HTC Desire 626: Rooting Process, Orange PL, Kingo Root PC/APK, TWRP, Custom ROM & Boot Unlocked
kwantor 4455 3
  • #1 16197804
    kwantor
    Help: 352
    Rate: 1227
    Hello, as in the subject, it is Orange pl. I made various attempts to rotate, but to no avail .. it is only possible with Kingo root PC or apk, but only temporarily until the device is restarted. There is no TWRP network for this model. I will be grateful for any advice. at the moment I lost my original recovery, after flashing the custom room, I was in the wrong room with Desire 626 S ..
    Naturally, the Boot is unlocked.
    Best regards.
    cxzcxz123
    Level 32  
    Help: 140
    Rate: 284
    This is a good forum for phones:
    https://forum.xda-developers.com/desire-626/g...wrp-how-to-install-twrp-3-0-root-htc-t3481688
    Maybe you will need it if you haven't tried this method yet. I just don't know if the branded system matters here. But the branded one is known to be cluttered, so I recommend changing it anyway.
  • #3 16199648
    kwantor
    Help: 352
    Rate: 1227
    I do not know why I did not find it (I have been sitting on this forum for a week) there is light in the tunnel, but if it will pass, it will turn out, I now have Android 5.1 lolli pop .. TWRP is for Andek 6. I don't care, check, I will put it completely scrap at the most :)
  • #4 16200447
    kwantor
    Help: 352
    Rate: 1227
    At the moment, unfortunately, it is impossible to set the root in this model .. Apart from my poor knowledge in this matter. I used the only thread closest to this model (straight from the Russian forum) and almost something sparked .. I booted the image and a quite familiar menu appeared with the option to upload a superuser, but unfortunately this menu freezes, because at that time the phone starts in the background, wakes up shela coating or whatever .. It took me quite a long time to figure out how to unfreeze this screen :) The author mentions something about the bag, that you need to make a backup partition and it is not non-critical, um, for me it is, because it is difficult to get more scarce info.
    Edit. I solved the problem using the files of the Russian to which you gave me the link. However, you had to use root-Kingo root.apk (temporary) and run the RASH application immediately, then choose to flash the recovery.img (TWRP) file located on the SD card. This is the last ARCHIVE link. Then superusera.zip is installed from the recovery shell (fast boot TWRP)
    The system has been permanently set with root privileges. It is a very resistant phone to this type of action, besides, android 5.1 likes to purr and storm on some applications installed with root requirements. Eg Xploid, the mount folder .. I don't know if it's not about creating this reserve partition, which I have no idea :) a is mentioned by the author. I do not recommend this phone :(
