Underfloor Heating: Cold Tile Floor Despite Warm Indoor Temperature - Possible Causes
Fokusmok21 25023 3
  • Why does underfloor heating leave tile floors cold?
    #1 16196345
    Fokusmok21
    I would like to advise, because we have underfloor heating throughout the house. The heat is felt indoors, but not on the floor. The man who did the floor heating said that it was about the air temperature and not the floor. That's what floor heating is all about so that your legs don't freeze. Also, sometimes you feel warm on the floor in some rooms, but only locally. We have a tile floor and the legs are very cold. If you feel the floor warm slightly locally, it cools quickly. What is wrong??? Thank you for your response.
  • #2 16196367
    sanfran
    Help: 963
    Rate: 3004
    Browse: https://www.elektroda.pl/rtvforum/topic3284767.html#16135558
    And especially:
    2) complaining about pink - beeeee, I thought I was going barefoot around the house because it is a floor ... well, unless outside at -25'C, but maybe two days a year
  • #3 16196391
    Fokusmok21
    This is our second home with underfloor heating. In the first we had only in the kitchen and it was nice and warm in the feet, so I do not understand this quote. I have a comparison, that's why it frustrates me and I'm trying to get help .... because there is a big difference in underfloor heating from the previous house.
    Regards
  • Better insulation keeps the floor only slightly warm
    #4 16197269
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    And he did very well. The heat is evenly distributed. It's the same, the temperature on the floor is 1-2 degrees Celsius higher than the set one (19.5noc and 22nd day). If you had radiators you would probably give boards and the impression would be nicer, but it would not be warmer by the floor.
    A warm (clearly) floor is a defect in the floor, harmful to health for a longer stay, only acceptable in bathrooms.
    Raise the temperature on the controller and after the topic.
    One overheated circuit is not a problem, but all ...
    You just have a better insulated house and the temperature is maintained without notorious heating of the floor.
