TV for In-Store Ad Display: Mounting, Loop Playback, Model Recommendations & USB Options
YayJayPi 9699 12
How can I set up a screen in a small store to play advertising videos from a USB drive in a loop, and what type of display or model is best for it?
Use a professional advertising monitor/panel rather than a normal TV; these displays are usually brighter, have no manufacturer logo, are built more solidly, and are meant for shops, airports, and shopping centers [#16195771][#16196326] For USB playback, some Samsung sets can loop a single file, and after checking they can also repeat a whole folder/catalog of movies, so you may need to combine multiple ads into one clip if your display only supports one-file looping [#16195780][#16197886] Another workable setup is a Raspberry Pi connected by HDMI, with the content sent over LAN from a central computer [#16195780] Specific models mentioned as examples were Samsung DB32D and Samsung MD46C [#16196366][#16197963] If you want a vendor for this kind of setup, Pictorplayer and Agneovo were suggested [#16196349][#16196067]
  • #1 16195635
    YayJayPi
    Hello, I would like to mount a television in my small store, which would serve to display ads and here my question - how best to do it?
    I was thinking about editing a few movies, putting them on a pendrive and starting a loop, but I don't know if there is such an option, if someone knows how to do it, I will be happy to hear opinions or links to ways to do it. :) And if someone recommends a TV that is suitable for this, I will also gladly use the suggestions.
    Commercial signage displays offer higher brightness and sturdier construction th
    #2 16195771
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    I hope someone will tell you because I don't want to look now. In any case, the TV is not used for this purpose ... just I do not know what it is called in Polish. It is used to display advertisements, signs, etc. It differs in that there is no manufacturer's logo, usually it has more brightness, generally better parameters than many TVs and a lower price. It also has a more solid construction.
    Samsung TVs Require Ads Compiled Into One Looping Video
    #3 16195780
    HD-VIDEO
    Help: 1265
    Rate: 1885
    I think it comes with graphic LED boards with very extensive graphics.
    On Samsung TV (in what I have), you can loop but separately in one file; so you need to assemble an advertising clip from several ads as one file.
    With many .... TV, you can use Raspberry Pi >> HDMI> TV and from the central computer is sent via LAN which everyone has to play. This is how one of the large retail chains operated.
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    it will be cheaper to buy a TV, unless you have money for a professional monitor ;)
    http://www.agneovo.pl/shop/
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
    Commercial LCD panels differ from TVs for signage use
    #5 16196326
    rosak
    Help: 142
    Rate: 559
    This is not about LED boards.
    It's about the LCD panel that differs from the TV in what I wrote earlier. It is used for these purposes. At the airport, in a shopping center, etc., you won't see TV sets, just such panels. I myself have one that I bought for pennies (used of course) to display diagrams. Usually it has only 1 HDMI input but it has different communication interfaces built in.
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    Well, this is the company I recommend above. They provide such advertising panels (stops, airports, stations, kiosks and the like).
    http://www.pictorplayer.pl/#
    OMNI-SAT
    rosak
    Help: 142
    Rate: 559
    The one I have is Samsung DB32D.
    HD-VIDEO
    Help: 1265
    Rate: 1885
    I will add that after checking, the TV can also repeat not only one file but also a catalog with many movies.
  • #9 16197959
    YayJayPi
    Could you provide a TV model I would appreciate :) ai was this option standard or do you need to install or buy any additional applications? And how do you think most newer Samsung TVs will have this option?
  • #10 16197963
  • #11 16199261
    necavi
    Level 19  
    Help: 5
    Rate: 57
    OT
    rubeno wrote:
    ... If you place a regular TV set, then take into account that the teleharacz will probably be obliged to pay.
    He won't have to without the antenna installation, because such a TV can't do without it.
  • #12 16199288
    Matitronik
    Help: 10
    Rate: 40
    Advertising panels are closer to PC monitors than to television sets Gentlemen.
    It probably doesn't matter at all, because you pay tribute for the "possibility" of receiving the signal and not just for receiving it. If I'm wrong please correct me.
    In addition, e.g. in hypermarkets, material on screens is usually displayed on a cable TV network.
  • #13 16199451
The discussion revolves around the best practices for mounting a television in a retail environment for ad display purposes. Users suggest that while standard TVs can be used, dedicated advertising monitors are preferable due to their enhanced brightness, durability, and lack of manufacturer logos. Loop playback can be achieved on many TVs, including Samsung models, by combining multiple ads into a single file. Some users recommend using devices like Raspberry Pi for more complex setups. Specific models mentioned include the Samsung DB32D and Samsung MD46C, with a suggestion to consider professional advertising panels for optimal performance.
