was so. I turned the steering wheel to full right and the unlucky sensor can be seen from the front passenger side. If someone needs a photo, I can do it and mark it. The exchange lasted 10 minutes.
    Therefore, writing such comments as 766630, that it will break down better, donate ... Such a repair does not require more skills and 150 zlotys for repair is a mockery.
  • #7 16602280
  • #8 18021964
    jacek779
    Rate: 47
    Hello. What symptoms of this sensor damage did you have?
  • #10 21327611
    papel91
    >>16602120 tell me, are you able to send pics?
The crankshaft position sensor (sensor A) in the Peugeot 407 SW 2.0 HDi 136 HP is located at the front of the engine near the crankshaft pulley, accessible from the front passenger side after turning the steering wheel fully to the right. The sensor is part of the engine management system and is responsible for detecting crankshaft position, with fault codes P0337 and P0338 indicating sensor circuit issues. Replacement involves unscrewing the sensor, disconnecting the cable, and installing a new sensor, a relatively simple procedure that can be done without specialist intervention. Visual aids and diagrams are available showing the sensor location for engine codes RHR (DW10BTED4) and RHD, which are common to Peugeot, Citroën, Fiat, and Ford vehicles. The repair cost quoted by some mechanics may be considered excessive given the straightforward nature of the task.
