Fiat 1.3 Multijet: Locating Crankshaft Hole, Checking Timing & Self-Adjusting Gears
ryba2010 47529 5
  • #1 16468360
    ryba2010
    Rate: 69
    Hello, where is the hole on the crankshaft crankcase, because I can not find it for nothing, the camshaft was blocked. How to check if the timing is set correctly because there are no marks or wedges in the front. These gears are not self-adjusting?
  • #2 16468518
    jenusz11
    Help: 33
    Rate: 196
    in the front of the car in the gearbox notch in it there is a hole for blockade, as properly tighten nothing will change, there are no wedges
  • #3 16468576
    coperfild
    Help: 291
    Rate: 1697
    And not sometimes from the bottom.
  • #4 16468592
    jenusz11
    Help: 33
    Rate: 196
    in Doblo is the last week ago I was doing, I do not write the author what a fiat
    Added after 55 [second]:
    the picture is opel
  • #5 16476445
    adresfizyczny
    Help: 15
    Rate: 63
    They write nothing about the car / engine model. At the front of the clutch housing halfway up, it will extend the horizontal hole as he wrote jenusz11 This is probably in all fiatas. Without locking, it is impossible to set the timing in any way. There are no wedges at the top and bottom, and the camshafts are mounted so they can not be seen.
  • #6 16494360
    Jackall
    Help: 77
    Rate: 396
    Well, as I remember the left thread on the crankshaft.
